#1 |
Member#: 319087
Hey I'm new to the forums but I am not new to cars, I have 184k miles on my 2004 wrx, mostly highway and I am currently running 10w-30 gtx with decent amount of oil burn off. I can not give an exact oil burn off because of varying driving habits. I changed my oil at 1500 miles and it pours out like water! Kinda scary. but would it be safe to switch to rotella t6 with all the good reviews
#2 | |
Member#: 767
Vehicle:04 FXT |
2. Yes switching to RT6 is fine -Dennis |
#3 |
Member#: 257818
SWIC
Vehicle:2007 STi CGM |
Fill out your profile man, up until reading your post again I thought you had an '83 Olds Delta 88
![]() T6 rotella is good stuff |
#4 |
Member#: 280943
Vehicle:'11 WRX |
OP, after you make your switch please report back on the status of your oil consumption. I'm curious if the RT6 helps
#5 |
Member#: 318956
I'm at the store now so rt6 is only in 5-40?
#6 |
Member#: 317760
yup 5w-40 only, as far as I am aware
#7 |
Member#: 318956
Kool beans.. Good luck op
#8 |
Member#: 156128
Vehicle:2011 WRX da ba dee da ba dye |
Another vote for T6, it's good stuff. I use it in my motorcycle, too!
#9 |
Member#: 319087
Ok sweet guys thank you, I will pick up my oil and filter tomorrow. And yes yes off to fill out my profile lol. Thank you again and I will report back with oil consumption results.
#10 |
Member#: 41762
International
Vehicle:04 STi CT-DE-FL rinse+repeat |
Hit up Walmart for a gallon jug (or two)
I've found it's usually $21'ish there as opposed to $26'ish at Autozone. |
#11 |
Member#: 267339
BAIC
Vehicle:2002 Impreza WRX MBP |
My '02 loves it (91K mi.) - zero loss in 3200 miles this OCI and still looks golden on the 'stick.
Nor Cal Autozone has T6 on sale now for $4 off (so 22.99 or 23.99/gall.) but don't sell quarts - just FYI if AZ is closer to you than Wallymart |
#12 |
Member#: 67956
Vehicle:2007 WRX Wagon Silver |
I'm running it in my 90 plow jeep with 200k plus mile, no leaks & running great
#13 |
Member#: 319087
Ok guys thank you for the great knowledge, I changed the oil last night and of course forgot to grease my UOA bottle as I took the plug out but there no need to know if I'm not using gtx any more, will keep checking oil every 200 miles and post back
#14 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
mmmmmm....if it had been ME.....i woulda got some of the 10w30 valvoline max life and used that for a change or 2 at 3k miles/per.....then went to the t6
but that's just me ![]() Last edited by Uncle Scotty; 05-18-2012 at 02:38 AM. |
#15 | |
Member#: 767
Vehicle:04 FXT |
![]() -Dennis |
#16 |
Member#: 319087
#17 |
Member#: 320155
#18 | |
Member#: 267339
BAIC
#19 |
Member#: 319087
Rotella for the win!!!!!!!!!! With 1076 miles and I don't burn any on my trip that made up the last 640 miles considering I was cruising at 80 which is about 3000-3250rpm for 4 hrs straight, this oil works AWESOME!!!!!!!!
| Thread Tools | |
| Display Modes | |
| Rotella T6! +1 | Flyin_Hayn | Car Part Reviews | 17 | 08-26-2011 02:15 PM |
| Just switched to Rotella T6... | artemis53 | Newbies & FAQs | 16 | 11-20-2010 08:58 PM |
| New Shell Rotella T6 5W40 | bzbuzz | Service & Maintenance | 27 | 07-23-2010 03:22 AM |
| FYI: Shell Rotella T6 Rebate | BadTrainDriver | Service & Maintenance | 0 | 05-26-2010 10:22 PM |
| Rotella T6, subaru approved? | sonyminidiscman | Service & Maintenance | 16 | 04-05-2010 04:53 PM |
