Old 05-05-2012, 11:20 AM   #1
DDScooby
Member#: 161876
02 Impreza WRX
Default A/C condenser and component replacement question
Overhauling my A/C system here soon and I REALLY don't want to have drain the coolant and drop the radiator out. Can I just undo/remove the fans and top restraining brackets, pull it up a little and drop it between the sub-frame and belts? seems there is enough play in the top/bottom radiator hoses and clearance on either side of the subframe/belts to facilitate this attempt. (have a Mishimoto radiator installed)
DDScooby is offline   Reply With Quote
rim damage and tire replacement question reevs Newbies & FAQs 5 09-20-2011 05:14 PM
02 WRX brake and rotor replacement question jk147 Brakes, Steering & Suspension 2 09-23-2009 09:54 PM
brake pad and rotor replacement question Special_K Brakes, Steering & Suspension 2 08-04-2008 07:11 PM
At what mileage should I replace seals and components on a 2.5 RS engine? Space Boy Matt Service & Maintenance 6 12-20-2004 03:52 PM
Question about XTC baffles and components silvertoy Car Audio, Video & Security 8 11-15-2002 10:34 AM
