Old 05-06-2012, 11:16 PM   #1
Decade
Member#: 285526
2012 WRX 5-door
ISM
Default Help with 2012 WRX front bumper
I took my bumper off without any issues today to paint the headlights black. So when putting everything together again all looks fine except on both sides right below the headlights' corners near the fender won't line up flush. When i look at the tabs the very top is pushed up against the actual body unlike all the others. Not sure if I just didn't notice this before taking it off or if the top one is supposed to be the hardest to snap back in and so this is normal? Everything aligns perfectly expect for the two corners on both sides, anyone have suggestions? I tried putting in a flat head to bring the tab lower but it goes right back into place. I even tried applying a little more pressure to see if it would snap back in but it won't.
Decade is offline   Reply With Quote
Old 05-07-2012, 07:14 AM   #2
Decade
Member#: 285526
2012 WRX 5-door
ISM
No ideas
Old 05-07-2012, 07:57 AM   #3
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
Pictures would help. Probably just need to use some force.
Ethan_Drift is offline   Reply With Quote
Old 05-07-2012, 09:06 AM   #4
Decade
Member#: 285526
2012 WRX 5-door
ISM
pics would be later tonight. I applied a lot of force and it would't go. Whats weird is I must be doing something wrong snapping it back in since both sides are doing it. Does the top tab right below the headlight corners usually take some pushing? The rest locked in with almost no effort.
Old 05-07-2012, 12:08 PM   #5
Decade
Member#: 285526
2012 WRX 5-door
ISM
Any other suggestions if this is normal? It's driving me crazy.
Old 05-07-2012, 12:14 PM   #6
ofspunk7
Member#: 249401
2005 LGT and 91 MX5
Is your fender liner on the bottom flush? It makes we think that maybe something is lined up wrong... or overlapping incorrectly. Also, could it be from the headlights being tweaked wrong? Did you check to make sure they are flush?
I have removed the front and rear bumper a ton on my 2009. It usually takes a bit of flex in the bumper, a little pull and push... but it always snaps into place.
ofspunk7 is offline   Reply With Quote
Old 05-07-2012, 12:17 PM   #7
Decade
Member#: 285526
2012 WRX 5-door
ISM
Thanks for the response. Once I am off I will take it back off but what looks off to be is the one tab where its not connecting sits much higher compared to the levels of the other. Do you know if the tabs that hook into the bumper are all supposed to be at the same level or is it normal for the top one to be higher up making it more difficult to hook into?
Everything besides those corners on both sides lined up perfectly as far as I can tell.
Old 05-07-2012, 01:55 PM   #8
Decade
Member#: 285526
2012 WRX 5-door
ISM
I am wondering if I should take it to the dealer since i've only had it 2 weeks or if i should go home and take the bumper off again to try and see if I can fix it.
Old 05-07-2012, 02:14 PM   #9
olazy
Member#: 263322
2011 WRX Limited
WRBP
i'm sure you just have something misaligned. i would give it another try before admitting defeat. and as stated above pics would help us help you better.
olazy is offline   Reply With Quote
Old 05-07-2012, 02:53 PM   #10
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
I think YouTube has a video on this. Might want to check it out. Good luck, hope you can realign it back.
SilverBOXER4 is offline   Reply With Quote
Old 05-07-2012, 02:57 PM   #11
Decade
Member#: 285526
2012 WRX 5-door
ISM
Thanks to both of you also. I think the youtube video is for removing the bumper only. I actually used it to remove mine ha. I have looked for a video for putting it back on but no luck. Could it really be an alignment issue even though the other parts line up perfect?
Old 05-07-2012, 03:10 PM   #12
Decade
Member#: 285526
2012 WRX 5-door
ISM
I just got a message from the person who helped me with the headlights and he mentioned that one bolt can cause that last tab to come up to high and it sounds like this is the issue I am having! Excited to get home and loosen that bolt up to see if my issue is done with. Thanks all! And Corey
Old 05-07-2012, 04:00 PM   #13
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Anytime! I look forward to see pics
ocdpvw is offline   Reply With Quote
Old 05-07-2012, 06:26 PM   #14
Decade
Member#: 285526
2012 WRX 5-door
ISM
I hope these pics work, loosening the bolt didnt work
Pics arent working, I have nothing to source them to. Any suggestions on how to let them be seen?
