#101 |
Member#: 225225
Vehicle:11 WRX 335HP, 394TQ, 93 VF52!! |
hey now, i still think my 99 si was faster then my wrx. dont knock the vtech haha. i had that bitch coming on at 2-3k rpm.
#102 |
Member#: 155696
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
Hahaha i know right. I had a Chipped p28 "skunk 2" ecu with a 3,200 vtec cross-over. Thought that thing was the fastest car in the world cause it ran 14.2. Then again that was 13 years ago and that was pretty quick considering.. Now every car the comes out runs 13's or quicker stock. It was a better time.lol
#103 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
My car had the F23 motor and the VTEC engagement was variable, but it would come on as low as 2,000rpm's under normal acceleration. It was basically a gas-saver VTEC instead of performance. You couldn't hear or feel it at all. Anyways, enough with the Honda's! I just wanted to post a slow car as a reference
#104 |
Member#: 225225
T3T4, .68 turbine, .70 AR compressor, 3" inlet, 3" piping, 11psi, stock motor, 295hp, in a 2000lb gutted body...yeah she was quick!!! That is all.
#105 |
Member#: 261612
Too bad you didn't do a 50-100mph run! Then you would know for sure which one was faster! I am really fortunate I did one with my old car. Now I know without a doubt that the Subaru is faster!
#106 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
#107 |
Member#: 261612
I'll check it out. I was thinking that I could troll YouTube and use those. I'd rather have good mod lists with them if I could though.
#108 |
Member#: 133146
#109 |
Member#: 90110
W. Canada
Vehicle:2004 wrx wagon WRB |
Vehicle: 2004 WRX Wagon
Motor: 2.5L Forged Pistons, Rods, Ver8 EJ207 heads Turbo: GT35r .82 hotside Boost: 22psi Transmission: 04 STi Redline: 8000rpm Fuel: 91 Upgrades: UR 3" turbo back TWE EL Header Tial 44mm EWG routed back into exhaust UR FMIC UR 900cc Injectors (Siemens) Walbro 255 Fuel Pump Aquamist HSF-5 50/50 Work Emotion 17x9" Wheels Bridgestone RE01 245/45R17 Tires Weight: 3542lbs 50-100MPH: 5.5sec ![]() I'm going to try an 80-160kph (same as 50-100 I think) as I think it should be faster if I do it in 3rd and 4th gear opposed to this 60-160kph graph where I'm doing an extra shift. I've been doing 60-160 graphs ever since I started upgrading my Suby back in 2005. I have found its a great way to track improvement. |
#110 |
Member#: 287906
Vehicle:2006 STi Black |
Vehicle: 2007 STi
Motor: 2.5L Forged Pistons Turbo: Kinguawa TD-06H 20G 8cm Boost: 24->22psi Transmission: Stock 6 Speed Redline: 7500rpm Fuel: 91 + Meth 50/50 Upgrades: CES 3" TBE AP 3" Turbo Intake CAI ID 1000cc Injectors Walbro 255 Fuel Pump TGV Deletes Hyperflow TMIC Weight: Full Stock Weight + Driver 50-100MPH: |
#111 | |
Member#: 243261
TXIC
Vehicle:2004 WRX Java black pearl |
Yea I remember those days.. I had a 95 gsr back in 98 ran 15.0 at like 93-94 bone stock gutted it then put a header on it.. went alot faster. 2440 with me in it was the weight. Compresison test stock on that car showed 230 psi each cylinder |
#112 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
Vehicle: 2005 STI
Motor: ej257 stock pinned sleeves @ 100mm, o-rings, manley pistons, pauter rods, d25 heads, supertech +0.5mm valves, ferrea drag springs, gsc s3 cams Turbo: beat to hell gt35r .82ar with the 2.5" turbine outlet Boost: 26-27psi Transmission: Stock 6-speed Redline: 8200rpm Fuel: e85 Upgrades: gruppe-s UEL header, 2.5" uppipe, 3" downpipe, qtp cutout, borla hush catback id2000 injectors, dual walbros, aeromotive fpr, fuelab fuel filter custom fmic w/garrett 1000hp core and 3" ID piping, tial bov dss rear axles, dss aluminum driveshaft, clutchmasters clutch, bfg drag radials about 3300lbs w/driver I got a speeding ticket while taking video for this stupid thread. I was very relieved when the cop said he got me for 85 in a 60, and even more relieved when he wrote the ticket for 69 in a 60. My V1 never went off and the cop literally came out of nowhere a few seconds after I stopped filming and slowed down. Oh and right before I shot this, I had the front wheels off and I think I knocked a wheel weight off, hence the shaking. While going frame by frame in movie maker I get 4.5 seconds +/- a tenth. I think I could improve if I brake boost 3rd gear, but I'm not going to push my luck with the local cops. |
#113 |
Member#: 261612
I'll try to get this updated soon!
If he kept changing the numbers it means he probably didn't even get you on radar/laser and just saw you flying past. |
#114 |
Member#: 225225
We were trained in visual so he can write it like that. Also the lower he's just being nice so your fines aren't high and not more than 2 points.
