Old 05-06-2012, 02:41 AM   #1
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
Default 02 wrx a/c help
Went to lunch on wednesday and turned the a/c on and it started to blow out hot air. So i turned the a/c off let the car warm up and tried it again, same thing hot air. I checked the fuses, and they are still good. I'm not sure if it needs to be recharged or if the a/c compressor is bad. I don't hear it kick on when i turn the a/c on and i have no idea what it could be. Anyone with this problem and solutions will be greatly appreiciated since its starting to warm up.
bigdanswrx is offline   Reply With Quote
Old 05-06-2012, 07:29 AM   #2
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
Let your a/c run while you check the compressor. If it doesn't kick in or tries to kick in and barely spinning than your compressor clutch may be out. I had this problem last month and had to replace it. GL
SilverBOXER4 is offline   Reply With Quote
Old 05-06-2012, 03:21 PM   #3
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
how much did it cost to replace the compressor clutch? how long should i let it run for?
Old 05-06-2012, 03:28 PM   #4
kakdaman
Member#: 245117
2005 wrx
aspen white
Got to a shop and do a pressure test, if that fails they'll do a leak test. I thought my a/c was shot, turns out it it was just a bad o-ring and needed a recharge.
kakdaman is offline   Reply With Quote
Old 05-06-2012, 03:39 PM   #5
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
alright i'll find a shop and have to let them try that. thanks for the help guys. i was pretty much clueless about what to do i was even considering going to the dealer and i know they would of screwed me on prices and probably would of told me i need this and that. thanks again for the input greatly appreciated
Old 05-06-2012, 05:49 PM   #6
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
You're just checking to see if the compressor is spinning while your a/c is on. If its not than its out. Even if your o-ring is bad your compressor should still run. As for replacing the a/c clutch you won't be able to replace it. You will have to replace the whole compressor. Luckily I found a used compressor on eBay with only 30k miles on it for 75$ shipped.
Old 05-07-2012, 02:25 AM   #7
FNHP35
Member#: 220038
2006 Legacy GT Wagon
2005 STi
If I remember correctly, the compressor has a self protection switch that will keep it from running without refrigerant since if it does it burn itself up. If you do have a leak, the compressor will not turn on or turn on only for a very short time and then cut out.
FNHP35 is offline   Reply With Quote
Old 05-07-2012, 04:07 PM   #8
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
I let the car run with the a/c on but i don't hear the compressor kick on at all. I let it run for a couple of mins to see if it would kick on or anything but never did. I'm going to get a pressure test and a leak test done today to see if that's the problem. I will let y'all know what happens. Thanks again for the help.
Old 05-16-2012, 08:51 PM   #9
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
Well i got the pressure test and leak test done today. and come to find out i have a leak. The mechanic filled it with refrigent and uv dye and ran the car for about 30 min and couldnt find the leak. I got to my cousin's house and walked by the car and heard a hissing nosie like something was leaking. looked around and found out where the leak is at. The condenser has a leak on the top left hand side right behind the radiator. Is there a way i can get the condeser fixed or would i need to buy a new one?
Old 05-16-2012, 09:19 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
The odds of you finding a welder ballsy enough to weld your condensor is g_64:1. You will likely have to buy a new one and they are PRICEY, so try your damndest to get a used one. I got a used one from an STI for like a hundo and new I think they are like tree fiddy.
Old 05-16-2012, 09:45 PM   #11
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
i looked at autozone and they have one that is like $155. What year models wrx/sti can i use that will fit for a 02 wrx?
Old 05-18-2012, 03:53 AM   #12
westsideguy
Member#: 319112
Yea it sounds like you probably hit something while driving and ruptured a fin in the condensor. I would look around online for a condensor rather than going straight to autozone unless it doesn't really matter to you. I put-in on google for an 02 wrx condensor and got this on one of the first search listings-http://www.genesisautoparts.com/product/con22017Xc0407a.htm Seems pretty decent at face value. I'm pretty sure subie has been using integral reciever driers on the condensors for a while and that one would fit you. I would shop around of course cause i'm sure theres a better offer somewhere than my first 5 second search on google Good luck my friend
westsideguy is offline   Reply With Quote
Old 05-25-2012, 12:15 AM   #13
bigdanswrx
Member#: 309819
2002 wrx
platinum sliver
thanks for the help guys. been a big help. i found out that it is not my condenser but the reciever drier has a pin hole leak. I remember that the original owner of the car said that he had not into a front end collision and "5 mph" and the reciever drier is pushed up against the radiator so i guess over time it made a pin hole leak. Is there a easy way of just changing out that one part or would it be best to get a new condesner? I check the the condenser and seems to be no damage execpt for it being pushed up against the radiator.
Old 05-27-2012, 09:37 AM   #14
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Early 2002's don't have a replaceable drier. It's part of the condenser.
Better check your production date before running out and buying anything lol
NitroTrike is offline   Reply With Quote
Old 05-31-2012, 08:07 PM   #15
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
Yes sir, I had the exact same symptoms as the OP, and it turned out I was all out of refrigerant.
bomber991 is offline   Reply With Quote
02 WRX, need your help choosing FMIC Joey B Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-05-2005 11:06 PM
02 WRX wagon strut help? LSR Newbies & FAQs 0 09-04-2004 11:57 PM
working on changing 02 wrx clutch need help!!!! compton Transmission (AT/MT) & Driveline 4 10-27-2003 09:15 AM
04 STI spoiler -> 02 WRX undrilled trunk help needed LDragon Interior & Exterior Modification 7 07-08-2003 09:57 PM
02 wrx exhaust ( help ) wrxmadness Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-03-2001 12:19 AM
