Closed Thread
Old 06-17-2012, 08:49 PM   #301
DirknJirkn13
Member#: 249696
2010 Outback Sport
Originally Posted by Power6
You don't need new keys, they will still work, remember you are only replacing the remote keyless function here.
The absolutely cheapest way to do this is get the legacy keyless, one used legacy key, a new housing/blade, and one used old legacy teardrop fob. Swap the keyless units, make your all in one key by hacking the valet key for the transponder, and program the old used legacy teardrop for use with the other stock keys. When done you now have one cool key, a remote and key set, and a spare key. You could even sell your impress keyless unit and remotes on eBay..
Basically what I said
DirknJirkn13 is offline
Old 06-18-2012, 03:27 PM   #302
slimfit
Member#: 90597
2011 WRX Premium
A word to the wise. Make sure you secure the transponder into the housing. Mine came loose inside the key while I was on vacation this weekend. The car wouldn't start half the time,or it would crank halfway then stop and sometimes wouldn't try at all. Kinda embarrassing, and I didn't have a spare or any tools
slimfit is offline
Old 06-18-2012, 04:24 PM   #303
brockd
Member#: 235571
2012 Impreza 2.0i
so stoked to get mine ;]
brockd is offline
Old 06-18-2012, 07:38 PM   #304
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
the new housing came in today... so I went from this:
To this:
Basically all it took was prying the legacy transmitter apart (4 little prongs) and removing the panic button (no resistance at all). I figure I don't use it anyway, so it's fine.
Thanks again Xluben. Most innovative mod evv44r.
OakleyWRX is offline
Old 06-18-2012, 11:13 PM   #305
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks pretty good! But you should try one of the shells from my photos. I think you'll be impressed
Another round of shells of going out today!
xluben is offline
Old 06-18-2012, 11:29 PM   #306
chet24
Member#: 315018
01 2.5RS & 04 FXT
STM/AW
Are you continuing to get more shells or is this a limited time thing?
chet24 is offline
Old 06-18-2012, 11:31 PM   #307
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm going to be getting more soon. I'll keep doing it as long as there's still interest.
xluben is offline
Old 06-18-2012, 11:42 PM   #308
BoDacious
Member#: 190110
2011 WRX
Sweet! Got my Legacy (ebay) key today. I plan on getting a key cut for me as I don't have a dremmel. :-(
Has anyone attempted to have a Legacy style fob ordered with the same code as their original key fobs? It would be nice to have all fobs working without having to pair all of the different codes.
BoDacious is offline
Old 06-18-2012, 11:43 PM   #309
AkumaMax
Member#: 180243
2005 Legacy 2.5GT
Sent you an Email. Those shells look damn sexy IMO. I'm going to mod one for my 05 Legacy. Pretty sure it will be just as easy to do if not a little cheaper to get my regular key cut compared to the usual $30+ to get your guys Laser keys cut.
AkumaMax is offline
Old 06-18-2012, 11:47 PM   #310
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Not possible. You need to program the code. Luckily it's easy and free. And the car holds five codes so the original remotes will still work.
Yep! Standard keys only cost a couple bucks to cut and can be done just about anywhere.
xluben is offline
Old 06-18-2012, 11:53 PM   #311
BoDacious
Member#: 190110
2011 WRX
Good to know, thanks for the info.
Old 06-19-2012, 01:40 AM   #312
2.5TurboWRX
Member#: 317970
2012 WRB Impreza
WRX Limited Sedan
Originally Posted by Alternet View Post
Wow :P I totally didn't check the thread for 4 days and the day you put that link up is when all of them went :P
I'm so angry at myself now I don't get how you found this though? I have been searching
'2011 subaru legacy key'
and I always get the same results... is there something else I should be searching?
I had the most luck searching "Subaru Key Fob" and checking the FCC ID and the picture to make sure they matched. Just don't give up and make sure you go through all the pages of results looking closely at each image and description.
2.5TurboWRX is offline
Old 06-19-2012, 05:52 PM   #313
BoDacious
Member#: 190110
2011 WRX
Got lucky and programmed the remote the first time. If anyone wants to get a laser cut key in the Northern Colorado area, I have a contact who will cut you one for $25.00.
Old 06-19-2012, 09:15 PM   #314
XsoberX
Member#: 289656
2011 Impreza WRX
Wondering if anyone else is having trouble programming their new key? I'm just using a legacy key, and got a new blank cut/swapped in my transponder. The key works great in the ignition and doors, but the remote doesn't work.