#115 | |
Member#: 133146
#116 |
Member#: 287906
Can any slow frame mine? I think its about 5secs thanks
Few posts above ^^^ |
#117 | |
Member#: 78165
South East
Traps... I don't know. But I've driven the car with a tune that trapped 125, and with a tune that trapped 132, and it feels closer to the 132 tune ![]() |
#118 |
Member#: 261612
#119 | |
Member#: 261612
50-100mph: 5.75 seconds 50-100mph: 4.49 seconds List is updated! |
#120 |
Member#: 133146
how about the gtr? That car run 11.0@129 with just a tune
#121 |
Member#: 261612
Forgot about that one. That would be a good comparison point because it has a trap speed associated with it.
#122 | |
Member#: 261612
Do you think I should add videos from YouTube to the list? |
#123 | |
Member#: 133146
I really want to see your car running at the track, your time is really impressive. My car is down again i will make a high boost run in about two months. |
#124 |
Member#: 295254
Vehicle:2011 STI Hatch Plasma Blue Pearl |
I didn't see any stock STI on the list so I figured I'd give it a go. Man I must really suck at driving. A stock STI seems so slow compared to all these built cars. I logged using the AP on a stock map.
Code:
amp2oo1 2011 Subaru STI NA NA NA NA NA NA 14.5 93 NA NA NA NA NA NA 9.88 Vehicle: 2011 STI Hatch Motor: Stock Turbo: Stock Boost:Stock Transmission: Stock Redline: Stock Upgrades: All stock w/P&L CBE Weight: Stock + 3/4 tank of gas + 205 lbs driver 50-100MPH: 9.88 Code:
Time RPM (RPM) Vehicle Speed (mph) 47.88 2864 36.04 48.26 2836 36.04 48.64 2831 36.04 49.02 2836 36.04 49.4 2824 36.04 49.78 2851 36.04 50.16 2905 36.66 50.54 2953 37.28 50.92 3029 38.53 51.3 3116 39.15 51.68 3210 40.39 52.06 3322 42.25 52.44 3546 45.36 52.82 3764 48.47 53.2 4007 50.95 53.58 4255 54.06 53.96 4442 57.17 54.34 4651 59.65 54.72 4928 62.14 55.1 5092 65.24 55.48 5314 67.73 55.86 5508 70.21 56.24 5676 72.08 56.62 5789 73.94 57 5965 76.43 57.38 6166 78.29 57.76 6636 78.29 58.14 4418 79.54 58.52 4807 81.4 58.9 4896 83.26 59.28 5011 85.13 59.66 5077 86.37 60.04 5190 88.23 60.42 5277 89.48 60.8 5347 91.34 61.18 5416 92.58 61.56 5529 93.83 61.94 5584 95.07 62.32 5647 96.31 62.7 5740 97.56 63.08 5769 98.8 63.46 5823 99.42 63.84 5896 100.66 64.22 6031 101.9 64.6 6081 103.15 64.98 6112 104.39 65.36 6203 105.63 65.74 6242 106.25 66.12 5588 106.25 66.5 4881 104.39 66.88 4259 103.15 67.26 3674 100.66 EDIT I checked another log on stock map and realized I suck a little less. Previous one was in 3/4th gear, this one is all 4th. Still slow. Code:
Time RPM (RPM) Vehicle Speed (mph) 0 2170 36.66 0.38 2167 36.66 0.76 2188 37.28 1.14 2229 37.9 1.52 2312 39.15 1.9 2376 40.39 2.28 2474 42.25 2.66 2535 43.5 3.04 2659 45.36 3.42 2777 47.22 3.8 2907 49.71 4.18 3023 51.57 4.56 3130 54.06 4.94 3269 55.92 5.32 3448 58.41 5.7 3592 60.89 6.08 3724 63.38 6.46 3852 65.24 6.84 3964 67.73 7.22 4113 70.21 7.6 4225 72.08 7.98 4352 74.56 8.36 4450 76.43 8.74 4607 78.29 9.12 4714 80.16 9.5 4842 82.02 9.88 4941 83.89 10.26 5032 85.75 10.64 5131 87.61 11.02 5245 89.48 11.4 5331 91.34 11.78 5465 93.21 12.16 5533 94.45 12.54 5664 96.31 12.92 5713 97.56 13.3 5835 99.42 13.68 5922 100.66 14.06 5955 101.9 14.44 6046 103.15 14.82 6166 104.39 15.2 6181 105.63 15.58 6272 106.88 15.96 6342 108.12 16.34 6398 109.36 Last edited by amp2oo1; 05-13-2012 at 04:14 PM. |
#125 | |
Member#: 194580
Vehicle:05 STI NF Performance |
OMG ben that is a fast azz accord |
| Thread Tools | |
| Display Modes | |
| NASIOCers!! Starter mods list | Daniel son | Legacy Forum | 4 | 11-21-2006 03:56 PM |
| 50 cent listings on eBay motors | plunk10 | Off-Topic | 7 | 10-17-2006 12:15 PM |
| Official NASIOC OT C List | dr_wheel | Off-Topic | 25 | 02-22-2006 05:41 PM |
| NASIOC GMail Invite List | AVATAR-X | Off-Topic | 458 | 05-21-2005 10:04 AM |
| Japan's Top 50 car list | Tragedy | Off-Topic | 5 | 07-29-2003 11:49 PM |
