Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 05-03-2013, 03:32 AM   #751
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
stock rear diffs (gearing must be right) and built trans. ipt and a few other companies do subaru autos. The rest of the drivetrain can be much less built that 6 spd setups because the power is more linear and theres not nearly as much shock to parts
stretchedk7 is offline   Reply With Quote
Old 05-11-2013, 04:42 PM   #752
J_Maher_WRX
Member#: 290307
http://www.youtube.com/watch?v=rVkHi...ature=youtu.be
Got another video of mine here Ben, running the Torqued Performance Stage 3 map in this one though.
Vehicle: 2011 WRX
Motor: Stock
Turbo: Stock VF52
Boost: 20psi
Transmission: Stock 5 Speed
Redline: ~7000
Upgrades:
... Nameless Performance Catback (muffler deletes, single resonator)
... FMS 3" Downpipe
... FMS Front Mount Intercooler
... KSTech 73mm Cold Air Intake
... Grimmspeed Uppipe w/44mm Tial EWG
... Grimmspeed EBCS
... Grimmspeed Lightweight Crank Pulley
... DW65C Fuel Pump
Weight: ~3450 including myself
50-100MPH: ~7.1 seconds, clocked using my iphone :P
Could also probably go about half a second quicker if I downloaded the flat-foot shifting patch.
TP Stage 3 was definitely a nice improvement over stage 2 though!
J_Maher_WRX is offline   Reply With Quote
Old 05-11-2013, 05:56 PM   #753
toph
Member#: 78640
08 STi 3.5XT-R
15 STi CWP | 02 STi Wagon
I always wonder why you would get an upgraded OTS map rather than having someone protune it, or even e-tune it. Is price the only reason?
toph is offline   Reply With Quote
Old 05-11-2013, 06:49 PM   #754
J_Maher_WRX
Member#: 290307
Well, the fact that there isn't a single AWD dyno in Newfoundland, nor are there any tuning companies here. So it's either get an e-tune, or tune it yourself...
And it's not an OTS map... He sends you a base map for the relevant mods, and then he does an e-tune, log, make revisions, new map, log, make revisions... Until the tune is perfect. My 'stage 3' map took 6 revisions for example. So it's as close to a protune as you can get without being on a dyno.
Old 05-11-2013, 09:27 PM   #755
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
No car drives the same on the street as it does on the dyno. A street or etune is way more accurate then just a dyno tune. That's why any tuner that's worth the 400-500 dyno tuning price will take it out on the street after to finish the tune and dial it in.
Slimsti is offline   Reply With Quote
Old 05-11-2013, 11:27 PM   #756
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Vehicle: 2011 WRX
Motor: Stock
Turbo: Stock VF52
Boost: 20psi
Redline: ~7000
Upgrades:
... FMS 3" Downpipe
... Grimmspeed EBCS
... DW65C Fuel Pump
I clocked 8.25-8.75 sec with the Quicktime movie inspector (really hard to tell from that angle when you EXACTLY hit 161kph)...but you can go ahead and figure 8.5 sec would be a perfect halfway point and probably the most accurate. That's a pretty good improvement over a stock 2011. How do you like the EWG on that turbo?
150% agree
amalgrover is offline   Reply With Quote
Old 05-12-2013, 12:48 AM   #757
toph
Member#: 78640
08 STi 3.5XT-R
Oh okay, I thought it was just an upgraded OTS map. I didn't know it was logged and recalibrated.
Of course, that's the only way. I wish I had my stage 2 dyno tune street tuned after, had some weird spots in certain gears that I feel could have been improved on the street. I didn't complain because it was more than I wanted at the time anyways.
Old 05-12-2013, 01:13 AM   #758
J_Maher_WRX
Member#: 290307
150% agree
Lol it's a lot faster than that bro. Almost 9 seconds? Ben clocked my old stage 2 + EWG map at 7.4seconds.. I did have a lazy 2-3 shift in that video but it's still way quicker than over 8 seconds I think... Or I would certainty hope so haha Need to download the ffs patch and do a good 3rd-4th pull to get the best time I would imagine. Haha
Honestly the EWG worked pretty well. I had just stage 2 + Cobb sf intake for a while, and then I actually sold the intake and added the EWG, gained something like almost 15whp and 10 wtq across the board, so it was well worth it IMO. I got it mostly to make sure I would have 0 boost creep issues considering I have no cats and no mufflers and the car is driven all year round haha
Old 05-12-2013, 08:35 AM   #759
amalgrover
Member#: 183480
2009 Forester XT
Hey, I didn't post the video...I just posted the accurate time for you. Even if I give you the most generous estimate possible, I am only getting 7.42 seconds. I got about the same time as xluben did on your last video. So it isn't that Quicktime's movie inspector timestamp is inaccurate or anything. It probably has something to do with the 3/4 second shift you took on this one whereas the last video had a nice clean and quick shift.
With that EWG, you should be able to hold boost out quite a bit longer than the stock IWG. You should throw an aggressive boost map on there (something like 23psi tapering to 18) and see how she does. Did TP give you any whp/wtq numbers? If they didn't, you should run your logs through Airboy or VD to compare the difference between the stage 2 vs stage 3.
...Edit: I am assuming the answer to my last question is yes considering you said you gained 15whp/10wtq...
