Closed Thread
Old 08-19-2012, 03:16 PM   #576
glockatory
Member#: 298510
2011 WRX
Thanks for the excellent write up and thanks for answering all my questions Ben!
glockatory is offline
Old 08-20-2012, 01:24 AM   #577
SPTTuner
Member#: 291950
2011 WRX STI
Obsidian Black pearl
does anyone know if Home Depot or Lowes can cut these keys???
SPTTuner is offline
Old 08-20-2012, 08:29 AM   #578
DirknJirkn13
Member#: 249696
2010 Outback Sport
Not the laser cut ones, only the older style.
DirknJirkn13 is offline
Old 08-20-2012, 12:11 PM   #579
SPTTuner
Member#: 291950
2011 WRX STI
So its either the dealer or find a local locksmith??
SPTTuner is offline
Old 08-20-2012, 12:27 PM   #580
DirknJirkn13
Member#: 249696
2010 Outback Sport
That's what it seems like. My dealer doesn't cut keys, but others have had better luck. I just searched google for a local locksmith who does laser cut keys.
Old 08-20-2012, 03:52 PM   #581
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Originally Posted by Power6 View Post
^^That sounds right, don't think there should be an issue with Canadian car, would be nice if someone with a 2011/12 could confirm.
When you program the remote, the lock/unlock sequence at the end is the confirmation, it will beep either way, but if you don't get the lock/unlock it failed. You'll know you are doing it right when you have tried 4 times and un-programmed your other remotes ;-)
Also be patient, the remote sometimes doesn't work the first couple presses for whatever reason, then it starts working. Make sure to turn the ignition off and remove the key before you try the successfully programmed remote.
If you have done all that you might just have a bad remote. I might be inclined to tell the dealer it didn't work on your "Legacy" and see if they will then take it back. Get a VIN from a local or grab one from EBay if they ask.
So I went to the dealer and they checked the remote battery for me, the remote is giving out a strong signal and should be working. Only thing I can think of is :
1. This does not work on Canadian Cars
2. The white sticker / sticker hooked onto the Legacy Key both have the wrong programming code for this remote. (Highly unlikely?)
Anybody out there with a 2012 Canadian WRX able to successfully program the key? Or do I need to buy a Canadian Legacy key?
As for returning the key, I don't know if I can. The guy at Chaplins knows I own the WRX (from the VIN ). Unless I can somehow take it to other dealerships or talk to some other Internet parts guy from Chaplins...
Karce. is offline
Old 08-20-2012, 06:26 PM   #582
ImprezivSTI
Member#: 329720
i want to do this soooooo bad
ImprezivSTI is offline
Old 08-22-2012, 12:30 AM   #583
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Huh yeah this is weird I'd have to say the key is probably good. Still waiting for another Canadian to chime in...
What is the FCCID on your stock teardrop?
Power6 is offline
Old 08-22-2012, 02:01 AM   #584
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
I just read a post from you over at 3gwrx and went onto http://transition.fcc.gov/oet/ea/fccid/
to check the FCCID.
To my surprise, my stock teardrop remote has a FCCID of NHVWB1U711 which gives a transmitter frequency of 433.92 MHz.
The 2011 Legacy Key with FCCID CWTWB1U811 has a transmitter frequency of 315 MHz!!!
What is the US Spec teardrop remote's FCCID?
Edit: After reading your whole thread between you and bjkeed21, it looks like the Canadian cars never got the newer remotes. We don't have TPMS, so maybe we never got the upgrade. Can this still be done without changing the keyless unit itself inside the car?
Karce. is offline
Old 08-24-2012, 11:27 AM   #585
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Update:
If anyone needs a brand new 2011 Legacy Key, please PM me. I purchased it new from Subaru Geniune Parts but I doesn't work on my car as I am from Canada.
Karce. is offline
Old 08-24-2012, 03:23 PM   #586
kdubwrx
Member#: 284004
Karce- pmed you
kdubwrx is offline
Old 08-24-2012, 05:52 PM   #587
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Originally Posted by kdubwrx View Post
Karce- pmed you
Replied PM.
Karce. is offline
Old 08-28-2012, 06:54 PM   #588
pmraiders
Member#: 330191
2014 Impreza STI
Dark Grey Metallic
I am going to look into doing this, are the parts still easy to come by?
pmraiders is offline
Old 08-28-2012, 07:02 PM   #589
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep! Send me an email.
xluben is offline
Old 08-28-2012, 10:54 PM   #590
pmraiders
Member#: 330191
2014 Impreza STI
Dark Grey Metallic
There are some pretty silly restrictions on new users (I realize they combat spammers) so I can't email you yet. I will try to PM you.
Old 08-29-2012, 02:51 PM   #591
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
I finally finished my key! Maybe xluben can update his original post for us up North.
For Canadians:
Our cars never got the TPMS in them (as of 2012 WRX) and therefore the remotes have not changed in the 2011+ models. You need to buy a 2012 CANADIAN Legacy key! The US vs CAN remotes run on different frequencies so they won't work with each other.
Karce. is offline
Old 08-29-2012, 02:51 PM   #592
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Do you know the part number?
xluben is offline
Old 08-29-2012, 09:12 PM   #593
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
P/N 57497AJ00A
Karce. is offline
Old 08-29-2012, 09:23 PM   #594
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
Nice work karce! Congrats!
OakleyWRX is offline
Old 08-30-2012, 04:46 AM   #595
SPTTuner
Member#: 291950
2011 WRX STI
got my all done and added a little mod to it
SPTTuner is offline
Old 08-30-2012, 10:10 AM   #596
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
WOW! That looks nice!
xluben is offline
Old 08-30-2012, 04:27 PM   #597
Xsv21
Member#: 330589
2008 Subaru WRX
Charcoal
Makes me want one.....
Xsv21 is offline
Old 08-30-2012, 05:21 PM   #598
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Satin White Pearl
Sweet!!
Old 08-30-2012, 05:48 PM   #599
m00m00w4t3r
Member#: 246695
2008 STi
AW
As long as the frequency matches then im good to go?
my 2008 Impreza:
FCC ID: NHVWB1U711
Frequency Lower: 433.92
Frequency Upper: 433.92
Legacy
FCC ID: CWTWBU766
m00m00w4t3r is offline
Old 08-30-2012, 08:29 PM   #600
hella_sti
Member#: 139289
2003 WRX Wagon
Would any of these key mods or remotes work on my 2003 wrx ?
hella_sti is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
