Old 05-09-2012, 04:35 PM   #1
BeastianSTI
Member#: 310506
2005 WRX STi
Silver Beeches
Default 05 STI Fuel Filter
Another fuel filter thread, but.. I was just thinking, If it costs about $90 from the dealer for the fuel filter assembly, isn't there a way to just swap the "gauze" looking filter out with another one, rather than buying the entire thing? Also, are there any decent aftermarket alternatives?
BeastianSTI is online now   Reply With Quote
Old 05-09-2012, 05:10 PM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
You should be able to get the pod with filter for $60'ish online. Unfortunately, i don't think you can get just the filter insert.
Part number for my 04 was 42072FE020 so pretty sure your 05 is the same but double check.
Alternatively, some people remove the filter from the trunk and put on in the engine bay where the old style was. I thought about doing that but decided to just replace the in tank one.
z is offline   Reply With Quote
FS: NH AVO 850cc Side Feed Injectors, 05 STI TGV's, Stock 05 STI Fuel pump. PICTURES! Forsfed25 Engine/Power/Exhaust 21 06-28-2010 10:33 PM
clarify 05 wrx fuel filter Subey03 Newbies & FAQs 3 06-19-2010 12:53 PM
05 sti fuel filter Dirtyhobo010 Service & Maintenance 1 03-03-2010 10:07 AM
05 RS fuel filter binkman88 Service & Maintenance 7 02-28-2010 03:05 PM
05 RS fuel filter change/ iacv valve? binkman88 Normally Aspirated Powertrain 2 04-29-2009 11:22 PM
Message Board Statistics All times are GMT -4. The time now is 03:10 AM.
