Mid Atlantic Impreza Club
Closed Thread
Old 02-26-2013, 08:56 AM   #4276
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Originally Posted by spintheground View Post
Now the new OBDIII system is WiFi enabled and the DMV is going to have hotspots so it can sync with your car and read any CEL's and send you a ticket in the mail. That's nuts!
That is nuts! I'm sure that OBD III will also report how much time you spent over the speed limit or any other slightly fun thing you might have tried to do with your car. I've got a feeling that if I ever get a car with OBD III, something will probably happen to the Wi-Fi antenna.
This is just an extension of vehicle inspections as another way for the state to make some money and pretend that they are keeping everyone safe.
ThatGy is offline
Old 02-26-2013, 08:59 AM   #4277
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
I can't find the orginal source.. I read it a couple years ago but ala google:
http://lewrockwell.com/peters-e/peters-e144.html
I believe BMW is using it so the car can make an appointment for routine maintence with the dealership automaticly.
Edit:
More info
http://lobby.la.psu.edu/_107th/093_O..._questions.htm
spintheground is offline
Old 02-26-2013, 09:18 AM   #4278
prescottn6ft7
Member#: 268918
2004 STi
Originally Posted by HinshawWRX View Post
Speaking of cars, I need to either rebuild or replace my steering pump.
If whoever you decide to get a pump from doesn't have any rebuilt in stock, and you need a pump to send off I have one you can use as a core then just give me your bad one. No down time waiting on the new part.
When mine went on my WRX I found one on here for like $50 and did the same. So now I always have one at the house.
Not sure if you've read what all it entails to rebuild them, but it doesn't look fun. Its not so much the labor it's procuring the miscellaneous O-rings that's a beeeeotch.
prescottn6ft7 is offline
Old 02-26-2013, 09:22 AM   #4279
bigshow8705
Member#: 322527
Hey I've got kind of a noob question since I'm still new to the subbie scene but does anybody have an info when using the access port for waste gate duty?
bigshow8705 is offline
Old 02-26-2013, 10:01 AM   #4280
prescottn6ft7
Member#: 268918
2004 STi
If you have specific questions about WGDC you may want to get on COBB's forum, or here: http://forums.nasioc.com/forums/forumdisplay.php?f=140
Definitely search first and put your flame suit on.
Old 02-26-2013, 10:20 AM   #4281
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
What do you mean by "using the accessport for waste gate duty," exactly?
HinshawWRX is offline
Old 02-26-2013, 10:39 AM   #4282
bigshow8705
Member#: 322527
Me and Mario were talking a while back about the boost issues I've been having and he thought it might be my wg well I just updated my ap and noticed the wgdm and was wondering if I could determine whether or it's going bad
Old 02-26-2013, 10:39 AM   #4283
Ntrpriz
Member#: 294989
2011 WRX STI
Dark Gray Metallic
Was thinking same. I assume for monitoring.
Ntrpriz is offline
Old 02-26-2013, 11:03 AM   #4284
prescottn6ft7
Member#: 268918
2004 STi
You definitely need to read up on "data logging" and get a few good pulls logged before you go into any of the tuning forums or they will rip into you, but will gladly help if you give them the right info to look over.
Old 02-26-2013, 11:16 AM   #4285
bigshow8705
Member#: 322527
Video Link: http://www.youtube.com/watch?v=rjEGZ-4dsDY
Well here's my question to you reason why I started asking questions is because when I start to build boost the car starts to jerk and hesitate is it safe to make the pulls I've been babying it until I figure out the issue?
Old 02-26-2013, 11:18 AM   #4286
Very WRXY
Member#: 295615
2010 Motor Whore
Going back into my hole
Get on it till she blows. its what i do.
Very WRXY is offline
Old 02-26-2013, 11:27 AM   #4287
bigshow8705
Member#: 322527
Thanks for that video man that helped a lot with my understanding of the ap now....will def be doing a log this week and be able to understand it now
Old 02-26-2013, 11:29 AM   #4288
prescottn6ft7
Member#: 268918
2004 STi
I would try replacing the BCS first I have a brand new oem one laying around if you want to put it in for a test run.