I Got my code, wrote it down (double and triple checked to make sure I have it written down right). Entered in the code on 3 different occasions(following the procedure), all 3 times the car did the confirm beep, and locked/unlocked the doors (which as I understand, means that it worked). Still no luck, the remote just doesn't do anything. Went out, bought 2 new batteries, tried that, still nothing... Anyone?
Also, if anyone went to the dealership to do it, was it a hassle? My dealership is run by complete morons, so that's kind of a last ditch effort... Help?
XsoberX is offline
Old 06-19-2012, 09:21 PM   #315
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
which 'confirm beep' are you talking about? It should make the same beep as when you use a normal remote to lock/unlock, not the beep that you get when you leave the key in the ignition/leave the lights on. The 'beep' should come from outside of the car.
Old 06-19-2012, 09:38 PM   #316
shortandangry
Member#: 311160
2012 WRX 5 door
After I programmed it, mine didn't do anything immediately. I sat there hitting button on the remote and finally it worked. I think it was after I pushed every button.
shortandangry is offline
Old 06-19-2012, 10:51 PM   #317
slimfit
Member#: 90597
2011 WRX Premium
I actually gave up thinking it didn't work. Walked away in disgust and sat in the house. Came out 10 mins later to find all the buttons operating as they should. Weird.
slimfit is offline
Old 06-20-2012, 12:08 AM   #318
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Ahh yes didn't read that yeah pretty much.
I recently got an 09 Legacy key for $10 off EBay, just bid on it and waited for the auction to end. You can do this cheap if you are patient.
Seems like you can't beat that for a teardrop, those seem to go for at least $20.
Originally Posted by XsoberX View Post
Wondering if anyone else is having trouble programming their new key? I'm just using a legacy key, and got a new blank cut/swapped in my transponder. The key works great in the ignition and doors, but the remote doesn't work...Also, if anyone went to the dealership to do it, was it a hassle? My dealership is run by complete morons, so that's kind of a last ditch effort... Help?
If you've programmed the same code 3 times successfully, then you have probably lost one of your stock remotes, the memory holds 4 remotes, first in first out style, so now you have 3 of the same plus one of your stock ones. You can check that out and at least it will tell you if you are doing it right ;-) You could have the dealer program it (they just type the code in to the tool, much easier) to be sure, but really if you have the right code and got the confirmation lock/unlock you are doing it right.
Sounds like you got either a bum remote, or a wrong one. What blade style and FCCID if used? P/N if new?
Power6 is offline
Old 06-20-2012, 08:30 AM   #319
carse
Member#: 237993
75 MGB
The FCC ID on that $10 key does not match the one listed in the first post.
carse is offline
Old 06-20-2012, 08:32 AM   #320
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's an 09 Legacy key for use on the older WRX's.
xluben is offline
Old 06-20-2012, 10:00 AM   #321
chet24
Member#: 315018
01 2.5RS & 04 FXT
STM/AW
Shh! Don't give away my secret. I am the current top bidder on that one...
chet24 is offline
Old 06-20-2012, 10:01 AM   #322
XsoberX
Member#: 289656
2011 Impreza WRX
At work right now, the FCC is is right, factory remote still works. Going to mess around with it some more tonight. If not... Off to the dealer I go.
XsoberX is offline
Old 06-20-2012, 08:09 PM   #323
XsoberX
Member#: 289656
2011 Impreza WRX
Tried this all again when I got home... Still nothing, the car gives me a confirmed beep with the lock/unlock, so it really seems like it should work. FCC ID is CWTWB1U811, just read it off the key. Blade type is the same as the 2011 WRX's, flat blade with cut out's on 4 edges. New battery.. Tried mashing all the buttons, tried pressing lock 10 times in a row.... Everything. I'm going to go to the dealership this weekend, and if that doesn't work, I guess I'll start looking for another used key... So frustrating. As a weird coincidence, after programming the new key for the 4th or 5th time, my original key fob didn't work... So I pressed the lock button a couple of times in a row, just to see. Then it started working again. Hmm... Strange. Anyways... If anyone has any insight as to something I may be overlooking... Get at me..
XsoberX is offline
Old 06-21-2012, 12:20 AM   #324
Alternet
Member#: 290172
2015 WRX
WR Pearl
Out of curiosity.. does the dealer charge you for programming a remote for ya?
Or is it different for different dealers...
Alternet is offline
Old 06-21-2012, 12:41 AM   #325
fenderpicks
Member#: 287694
2011 WRX
Hey guys DOES THE LEGACY KEY MUST HAVE IDETICAL PART AND FFC ID NUMBER???
To work with a 2011 WRX?
fenderpicks is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
