Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-03-2011, 03:29 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default power steering
I will post this in the RMIC first. This is a real thread with real problems. They story is real as far as I can convey it properly with my limited vocabulary and education.
I replaced my PS pump before SEMA a couple years ago because it was starting to make noise and I didn't want it to get to Vegas and have it fail, considering the cost of a new pump.
About 2 months ago I would get intermittent loss of PS when turning, to the point of the steering wheel almost jerking out of my hand. One hand on the steering wheel and the other getting ready to shift coming out of a corner.
I pulled over and there is a considerable amount of air bubbles in my reservoir. I put hose clamps on all the rubber hoses thinking maybe it was sucking air on the vacuum side or something like that. The problem is getting considerably worse, what use to only happen once or twice in the first couple months now happens when ever I want.
There aren't any leaks anywhere and I check it every time I drive it. I am about to spend money and replace the low pressure hose and the pump again but thought I would ask around and see if I have missed anything.
Help me not spend my turbo money again fixing my car and help me solve my problem.
and for those of you who can't read.
medamullet is offline   Reply With Quote
Old 02-03-2011, 05:55 PM   #2
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
a common problem is the washers on the hard lines. i hardly turned one of the bolts once, literally 1/4 turn, then back tight again. and that made them suck in air. once those washers were replaced and the system rebled, it worked fine again.
PCSkiBum_21 is offline   Reply With Quote
Old 02-03-2011, 06:02 PM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I will buy new crush washers and rebleed. Since the pump doesn't make niose I assume the pump isn't going out. I will buy a new low pressure feed hose and replace that as well. I wanted to change that hose when I replaced my pump becuase it was hard as rock, but had to order it and I didn't have the time.
Old 02-03-2011, 11:26 PM   #4
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Is it bad if all i did was look at the picture?
907Bum is offline   Reply With Quote
Old 02-04-2011, 12:51 AM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
lol, jesse not at all
ok so I tightened everything, checked my headlight fluid, tightened my license plate frame. cleand my windshield. We shall see if the problem has gone away. I drove it to the gym after words and it seems ok. Only time will tell.
Old 02-04-2011, 09:53 AM   #6
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
So did the headlight fluid have a direct impact on the P.S. pump? I knew it was somethin crazy like that!
06HAWKMAN is offline   Reply With Quote
Old 02-04-2011, 11:24 AM   #7
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
back to the drawing board. I got to work and it started doing it again. I assumed the low fluid in my right light would have caused it. I was wrong.
NEED MORE HELP.
Old 02-04-2011, 01:06 PM   #8
CBR954
Member#: 250132
2008 WRX Silver
This makes me not want to let you tune me>
CBR954 is offline   Reply With Quote
Old 02-04-2011, 01:13 PM   #9
phattydrummer
Member#: 183070
2003 WRX
True Blue
Bring it by the shop! I have an install and Jesse has a tune later on Saturday. Ill be there from 9am to about 4pm. We can try manually bleeding it with the tires off the ground and check for leaks of any kind to make it easier. If the pump isn't growling then its a pressure issue (obviously). It has sometimes taken me hours and hours to bleed power steering fluid after pump, rack, and bushing installs. Its worth a try, right?!
phattydrummer is offline   Reply With Quote
Old 02-04-2011, 03:09 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I just ordered new rubber hoses, I will wait until they show replace both the return hose and the feed hose, new fluid and bleed it again. If it doesn't work I will go to plan B. It sucks air from somewhere that's for sure.
The weird thing is the bubbles are super super tiny. I assume that the hole is small enough to let air in when under high rev's but no big enough to leak from just sitting.
I might order a water pump, stat and do a bunch of maint stuff all at the same time.
I will let you know next week and might bring it over to the shop then.
Old 02-04-2011, 03:25 PM   #11
AwkWarD
Member#: 196530
98 BMW M3
Check it yo'
http://www.rallysportdirect.com/Gate...2-2011-WRX-STI
AwkWarD is offline   Reply With Quote
Old 02-04-2011, 04:19 PM   #12
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
nice, now I have to figure out how to cancel my OEM 1
Old 02-08-2011, 12:28 PM   #13
wrxkyle
Member#: 199635
02-4 rSTI
pm'd, there's a thead that helped me with this, it's very likely the oring that seals the return hose connection. unscrew that plastic/metal piece and take a look, it should be round (duh) but when i pulled mine it had degraded to a square cross section and was hard as a rock.
also the return lines do get brittle and though not enough to leak out fluid they do leak in air. with just replacing the clamps many people fix the problem.
on a side note the 20g-xt is in, and five0 will be getting a call from me today about their 1200cc sidefeeds corn juice is just around the corner
wrxkyle is offline   Reply With Quote
Old 02-08-2011, 03:43 PM   #14
wantsti
Member#: 134764
04 sti
java black pearl
http://forums.nasioc.com/forums/show....php?t=1897783
I had the jerkyness problem when I would do back to back runs when auto x ing. I switched the fluid to a high quality atf and problem when away.
but it sounds like the O ring replacement might be for you.
wantsti is offline   Reply With Quote
Old 02-09-2011, 10:19 AM   #15
inthenameofweez
Member#: 201374
2004 Broken down
slow ass wagon
I was also about to suggest the top o-ring. I had exact same symptoms. O-ring fixed me! Just be sure to get the right size by either Getting it from the dealer or taking the old one to Checker with you. They've got a great selection of individual o-rings.
inthenameofweez is offline   Reply With Quote
Old 05-04-2012, 04:23 AM   #16
Mush04
Member#: 191705
2007 Limited STi
Swp
Ok so I had my car parked for almost a week, pulled it out if the garage today to wash it and noticed my steering making noise, it goes faster when rev'd up which makes me think the pulley?.......but also get the whole intermittent power and I believe the bottle has bubbles as well........should I replace the pulley and try the o-ring +hoses? Would like to get this fixed tomorrow so its not noisy for the meet sat. ALL HELP IS APPRECIATED!!!
Mush04 is offline   Reply With Quote
Old 05-04-2012, 01:52 PM   #17
Mush04
Member#: 191705
2007 Limited STi
Swp
Ok so I just went out and played with it for a few mins, and am pretty sure it's the pump
my next question would be how difficult is it to swap them out? is it pretty easy to drain the old fluid?
Old 05-07-2012, 06:18 PM   #18
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
jon don't do the pump first. get some hose clamps and replace all those pinch crap ones. If that doesn't clear it up. Buy new hoses, I am sure yours are old and hard as a rock (TWSS) THEN if it still makes noise replace the pump.
You will still use your new hoses and clamps. but hoses and clamps = $60 an da pump =$260
Old 05-08-2012, 11:17 PM   #19
Mush04
Member#: 191705
2007 Limited STi
Swp
Thanks Jason I actually tried the O-ring thing first and that worked like a charm! the stealership wants 460 ish or something I think haha at least that's what I thought I heard.
Steering wheel hard to turn at idle - powers steering pump? thrdeye South East Region Forum 23 12-15-2008 09:07 AM
Power steering noise but maybe not the power steering pump.....? deathskrye Brakes, Steering & Suspension 5 08-29-2008 10:56 PM
Steering Issue, Power Steering BAD?? Boosted1456 Service & Maintenance 4 10-11-2007 09:44 PM
Power Steering Fluid / Steering Shimmy + Noise Altaic Brakes, Steering & Suspension 4 04-24-2006 12:59 AM
Adjusting steering wheel and Power STeering noises FatCatTurbo Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-06-2003 09:33 AM
