Old 05-08-2012, 07:39 AM   #26
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Originally Posted by MaddMax
Interesting because the service manager at my Subaru dealership say they can tell that the ECU has been tampered with by looking at the CVN. Since you're a tech and obviously quite knowledgable, now I don't know who to believe Thanks for this posting up.
Read Christian 's email. Your reading skills = fail.
moonrider_99 is offline   Reply With Quote
Old 05-08-2012, 09:51 AM   #27
woody06967
Member#: 110330
2007 STI Limited
2016 Golf R MT
I bought my STI with an aftermarket exhaust, intercooler, and CAI on it from a Subaru dealer CPO who offered to sell a custom tune at the same time. This is my second turbo Subaru that I've done a fair amount of work to and never had an issue with modifications at a dealer.
woody06967 is offline   Reply With Quote
Old 05-08-2012, 03:14 PM   #28
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
which dealer offered you a tune?
Old 05-09-2012, 03:34 PM   #29
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Why so harsh? This is the first time I've ever seen this Cobb email and obviously many others are in the same boat.
My question is why then are people so worried about the ECU modifications and warranty issues if the aftermarket flash (assuming you removed it prior to taking it in) is completely transparent when hooked up the Subaru's computers? From what I've read on this site, there have been many cases where Subaru denied powertrain warranty work claiming the ECU had been modified. Daily on this site, you read people say, "if you mod the ECU, kiss your powertrain warranty goodbye".
Even though I'm currently happy with stock power levels, I'd eventually consider a Stage I flash (no intention of Stage II ever). However, with everything I've read on this site, what my service manager is saying, and what the local Kansas City Subaru group says (one of which is full of scooby gurus), the word is Subaru can tell the ECU has been tampered with regardless of what Cobb says. Now UK-Wagon, whom claims to be a Subaru tech, says Cobb is spot on with their findings.
Who are you to believe? It's a risky proposition when $4K+ is involved in the event your shortblock becomes wrecked and Subaru says "denied."
MaddMax is offline   Reply With Quote
Old 05-09-2012, 04:13 PM   #30
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Harsh because you did not read a very valuable email from COBB with the due attention.
Here's how dealer finds out your ECU is/was altered
- Your ECU is stock or modified but you have physical mods (downpipe, etc)
- You are "physically" stock but your ECU is modified and therefore your CVN/CID does not correspond to one of the numeric combinations that Subaru assignes to the ECUs in factory.
- You re-flashed back to stock using open source, CID/CVN are lost*.
*I'm actually curious about this one, since according to COBB (if I understand this correctly) if CID is not same as the CVN the car should not start (ECU fails internal check). UK-Wagon, can you comment?
Old 05-09-2012, 05:19 PM   #31
apocalight
Member#: 315478
2012 STi
I dont recall seeing anything about the car failing to start with a different CID / CVN combination. The CID just refers to the software that SHOULD be on the ecm and the CVN is that validation. When you tune it, the CVN check changes to reflect that the ecm is not using the software version expected based on the CID.
apocalight is offline   Reply With Quote
Old 05-09-2012, 06:10 PM   #32
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
It's not fully clear to me based on this section from COBB:
"When the AccessPORT is installed, it changes the CVN so it no longer
matches the valid value for the CID. This is required because we are
altering data in the ECU. If the CVN is not correct for the new data,
the ECU will fail its internal check and not run because it thinks it
data is bad. So, we are forced to alter the CVN if we want the ECU to
run with the new data. That means we're not changing the CVN for the
sake of changing it, we have to in order for the ECU to operate.
When the AccessPORT is uninstalled (Reverted to stock), the CVN
_*matches*_ the CID."
I have a feeling somewhere in this paragraph it should say CID instead of CVN, can anyone confirm?
Old 05-10-2012, 08:18 AM   #33
WRXLTD
Member#: 136314
2014 Grand Cherokee
I'd bet money that if I was bone stock other than an OTS Cobb Stage 1 reflash and a CBE when the motor popped (from everday driving), as long as I unmarry the AP correctly and don't fall for any tricky business from the dealership (i.e. admitting to an ECU reflash), there's no way I would be denied warranty work...the first time at least.
WRXLTD is offline   Reply With Quote
Old 05-10-2012, 08:23 AM   #34
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
I've taken that bet, and my CBE (SPT) came shipped to the dealer on the car... Not that I want my motor to pop, I'm just saying...
nightdown fox is offline   Reply With Quote
Old 05-10-2012, 12:41 PM   #35
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
yep, no reason to get the claim denied, as long as you flash back to stock and drive it long enough for all sensors to come back online.
Old 05-10-2012, 12:55 PM   #36
WRXLTD
Member#: 136314
2014 Grand Cherokee
Yes...good point! That or say I disconnected the battery overnight to clear the CELs.
Old 05-10-2012, 08:37 PM   #37
NeverSummer WRX
Member#: 311108
2012 WRX LTD 5-door
Hmmm.... this may make me reconsider waiting until my warranty is up to get an AP.
NeverSummer WRX is offline   Reply With Quote
Old 05-11-2012, 09:21 AM   #38
WRXLTD
Member#: 136314
2014 Grand Cherokee
IMO, the longer you stay with the crapstastic stock tune, the better the chance of breaking a ringland. Just look how lean the stock tune is in boost...
Old 05-11-2012, 08:17 PM   #39
NeverSummer WRX
Member#: 311108
2012 WRX LTD 5-door
Agreed.... however I would rather have a broke ringland with a warranty than a great tuned car with no warranty in need of a short block.
Old 05-12-2012, 06:43 AM   #40
WRXLTD
Member#: 136314
2014 Grand Cherokee
There's no arguing that point. Yes it's a chance one takes losing a portion of their warranty after flashing the ECU. My greatest fear is breaking a ringland on the stock tune, getting the motor fixed under warranty, then another ringland breaking later on. I don't think the dealership is going to fix it under warranty the second time no matter what the owner says...they will claim "abuse".
Old 03-31-2013, 11:12 PM   #41
SATSTI
Member#: 341814
2013 STI
Wow. That picture of the tune is pretty horrible. I was thinking of staying stock as well and just doing suspension mods...but man AFR's shouldn't be anywhere near stoich during boost. WTF were they thinking?!
SATSTI is offline   Reply With Quote
Old 04-01-2013, 01:53 AM   #42
Madrallyskillz
Member#: 13762
In a word... Emissions.
Subaru is fully aware of the lean tune under boost, and they rely on the knock detection system to keep the motors together, they are also fully aware that that same lean tune is what lends to the higher number of engine failures; and they have a pretty good idea of how many will fail under warranty period.
Thing is... it makes sense for them to do it to get the lower emissions ratings for many reasons, marketing and tax credits (Millions of dollars per year) to name a few...
Madrallyskillz is offline   Reply With Quote
Ringland Failure Poll for MY 2009-2011 STi's last lemming alive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 09-08-2012 08:53 PM
Ringland failures with ELH? TRSCobra Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-11-2011 05:32 PM
And I Thought Ringland Failures were for the 2.5 motors... dux10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-18-2011 03:32 PM
Stock pistons...cracked ringlands...what next??? daddyphatsax304 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-22-2010 12:58 PM
School me on ringland failure...preventive measures? JDMFLCL Newbies & FAQs 12 06-18-2009 09:33 PM
