Old 10-24-2011, 08:30 PM   #1
Strainjah
Member#: 291262
2011 Sti Hatch
Plasma Blue Pearl
Default 2011 exhaust tip finishers
Has anyone paint matched the exhaust tip finishers? Any pics out there. I don't like the silver and am debating changes. Carbon fiber, black, or paint match? Thanks!!
Strainjah is offline   Reply With Quote
Old 10-24-2011, 08:31 PM   #2
Strainjah
Member#: 291262
2011 Sti Hatch
Plasma Blue Pearl
Omit the word "tip"
Old 10-24-2011, 08:35 PM   #3
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Painted mine to match WRB. I also have the BaysonR R205 replica diffuser in case anyone asks.
atf78 is offline   Reply With Quote
Old 10-24-2011, 08:38 PM   #4
Strainjah
Member#: 291262
2011 Sti Hatch
Plasma Blue Pearl
Did you paint them yourself? If so can you explain the process. I have a PBP Sti Hatch. I like how that looks...nice car.
Old 10-24-2011, 08:45 PM   #5
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
I did paint them myself using Grimmspeed's WRB spray paint. I sprayed 2 coats of primer, 3 coats of WRB paint, and 3 coats of clear coat. I also replaced the included nuts and bolts with black hardware.
If you're not comfortable painting them yourselves, a shop shouldn't charge too much to paint them.
Old 10-24-2011, 08:52 PM   #6
Strainjah
Member#: 291262
2011 Sti Hatch
Plasma Blue Pearl
Thanks for the info. I will probably look into a shop as I am not comfortable doing it myself.
Old 01-21-2013, 05:40 PM   #7
DDabs
Member#: 339686
2013 WRX Sedan
Which screw on the passenger side finisher is a fake? I know it only uses 3 out of 4 to screw in, just wondering which is the fake.
DDabs is offline   Reply With Quote
Old 01-21-2013, 06:44 PM   #8
Shohin
Member#: 170188
2016 STI Limited
The bottom screws on the inside of the finisher (towards the centerline of the car) are there purely for aesthetics and don't serve a functional purpose.
For another take, I plast-dip'd mine, leaving the hardware silver:
Shohin is offline   Reply With Quote
Old 01-21-2013, 06:58 PM   #9
DDabs
Member#: 339686
2013 WRX Sedan
Thanks Shohin, excellent photo. I'm basically trying to figure out if the finisher itself is going to cover up my singed bumper from my Invidia exhaust. I think I'll be able to hide the burnt plastic.
Old 01-21-2013, 08:06 PM   #10
LUMBERZACK
Member#: 340009
2007 STi
48W
I always hated those finishers and thought they were tacky, but boy they look magnificent when matched with WRB
LUMBERZACK is offline   Reply With Quote
Old 01-21-2013, 09:44 PM   #11
DDabs
Member#: 339686
2013 WRX Sedan
I don't think they're tacky if they functionally protect my bumper from melting...
Old 01-22-2013, 02:20 AM   #12
Shohin
Member#: 170188
2016 STI Limited
I agree that the chrome/polised silver look is a bit gaudy, and personally I think the paint-matching draws even more attention to them. I'd just have removed them all together, but then there would be 6 holes in the bumper . . . so flat black was the most subtle option I guess. I'm going to leave the PD on there for a bit to make sure thats what I want, but I'm planning to permanently paint them at some point.
Old 01-23-2013, 03:34 PM   #13
thebanker
Breaker of Chins
Member#: 338070
2013 WRX Hatchback
2014 XV Crosstrek
Did you rough up the finishers and spray adhesion promoter on them, or did you just spray primer and paint?
thebanker is offline   Reply With Quote
Old 01-28-2013, 09:17 AM   #14
carsick30
Member#: 203475
'10 STi
Blue Mica
ok, so i'll ask the dumb question. the finishers are that much closer to the hot exhaust tips, wouldn't painting them / plastidipping them melt that paint/dip off from the exhaust heat? the supposed idea of those things is to do heat dissipation, but what's the point of painting if it will get warped/bubbled from all that heat? i only ask because i really like the matched look, but don't want to waste $ painting if it will just peel off in a couple of months.
carsick30 is offline   Reply With Quote
Old 01-28-2013, 10:01 AM   #15
garudatwo
Member#: 322385
I've plastidipped my stock exhaust tips, no bubbling after 5 months afaik.
garudatwo is offline   Reply With Quote
Old 01-28-2013, 10:11 AM   #16
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
I gave the finishers a light scuffing with sandpaper, not sure what grit. Than I cleaned them with rubbing alchohol and primed + painted + cleared.
Mine were on the car for almost a year before someone rear ended me, and when I took them off the paint looked as good as the day I installed them. I don't think the heat will have any affect on paint, not sure about plasti-dip but it should be fine also.
I decided not to reinstall them on the new bumper, still not sure if I will put them back on.
Old 01-28-2013, 12:53 PM   #17
thebanker
Breaker of Chins
Member#: 338070
2013 WRX Hatchback
2014 XV Crosstrek
I'd like to see some pics of these on a DGM hatchback. I'm going back and forth as to whether or not I really like them.
Old 01-28-2013, 07:06 PM   #18
DDabs
Member#: 339686
2013 WRX Sedan
Just installed mine today to hide my bumper burns.
-David
Old 01-28-2013, 09:18 PM   #19
intense98rt
Member#: 309124
12 wrx
Looks good black but I don't like seeing the hardware. It would be nice if they would attach on the inside.
intense98rt is offline   Reply With Quote
Old 01-29-2013, 04:56 PM   #20
carsick30
Member#: 203475
'10 STi
Blue Mica
Mine came with these thin black rubber guards running along the entire edge. Did you take yours off? I don't think I see them in the pic. I'm having my shop color match mine and the guy says they would have to take those rubber guards off to avoid paint peel. May not be able to get them back on. If your guards are off, are you seeing any wear between the metal edge and the bumper from vibrations/rubbing? I like to ask OCD questions.
Old 05-26-2016, 02:58 PM   #21
Subareese
Member#: 21124
2012 WRX
World Rally Blue Pearl
Great job! This will be my first mod to my new (to me) 2012 WRX Hatchback. Thanks for the info and pics!
Subareese is offline   Reply With Quote
Old 05-28-2016, 12:16 PM   #22
boostedbugeye02
Member#: 447507
I love the look of this!
boostedbugeye02 is offline   Reply With Quote
STI Exhaust Tip Finisher (08-10) $ickSTI Exterior/Styling 3 04-16-2012 08:04 AM
is my exhaust tip finish f@#$ed? dLo R6 Car Care & Detailing 70 05-31-2011 01:43 PM
FS : STi Exhaust Tip Finisher 2008-2011 nethngbtstk Exterior/Styling 5 12-12-2010 06:04 PM
does anyone have the exhaust tip finishers on their 08 STi? zmw Texas Impreza Club Forum -- TXIC 6 07-01-2009 08:12 PM
is my exhaust tip finish f@#$ed? dLo R6 Car Care & Detailing 4 03-13-2009 04:11 PM