Old 05-12-2013, 10:23 AM   #760
J_Maher_WRX
Member#: 290307
Yeah I understand bro, like I said it was some lazy granny shifting in that video haha when I get the FFS software ill make a few attempts at getting some quick times. Would like to hit 7.0 flat or high 6's.
Yeah I'm hitting about 21psi now. Can't remember what it's tapering to. I've got virtual dyno and it's saying ~300/325 I believe. Which probably isn't that accurate, but seems like I gained roughly 20whp/25wtq over the stage 2+EWG setup. Numbers probably aren't accurate at all, but who knows! During my logging my last revision was doing 50-90mph in about 5.5seconds in just third gear, so that's why I'm thinking my 50-100 mph could be gotten under 7 if I do a really quick shift to 4th.
Old 05-12-2013, 06:59 PM   #761
Slimsti
Member#: 155696
Yeah it looks like almost 8 to me too. Shifting speed and what gear u start in makes a huge difference. I went from 7.5,to 6.8 to 5.6 in back to back to back pulls. Starting in 2nd seemed to work the best for me. More shifting but helped keep me in my sweet spot
Old 05-13-2013, 08:21 AM   #762
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
I'll have to take a look at it, but shifting slowly can definitely make a huge difference.
xluben is online now   Reply With Quote
Old 05-16-2013, 09:40 PM   #763
Slimsti
Member#: 155696
https://www.youtube.com/watch?v=Vyob...e_gdata_player
New pull with 27psi. Should be a bit quicker than my 6.5 second fp green pull
Old 05-17-2013, 02:23 AM   #764
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
^^ Looking good I need to probably get a retune and make a video myself..
k04sti is offline   Reply With Quote
Old 05-17-2013, 08:47 AM   #765
Slimsti
Member#: 155696
Do it. I saw a huge difference in power adding the FMIC and cranking the boost upto 27 with speed density. I was hoping for a little more power than i made but i cant complain the thing really moves once you get past 4k. Id love to see what other 04-07 Sti's with dom 3 xtr are doing so i can compare mine. What kind of power and boost are you running?
Old 06-02-2013, 02:39 PM   #766
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Vehicle: 2007 STi
Motor: 2.5L Hybrid motor, 2.0L WRX heads, PnP, Cosworth Cams
Turbo: EFR7670 Full Race kit w/ FMIC
Boost: 16 PSI
Transmission: '07 6-speed
Redline: 7000 rpm
Upgrades: PnP heads, Cosworth cams, +1mm valves, reverse manifold FMIC, FIC 1100cc injectors, Link G4 extreme pro ECU
2-3-4 pull
3-4 pull
Needs more boost and my 2.34L LR motor stat.
My laptop stop cooperating so I couldn't look at the logs for exact time. If anybody could time the vid with editing software I would appreciate it. Thanks.
Old 06-02-2013, 05:09 PM   #767
Slimsti
Member#: 155696
Dude thats moving for only 16psi Jesus. Crank that up and it'll be off the wall. Lol
Old 06-02-2013, 11:18 PM   #768
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Originally Posted by kellygnsd View Post
Vehicle: 2007 STi
Boost: 16 PSI
Redline: 7000 rpm
2-3-4 pull
http://youtu.be/7g96FYPxHzQ
3-4 pull
http://youtu.be/uA6rR0LeS_o
Why 2.0 heads?
340Duster is online now   Reply With Quote
Old 06-03-2013, 12:39 AM   #769
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
I did some vbox 50-100s in my GTR today and all I have to say is DAYUM Andys car fast
Junior2JZ is offline   Reply With Quote
Old 06-03-2013, 12:41 AM   #770
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Originally Posted by 340Duster View Post
Why 2.0 heads?
Because I had them and well ported heads w/ cams and valves >>> stock STi heads. It was worth giving up AVCS
Old 06-03-2013, 12:54 AM   #771
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
OK, yeah, so you gonna share them?
Old 06-03-2013, 10:43 PM   #772
renosubby
Member#: 152576
2006 STI 10.8@ 129
www.Mayhemtuning.com
renosubby is offline   Reply With Quote
Old 06-05-2013, 12:45 AM   #773
Junior2JZ
Member#: 64908
2x9.0@170mph GTRs
Only 2.3 with a 3.60 60-130
0-170.5mph in 9.0 seconds... but it's my daily driver lol
Old 06-05-2013, 06:20 AM   #774
manitou
Member#: 193757
2006 XTI Limited
That's dope! Yeah a daily with twin 6266's! Lol I can see why you did the Carbon Ceramic brake upgrade!
What was Andy's 1.9? I think you need to go bigger! Hahaha
Old 06-05-2013, 10:20 AM   #775
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Game Over!!!!
pack it up guys, nothing to see here
NASIOCers!! Starter mods list Daniel son Legacy Forum 4 11-21-2006 03:56 PM
50 cent listings on eBay motors plunk10 Off-Topic 7 10-17-2006 12:15 PM
Official NASIOC OT C List dr_wheel Off-Topic 25 02-22-2006 05:41 PM
NASIOC GMail Invite List AVATAR-X Off-Topic 458 05-21-2005 10:04 AM
Japan's Top 50 car list Tragedy Off-Topic 5 07-29-2003 11:49 PM
