Old 05-09-2012, 05:35 PM   #1
teefivetee
Member#: 296046
2005 sti
Default p0420 only when its hot out?
Hey guys, ill keep this quick. Randomly when the weather gets warmer here, my car will throw this code from time to time and then go away. Anything to worry about ? Cat runs like a champ otherwise
Thanks in advance
teefivetee is offline   Reply With Quote
Old 05-09-2012, 08:38 PM   #2
silverstreak02
Member#: 316307
2002 Impreza WRX
Hmm..usually a catalyst code isn't altered too much by weather.
Mods?
Could be an 02 sensor that's become lazy over time and isn't switching as need be.
silverstreak02 is offline   Reply With Quote
Old 05-09-2012, 08:46 PM   #3
teefivetee
Member#: 296046
2005 sti
It's weird, came.with custom exhaust and downpipe. Intake. That's about it. No cat, but my buddy did the defouler trick to make the Cel turn off. Wouldn't the car run funny or have a decrease in mpg if the o2 crapped out ?
But totally random. Usually goes away next day
Old 05-09-2012, 08:51 PM   #4
silverstreak02
Member#: 316307
2002 Impreza WRX
I have a P0420 that comes and goes as well. My fuel economy is still 28-33 mpg even when the code is active. The previous owner put in an aftermarket 02 that doesn't switch as properly as an OEM sensor, so it creates a cat code even though the cat is good.
So to answer your question, it CAN alter your fuel economy, but not always because the fuel trims are still based on the sensor whether it's slow or not. Also, not entirely sure about Subarus but my experience as a tech with Hyundai/Kia has me familiar with the vehicle resetting to a default in order to protect the converter from raw fuel damaging it.
Old 05-09-2012, 08:52 PM   #5
teefivetee
Member#: 296046
2005 sti
I'm so stupid. The code is p0442. My bad
Old 05-09-2012, 08:57 PM   #6
silverstreak02
Member#: 316307
2002 Impreza WRX
http://forums.nasioc.com/forums/show....php?t=1888770
This thread may help. I had this problem one day as well, only my valve was actually broken where the hose connects to it. Hopefully this will fix your situation
Old 05-09-2012, 10:04 PM   #7
scarney1988
Member#: 317760
As with any evap code, especially an intermittent one, I'de recommend replacing your gas cap with an OEM. Clear the code, and test drive. If code returns, and cap is tight. Come back and post the code and freeze frame data.
Good luck
scarney1988 is offline   Reply With Quote
WTB : Need AC parts, its hot out :/ auzy07 Private 'Wanted' Classifieds 10 08-25-2010 11:58 PM
its hot out! Keith Off-Topic 32 04-17-2008 08:14 PM
You know how to know when its hot out? Cosworth Off-Topic 9 06-27-2007 03:39 AM
Dash Clock works only when its hot jaygra Interior & Exterior Modification 1 06-02-2007 08:41 PM
its hot out... DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 17 06-24-2002 01:03 AM