I'm assuming you have a boost gauge, and you've checked for boost leaks.
Are you over boosting and hitting fuel cut?
Has anyone ever messed with your bcs? There is a pill in those lines that is essential for the system to work correctly.
Old 02-26-2013, 11:34 AM   #4289
bigshow8705
Member#: 322527
I just replaced the bcs a couple of months ago and the restrictor pill is in the right spot and unfortunately my gauge just went haywire so I'm sending it back to prosport checked for boost leaks an still went through and replaced the older looking ones to be safe. I'm only building about 6 psi but then it struggles its ass off for any more than that. I appreciate the help man.
Old 02-26-2013, 12:24 PM   #4290
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
So low my rotors scrape..
I had a problem simpler to this and all I did was swap it out with a MBC and used my gauge to tell be careful tho lol
WRX WARRIOR is offline
Old 02-26-2013, 01:09 PM   #4291
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Do not put in an MBC if you don't know what you are doing.
Old 02-26-2013, 01:19 PM   #4292
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Anyone ever use an impact wrench on the rear differential drain plug? Mine are quite snug, and it is impossible to get any torque on it since it's sitting on my workbench.
I'd just have at it, but I'm pretty sure that the back piece is aluminum, and I don't want to crack it.
ThatGy is offline
Old 02-26-2013, 01:36 PM   #4293
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
Stand on it and use a breaker bar and a pipe. <---FYI that is what I did. It was an R180 though.
Might be eaiser with two people.
I'm not a fan of using non impact sockets/drives in a gun.
Old 02-26-2013, 01:49 PM   #4294
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
The problem is that I have the rear end apart so the differential is just sitting on my workbench. There really isn't anywhere to grab it.
I figured that it would a lot easier to get the new oil in with nothing in the way, but I may be wrong.
I guess I could just pour out the old fluid and pour in the new stuff out the holes for the shafts?
ThatGy is offline
Old 02-26-2013, 01:54 PM   #4295
prescottn6ft7
Member#: 268918
2004 STi
Not my car, but I would use the impact if it's off the car. Spray some PB blaster on it first. I mean the drain plug is square.... It's not like you're going to round it off. Putting it back in though I would use hand tools.
Old 02-26-2013, 03:17 PM   #4296
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Psh, wuss.
Old 02-26-2013, 03:23 PM   #4297
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
I'm just worried about the impact cracking the aluminum cover. I've decided not to chance it and just pour everything out the hole for the rear shafts.
Hopefully I'll be able to just get a 6 speed when it's time to change the oil again 30k miles from now.
ThatGy is offline
Old 02-26-2013, 06:03 PM   #4298
Damaca
Member#: 245703
07 WRX TR VF30'd
Phatbotti tuned
Who wrecked their white hawkeye sti on shore drive by little creek? I hope you're okay. Your car isn't but I hope you are.
Damaca is offline
Old 02-26-2013, 06:17 PM   #4299
noelicious
Member#: 185468
2006 STi Stage 2
White Buffalo
Before anybody thinks it, IT'S NOT NOEL... I'm home in my shorts and my babe is outside taking a cold shower.
noelicious is offline
Old 02-26-2013, 08:47 PM   #4300
Damaca
Member#: 245703
07 WRX TR VF30'd
Phatbotti tuned
I meant to add, "This wasn't Noel, I checked."
Damaca is offline
Closed Thread
Virginia Beach Meat's v3.0 Borjaq Mid Atlantic Impreza Club -- MAIC 541 08-13-2012 11:24 AM
Hampton Roads OT *Questions/Welcome/Help Request* V2.0 Damaca Mid Atlantic Impreza Club -- MAIC 2125 05-09-2012 01:39 PM
some questions and help requested midnight2.5rs-t Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-23-2009 10:20 PM
Hampton Roads Hooters Meet Pics Thread Ver 2.0 Unabomber Mid Atlantic Impreza Club -- MAIC 14 04-29-2004 05:07 PM
Message Board Statistics All times are GMT -4. The time now is 07:55 AM.
