Old 04-23-2001, 03:53 PM   #1
mack109
Member#: 3713
Angry wet my engine
Last week my wife took our MY 95 Legacy wagon with AT in to have the driver's side window regulator fixed and the dealer sent her home with a list of additional stuff they wanted to do.
Replace oil seals (for leaks) on right rear cam seal and oil filler neck @ $45 each !, Power steering flush ?, Air/fuel service, what ever that is.
Well there has never been a leak under this car (108K miles). There was a little oil "sweat" around the right rear cam seal and the oil filler neck, which could have been a dribble for the last time I changed the oil, so I thought I would clean the engine and look for evidence of new oil leaks. I got out my trusty pressure washer and went to town. Big mistake! When I restarted the engine it would start right up, fall back to idle, and stall, running quite rough just before stall. I figured the plug were wet, and they were. I pulled off the boots and blew out the plug wells and boots with compressed air. Restart - - same thing. It starts but won't idle and then stalls. I let it sit in the sun with the hood open to dry out everything else for several hours. Same thing. In neutral, I can keep it running as long as I am above 3000 rpm. I even drove it about 2-3 miles and it stalled each time I came to a stop. So home I went and did an ECU reset, by the battery disconnect method. Still no idle. The "check engine" light is not on. Any ideas?
PS: I found (so far) 3 ways to reset the ECU
1. disconnect battery Neg ground for 30-40 mins. reconnect and restart without touching throttle (it would not idle)
2. remove 50 amp and two 30 amp fuses from front fuse box for 5 mins. from the tech archives (did not try this)
3. connect green connectors and black connectors under dash near steering column as per MRT website (could only find one black connector)
Are these methods all effective and are there pros and cons to each method? Thanks for any advice.<u>Text</u>
mack109 is offline   Reply With Quote
Old 04-23-2001, 04:42 PM   #2
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
You might have blown a hose loose with the pressure washer. Check all your intake and fuel lines (probably not a fuel line, since it started more than once.
As a general rule, a pressure washer is not a good tool for cleaning your engine. Engine cleaner, a soft brush, and a garden hose should be plenty.
gavin is offline   Reply With Quote
Old 04-23-2001, 04:45 PM   #3
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
NEVER connect those plugs under the dash. Someone once posted (I found it on a search) that if you connected those that the CE light would blink a code, thereby telling you what is wrong. Uh...no. The car flipped out, all the dash lights blinked on and off (no, there was o dicernable code) the lights and blinkers were going nots etc. And to add insult to injury it was impossible to get any angle to get the darn pulgs apart! I had to break it. Man...Don't ever connect those things.
ChosenWon is offline   Reply With Quote
OMG I just wet my pants Porter South East Region Forum 35 02-14-2005 11:54 AM
My engine is blown, need advice on engine options GimpWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-26-2004 06:21 PM
is my engine a crate or JDM engine? JonofScio Normally Aspirated Powertrain 5 02-16-2004 08:47 AM
should i build my engine or buy an sti engine? David Glasscock Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-18-2003 02:08 PM
My car is eating coolant and smells like there's a dead cat in my engine bay... SoLo OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 09-29-2003 01:35 AM
