Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 05-09-2012, 12:34 AM   #1
Wagun
Member#: 106433
2004 WRX wagon
Default Hybrid - new pistons vs. machining heads
Anyone tried these pistons http://www.ebay.com/itm/ws/eBayISAPI...tchlink:top:en
vs. machining the 2.0 heads? It seems to me to be a better alternative to machining the heads since these pistons will be stronger than stock.
Wagun is offline   Reply With Quote
Old 05-09-2012, 02:23 PM   #2
Wagun
Member#: 106433
2004 WRX wagon
Bump, no one has tried these pistons instead of sending their heads to EqTuning and waiting 3 months?!?!?!
Old 05-09-2012, 03:45 PM   #3
RexWagonWA
Member#: 221945
Default Pistons vs. Heads
My hybrid has both. My pistons may be slightly different, but they are the JE pistons made for hybrids.
The head machining works well. It allows you better flow and cuts down on detonation hot spots. The are lots of hybrid Subarus without machining in the Pacific Northwest that need frequent rebuilds. My motto is do it right the first time. Avoid multiple rebuilds, as that gets expensive.
The folks at AndrewTech are getting good results without machining. I do not know what they are doing. But we have no idea if you are near Maryland.
GLWYB
RexWagonWA is online now   Reply With Quote
Old 05-09-2012, 06:21 PM   #4
Wagun
Member#: 106433
2004 WRX wagon
Thanks!
Old 05-10-2012, 12:01 PM   #5
Wagun
Member#: 106433
2004 WRX wagon
GLWYB
Wouldn't doing both lower the static CR to lower than an STi? Not to mention making a hybrid build more expensive.....
Old 05-10-2012, 02:43 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^And kinda defeats the purpose of getting these pistons in the first place
Old 05-10-2012, 04:08 PM   #7
TechMJ
Member#: 145804
2002 Bugeye Beast,
Murdered Out,2.5,6spd,20G
I'm doing a hybrid build on my 02 REX and I did a lot of research on this subject and yes I agree on doing it right the first time. My heads are at ASF Machine getting the chambers matched to my 2.5 block. The Block was built by S&R Performance with CP Pistons. My turbo is a custom built 18G by TurboChargers.com and I will be running Crower 264 Cams. The goal is not to have the highest WHP I can get but to have a reliable fun street car does what I want it to do. I will be starting a Build Thread soon to cover all that I have done and more on what a good build is all about.
TechMJ is offline   Reply With Quote
Old 05-10-2012, 04:08 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
you can machine the head to bring the combustion chamber out like the 257 or simply flare out the sides to allow better airflow and reduce the sharp edge hanging in the chamber
FuJi K is online now   Reply With Quote
Old 05-10-2012, 04:28 PM   #9
wrxhard
Member#: 108091
can you elaborate on this or possibly show some pics on what you mean here?
wrxhard is online now   Reply With Quote
Old 05-10-2012, 04:46 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
flare it out! EJ205 head
reduce over hands in the chambers. stock EJ205 head on a 2.5L block
stock 257 chamber on 2.5L block
Old 05-10-2012, 06:32 PM   #11
Wagun
Member#: 106433
2004 WRX wagon
I see no difference in the amount of material "overhang" on the sides with the 205 heads and the amount of overhang present with both 205 and 257 heads at the top and bottom of the chambers. If JE pistons are designed to compensate for the extra material using the 205 heads and bring the CR back to 8.5:1, then why do the machining?
Seems the only benefit would be to "unshroud" the valves for a little more flow.
Anyone have any flow bench data on the benefits of unshrouding the valves?
FYI, I exchanged emails with the folks at AndrewTech: they don't use special pistons and they don't machine the chambers, so how come they don't have a lot of engine failures? I suspect because they do proper engine tuning right after the install.
Old 05-10-2012, 08:28 PM   #12
luciferMotorCade
Member#: 253611
2004 GeNOME
ARE YOU BLIND!?
luciferMotorCade is offline   Reply With Quote
Old 05-10-2012, 08:58 PM   #13
TechMJ
Member#: 145804
2002 Bugeye Beast,
What he said!
Old 05-10-2012, 08:59 PM   #14
TechMJ
Member#: 145804
2002 Bugeye Beast,
Originally Posted by TechMJ
What he said!
Are you Blind? LoL
Old 05-10-2012, 09:00 PM   #15
TechMJ
Member#: 145804
2002 Bugeye Beast,
You can plainly see the differences in the pics posted by FuJi K
Old 05-10-2012, 09:03 PM   #16
kurion
Member#: 75543
05 05 WRX 4eat
PSM 2.5 35R
I'm just going to post my own experience regarding "hybrids". The bottomline is that no they won't blow up if you don't get the heads machined etc.
Cliff Notes - If your Tuner doesn't suck and isn't lazy, your hybrid shouldn't blow up.
The only thing that will make a difference is the tune that you put on the hybrid motor. I've run my hybrid motor for 60K miles using everything from a gt52 to a 35R.
My personal opinion is as follows:
1) hybrids have a higher compression ratio - which means you probably shouldn't run as much timing if you want your motor to last
2) With the higher compression ratio, you probably can't run as much boost - but for most people they are already octane limited by 93 pump
3) So assuming you run a bit less timing a couple less pounds of boost, you will probably make a bit less power. BUT
4) People want MOAR power! - so either they a) tell their tuner "I want dyno numbers" or b) their tuner is lazy doesn't feel like changing their tunes and maps, doesn't really compensate for the higher compression etc and gives them a tune that on the road will detonate more - and then bye bye motor
5) does chamber matching make more power? probably - can't hurt - could it be "safer" - maybe
6) I've gone to multiple tuners over the years and ONLY 1 tuner harped about getting the heads machined - and his tune was by far the worst tune - (damn car misfired on the way home from the tune..) coincidence? perhaps, but bottomline my motor is still together after 60K miles (using a different tuner of course)
kurion is offline   Reply With Quote
EQ Hybrid Engine Comparison - CNC Combustion Chamber vs. Thicker Head Gasket Equilibrium Tuning Proven Power Bragging 83 11-14-2010 11:48 AM
Hybrid Build VS Built Heads warex06 Built Motor Discussion 7 06-09-2010 05:21 PM
Two new pistons and a head rebuild. Jays04WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-11-2009 01:32 PM
07sti= new piston vs. new shortblock jconaty07 Warranty Issues & SOA Problems 10 04-18-2009 12:34 PM
Mahle 100mm EJ25 pistons - brand new - also USDM STI new pistons cheap! engineerx Engine/Power/Exhaust 23 11-04-2007 01:20 AM
