Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Closed Thread
Old 08-16-2012, 01:32 AM   #551
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Originally Posted by xluben View Post
Double check the code?
I have, both opened the remote to look at the white sticker plus there's also stuck to a stickie that came with the key....
Karce. is offline
Old 08-16-2012, 07:09 AM   #552
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
LOL @ this.
Some people shouldn't reproduce.
Also, mine has a bit of a wiggle as well, so it's common with all flip key shells. Xluben, youre right: It's just the gap b/w the front and back covers that's causing the blade and mechanism to wiggle a bit.
OakleyWRX is offline
Old 08-16-2012, 08:33 AM   #553
Grusselgrosser
Member#: 286859
2011 WRX Hatch
Satin White Pearl
So I was thinking about cutting the rubber off of my valet key so it would fit into my wallet and could act as a backup. But I guess this wouldn't be feasible since they have that white anti-theft part inside the rubber eh?
Grusselgrosser is offline
Old 08-16-2012, 08:36 AM   #554
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
You could do it, and maybe just wrap tape around it to be safe, but no, it will not be perfectly flat like a plain metal key. Although if you just want it in case you lock your keys in your car, then you could remove the transponder and it would still unlock the doors.
xluben is online now
Old 08-16-2012, 08:44 AM   #555
chet24
Member#: 315018
01 2.5RS & 04 FXT
STM/AW
I actually realized that my car has an aftermarket alarm (which is disconnected and I'm not sure how to connect it again... Kind of annoying...) but it has my valet key under the dash in a little box, which is for the remote start, I'm assuming. You could always try something like that... Then you wouldn't ever need a transponder. Good/bad.
chet24 is offline
Old 08-16-2012, 09:23 AM   #556
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Yeah, you can cut the transponder out of the key and secure it under the dash, in the steering column area, and then put the plain metal key in your wallet. Then if you do lose your keys you should still be able to start the car too!
Old 08-16-2012, 10:31 AM   #557
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Maybe I'll pry open my stock keys and get those codes, then reprogram all of the keys. I'm just scared I'll end up messing it up and all three keys won't work, then will have to resort to the dealership...
Karce. is offline
Old 08-16-2012, 10:51 AM   #558
dzywrx
Member#: 77610
2015 WRX-byebye 04
Sexy
the programming part is actually pretty easy - the instructions, however, make it look difficult.
just take your time to read the instructions before you get started.
dzywrx is offline
Old 08-16-2012, 10:56 AM   #559
dzywrx
Member#: 77610
2015 WRX-byebye 04
Sexy
Cheers Ben!
I have both the flip key and also kept a legacy all in one key. Lucky for me, the locksmith I went too just got their laser cutting machine so I got both keys cut for $35 as 'training'.
dzywrx is offline
Old 08-16-2012, 11:06 AM   #560
carse
Member#: 237993
75 MGB
Definitely do some searching around for locksmiths. I found a retired one that will do it for $12!
carse is offline
Old 08-16-2012, 11:25 AM   #561
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
I THINK i did it correctly, I mean I got the lock/unlock plus beep confirmation from the car, and I did this twice. :S
On a brighter note, I was able to get my local Subaru dealer to cut the key for free!!!
Karce. is offline
Old 08-16-2012, 07:31 PM   #562
Grusselgrosser
Member#: 286859
2011 WRX Hatch
Satin White Pearl
Sounds good, I'm gonna give it a whirl.
Old 08-17-2012, 11:12 AM   #563
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Looks like I have a bum remote, even though I bought it brand new from SubaruGeniuneParts. I tried reprogramming all my remotes, the stock ones still work but the new Legacy remote is still not doing anything. If all fails I'll have to look for a new key.... and I can't even return this one because it's an opened electronic part!
Karce. is offline
Old 08-17-2012, 11:18 AM   #564
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
I would certainly contact them. That does not seem right if it came DOA.
Old 08-17-2012, 12:10 PM   #565
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
They say that the Legacy key is not meant for the WRX, hence they cannot provide warranty for the electronic part. I also can't return it as the guy at Chaplins said that it's been opened and not used on the correct car....
Karce. is offline
Old 08-17-2012, 12:11 PM   #566
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Find a Legacy and try to program it on that.
Old 08-17-2012, 12:40 PM   #567
carse
Member#: 237993
75 MGB
Try a new battery in the remote?
carse is offline
Old 08-17-2012, 01:09 PM   #568
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
What part no did you buy, and what FCC ID to confirm. Does the Canada model have TPMS? I thought it didn't in the past but not sure about 2012.
Not sure if we have others in Canada with 2011/12 that have done this?
Power6 is offline
Old 08-17-2012, 01:16 PM   #569
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Originally Posted by krzywhtboi82 View Post
Ok see that's what I wasnt getting. I didn't kno you had to put the two theads together to be able to do mine. Like I said never done this before so I didn't know. Now it all makes sense. Sorry
You have to think outside the box a little bit. Use my DIY to get yourself working Legacy keys, then buy the shells from Xluben and swap to the flip key.
If you like I could set you up with all the right parts for a Legacy keyless unit and a couple of Legacy keys PM me if interested. You can DIY this too that is why I wrote the DIY on 3gWRX, just buy the parts new as it is difficult to get the right parts used if you don't know exactly what to look for many have been burned on EBay.
Power6 is offline
Old 08-17-2012, 06:01 PM   #570
roptic
Member#: 220922
2009 WRX Wagon
Lightning Red
Pm'd you, Thanks
roptic is offline
Old 08-17-2012, 08:38 PM   #571
Gsxricky
Member#: 324861
2011 WRX "Limited"
Def. gonna do this!
Gsxricky is offline
Old 08-18-2012, 05:51 PM   #572
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Part number 57497AJ10A, FCC ID CWTWB1U811.
It doesn't look like the Canadian models have it, I just checked my owner's manual and it says TMPS (US-models). I still don't get why we don't get all these features! No HID's either!
Karce. is offline
Old 08-19-2012, 08:09 AM   #573
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
Are you sure you're using the lock/unlock unit on the DOOR to program, and not the remote itself? That's been a common mistake throughout this thread.
Old 08-19-2012, 11:54 AM   #574
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
I'm pretty sure I am programming it correctly, using the door lock/unlock button. I've gotten confirmation from the car with the lock/unlock sequence plus beep when I finished programming a code.
I'll look for a new battery today, and pay a visit to the dealership tomorrow. Parts guy said he'll help me troubleshoot...
Karce. is offline
Old 08-19-2012, 02:43 PM   #575
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
^^That sounds right, don't think there should be an issue with Canadian car, would be nice if someone with a 2011/12 could confirm.
When you program the remote, the lock/unlock sequence at the end is the confirmation, it will beep either way, but if you don't get the lock/unlock it failed. You'll know you are doing it right when you have tried 4 times and un-programmed your other remotes ;-)
Also be patient, the remote sometimes doesn't work the first couple presses for whatever reason, then it starts working. Make sure to turn the ignition off and remove the key before you try the successfully programmed remote.
If you have done all that you might just have a bad remote. I might be inclined to tell the dealer it didn't work on your "Legacy" and see if they will then take it back. Get a VIN from a local or grab one from EBay if they ask.
Power6 is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