Old 05-07-2012, 06:34 PM   #15
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
upload them to tinypic.com
Danny5 is offline   Reply With Quote
Old 05-07-2012, 07:02 PM   #16
Decade
Member#: 285526
2012 WRX 5-door
ISM
see how close that top hook is? Going to take pic of the bumper on to see if the gap is normal or not
Old 05-07-2012, 07:10 PM   #17
Decade
Member#: 285526
2012 WRX 5-door
ISM
Here is what both sides look like with bumper on:
Old 05-07-2012, 08:24 PM   #18
Decade
Member#: 285526
2012 WRX 5-door
ISM
So does that look normal? I just took everything apart again and am still having the same issue.
If I take it to the dealer does anyone think they will fix with no cost? I looked and everything looks like it is where it is supposed to be so it's not like anything is bent or broke. I am just wondering if they would charge me since I took it off?
Old 05-08-2012, 09:56 AM   #19
Decade
Member#: 285526
2012 WRX 5-door
ISM
Does anyone have a close up of this section of their own car they can put up so I can compare? I would really appreciate it. It's looking like I will have to take it to the dealer to get it aligned correctly bc I cannot see anything off and everything else lined up.
Old 05-08-2012, 10:55 AM   #20
olazy
Member#: 263322
2011 WRX Limited
WRBP
come to think of it, i also have a gap in the same area, not as bad as yours but still annoying. haven't really had a chance to mess with it so curious to find out what's the fix. are the holes on the bumper clipping into this clips shown in this pic (to the right of the bolt)?
Old 05-08-2012, 11:02 AM   #21
Decade
Member#: 285526
2012 WRX 5-door
ISM
That clip that sits so high the bumper is not clicking to. The bumper even has a lip on this clips hole that makes me think the lip is there to help push that clip down and make it go into the bumper but it wont. I just made an apt with the dealer for saturday to see if they can fix. I dont think its normal. I just never noticed it before getting ready to remove the bumper and thought nothing of it since I figured I could correct it when putting it all back on but still wouldnt correct. Bothers me
Old 05-08-2012, 03:52 PM   #22
jdny769
Member#: 313725
2012 WRX
That gap looks perfectly normal im comparing it to my 2012 and i dont see any differance.
jdny769 is offline   Reply With Quote
Old 05-08-2012, 04:04 PM   #23
Decade
Member#: 285526
2012 WRX 5-door
ISM
Aww man really thats kinda sad. I couldnt swore there was little to no gap on the other pics i've seen. Maybe its the angles though.
Old 05-08-2012, 04:17 PM   #24
jdny769
Member#: 313725
2012 WRX
angles and distance will cause it to look differant. I just google image this and you can see the gap is pretty much spot on.
http://www.google.com/imgres?q=2012+...52&tx=67&ty=76
Old 05-08-2012, 04:31 PM   #25
Decade
Member#: 285526
2012 WRX 5-door
ISM
From that picture I thin the gap leading up to the top near the headlight looks good but right below the headlight looks much worse on mine. Judging by the pic of course. This sucks
WTB : 2011/2012 WRX Front bumper / Tow hook cover jrose29 Private 'Wanted' Classifieds 2 01-06-2013 10:40 AM
2012 WRX Front end for 2008 - 2010 Front Isoh SCIC Private Classifieds 14 05-11-2012 07:04 PM
WTT: white STi front bumper *for* WRX front bumper Phil Jr. Tri-State Area Forum 7 08-02-2005 03:39 PM
WTT: white STi front bumper *for* WRX front bumper Phil Jr. Private 'Wanted' Classifieds 1 08-02-2005 03:06 PM
Help with WRX front bumper reddog15 Interior & Exterior Modification 10 07-17-2002 10:55 PM
