Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 05-07-2012, 10:37 AM   #1
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Default Might need a shop
I tried to change my mother's timing belt last night and had some real problems. It's a 2004 Outback with a 2.5 Sohc. I got everything lined up and running perfect. I went to go take if for a test drive and it died on the road. I think the timing belt slipped. I'm guessing the tensioner is bad.
I'm going to try and throw a new tensioner in it tonight and pray to god that the vavles are not bent.
In the case that this doesn't work, where is the cheapest place to get this fixed? The closer to West Valley the better.
Not-EWRX is offline   Reply With Quote
Old 05-07-2012, 10:45 AM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
When a timing belt is done all pulleys including the tensioner should be changed. When you were pressing in the the tensioner did you do it slowly or fast?
bhhamblin is offline   Reply With Quote
Old 05-07-2012, 11:24 AM   #3
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I probably did it too fast judging by the result. I don't think i'll ever do a timing belt with out all the pulleys and such.
Also, when I pulled her spark plugs, 3 out of 4 were full of oil.
Old 05-07-2012, 01:00 PM   #4
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Take it to solid if you can't DIY.
When mine gets to that point that is one job I'll pay to have done.
car_cursed is offline   Reply With Quote
Old 05-07-2012, 01:13 PM   #5
axleon2
Member#: 154117
2003 Forester
Yeah I hear those guys are pretty good.
axleon2 is offline   Reply With Quote
Old 05-07-2012, 02:06 PM   #6
Not-EWRX
Member#: 158043
2013 Wrx Hatch
If I got them the heads, could they repair the valves there or will they use someone else?
Old 05-07-2012, 10:55 PM   #7
Not-EWRX
Member#: 158043
2013 Wrx Hatch
So the valves are bent. I pulled the timing cover again and one of the cams was about 180 deg out of alignment. The other one was still in line. When I pulled the belt and spun the one cam there was noticeable noise, a squeaking and a tick. I put everything back together and started it but I ran horribly and I had to keep on the gas to keep it running.
Can anyone recommend a shop that specializes in heads? Will the pistons need to be resurfaced as well? I might just have to tow it to a shop and let them do it. Can anyone recommend someone for that. Bueller?
Old 05-07-2012, 11:30 PM   #8
axleon2
Member#: 154117
2003 Forester
Shoot me a text I know someone.
801-574-6223
Old 05-08-2012, 03:05 AM   #9
MarcosV
Member#: 274936
2000 2.5rs
rbp
if this is too much of a hassle for you, i will buy it for about 4k, text me at 801-896-1523
MarcosV is offline   Reply With Quote
Old 05-08-2012, 12:43 PM   #10
Momosaurus WRX
Member#: 214737
Take the heads to metric motors. They charge $175 for a full rebuild per head. I just took them 7 heads to have them redo lol.
Momosaurus WRX is offline   Reply With Quote
Old 05-08-2012, 01:06 PM   #11
Not-EWRX
Member#: 158043
2013 Wrx Hatch
ha, well they should have pleanty of practice then:P
Do you think the pistons will be damaged?
Old 05-10-2012, 08:19 PM   #12
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Does anyone know if heads off a SOHC 2000 impreza will fit on an 2004 Outback.
Need help quick, Might need to return order! akballow Interior & Exterior Modification 3 11-22-2011 10:01 AM
Exhaust shops in CO: might need custom piping Dolphin Overton Rocky Mountains Impreza Club Forum -- RMIC 8 11-05-2003 06:32 PM
might need a lawyer Herbie Southern California Impreza Club Forum -- SCIC 3 11-04-2000 01:07 AM
might need to buy new rims...help? Keirik General Forum Archive 9 10-02-2000 07:32 AM
Anyone going to T-Hill? An instructor might need a ride. Joel Gat, 1.8L Southern California Impreza Club Forum -- SCIC 2 09-26-2000 07:48 AM
