#1 |
Member#: 18383
I have herd that these radiator splitters really do work That their needle is lower and so on. Now that combined with some water wetter would drop it even more. Is it possible to keep the water so cool that your engine won't run effeciant or properly? Or maybe your heater won't work as good, i duno im not a mechanic.
Also what i have a cusco radiator cap i got for free, what does that cap accomplish ? Anything? Also what will a thermostat do such as teh zerosports one?
#2 |
Member#: 12061
Vehicle:2002 Black WRX |
I am interested in these questions also.
My friend changed the thermostat on his Impala SS. The car ran great in the summertime. In the wintertime, his car ran fine, but his heater would never warm up. It was a fast cold car! SAW |
#3 |
Member#: 18226
Vehicle:2001 M3 Laguna Seca Blue |
Ditto
*BUMP* |
#4 | |
Member#: 10334
Vehicle:91 RX7 LSx swap '09 CC 3.6 4motion |
Your temperature is regulated by the thermostat.....You could have a radiator the size of a mack truck and your car would still run at thermostat temperature. The splitters, radiator caps, and "racing" radiators that are available help control overheating to which the thermostat has no control over. The radiator cap allows higher pressure therefore increasing boiling resistance of the coolant. Now...If you change your thermostat to lets say 150deg. Yeah the heater would be colder and you might even affect the way the computer fuels your engine and it takes into account the engine temperature in deciding what maps to use. I am not sure what temp the ECU needs to see before it goes to the normal (hot) fuel maps. As far as I have seen the WRX hasn't had any overheating problems with the stock cooling setup. Even with large flow restricting frontmounts in front of the radiator and high power levels. Jim |
| Thread Tools | |
| Display Modes | |
| is it possible to use the stock brakets and sliders to install aftermarket seats? | DiscoWagon | Newbies & FAQs | 2 | 04-08-2006 07:50 PM |
| Is it ok to over width your rim size .5" per tire rating? | RobSub | Newbies & FAQs | 14 | 08-23-2005 03:31 PM |
| Is it possible to heat wrap your stock uppipe? | blackie | Factory 2.0L Turbo Powertrain | 5 | 02-22-2005 07:52 PM |
| is it possible to reset ECU, wait week and if you get no codes pass OBD2 emisisons??? | Electronsmurf | Factory 2.0L Turbo Powertrain | 6 | 07-23-2003 12:05 AM |
| Is it possible to screw up your 2nd gear synchro... | latinskllz | Transmission (AT/MT) & Driveline | 8 | 03-03-2002 07:45 AM |
