Closed Thread
Old 05-16-2012, 11:44 AM   #101
olazy
Member#: 263322
2011 WRX Limited
WRBP
^ that flip will work, the only thing in question is the quality. people who have tried flip shells other than the one xluben has have said the quality is iffy.
olazy is offline
Old 05-16-2012, 12:23 PM   #102
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, exactly. The other flip shells are not as nice. I am getting very close to ordering a batch of flip shells. If you're interested, please e-mail me:
benjohnson dot smugmug at gmail dot com
xluben is offline
Old 05-16-2012, 12:43 PM   #103
rkjunior
Member#: 112220
2011 WRX 5DR Premium
Originally Posted by OKC-WRX View Post
Where did you order your key from?
Got mine from www.subarupartslive.com since I needed to order other stuff. It was a little more expensive - $75? - but free shipping. They offered to cut the key, as well, for $40. I'm just going to cut up one of my spares so I didn't bother but it's an option.
Now who's gonna sell me a shell?
rkjunior is offline
Old 05-16-2012, 01:59 PM   #104
Alternet
Member#: 290172
2015 WRX
WR Pearl
Using the part number 57497AJ10A
I found out my dealership sells it for $71.04...
I don't know if I can justify dropping almost $100 on a key mod :S
Alternet is offline
Old 05-16-2012, 02:07 PM   #105
ayanooo
Member#: 278908
'07 OBP WRX
Definitely tryin this one
ayanooo is offline
Old 05-16-2012, 02:08 PM   #106
rkjunior
Member#: 112220
I had just spent $1300 bucks on other parts so I said F-it. In the scheme of what I spent, it wasn't that much lol.
rkjunior is offline
Old 05-16-2012, 02:15 PM   #107
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Haha. Just a drop in the bucket
xluben is offline
Old 05-16-2012, 02:32 PM   #108
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
deleted
guitarman19853 is offline
Old 05-16-2012, 02:41 PM   #109
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I am planning on ordering shells. If someone else is thinking about ordering, please let me know and I will NOT be ordering them. I have no desire to compete with someone or to be stuck with 2 dozen key shells.
xluben is offline
Old 05-16-2012, 02:44 PM   #110
rkjunior
Member#: 112220
So, I have a question..
Programming remote
(to maintain your sanity your local dealer should do this for you with their computer)
1. Close all doors, trunk, gate
2. Open the driver’s door, sit in the driver’s seat, and close the door.
3. Perform the following steps within 45 seconds.
(1) Open and close the driver’s door once.
(2) Insert the key into the ignition switch, then turn it from the “LOCK” position to the “ON” position 10 times within 15 seconds.
NOTE: When you complete step (2), an electronic tone will sound once. If you do not perform steps (1) and (2) within 45 seconds, an error will occur. An electronic tone will not sound. In this event, perform the whole procedure again beginning with part 1.
4. Open and close the door once within 15 seconds.
When part 4 of the procedure is completed, an electronic tone will sound for 30 seconds. If you do not perform the operations in part 4 within 15 seconds, an error
will occur and the electronic tone will not sound. In this event, perform the registration steps again beginning with part 3 of the procedure.
5. Before the electronic tone stops sounding, press the lock side of the power door lock switch the same number of times as the leftmost digit of the transmitter
code. For example, press the lock switch eight times if the leftmost digit of the code is 8.
NOTE . The electronic tone will stop sounding when you start entering the number. If you do not start entering the number using the lock switch before the electronic tone stops sounding, an error will occur. In this event, perform the registration steps again beginning with part 3 of the procedure.
If the interval between one press of the switch and the next exceeds 5 seconds, an error will occur. In this event, perform the procedure again beginning with part 4. If an error occurs six times, perform the procedure again starting with part 3.
6. When you have finished entering the number, press the unlock side of the lock switch within 5 seconds.
NOTE . An electronic tone will sound. If you press the unlock side of the lock switch when more than 5 seconds have passed, an error will occur. In this
7. Perform parts 5 and 6 of the procedure for each of the remaining digits of the transmitter code beginning with the second digit (counting from the left) and
finishing with the eighth digit.
NOTE When you finish entering the eighth digit, an electronic tone will sound for 30 seconds. If the interval between one press of the switch and the next exceeds 5
8. Before the electronic tone stops sounding, use the power door lock switch to reenter the transmitter code beginning with the leftmost digit.
If you do not start entering the number using the lock switch before the electronic tone stops sounding, an error will occur. In this event, perform the procedure again beginning with part 3.
9. When you have finished entering the code a second time, an electronic tone will sound for 1 second to indicate completion of registration, provided the code entered the second time is identical to that entered the first time.
NOTE If the code entered the second time is not identical to the code entered the first time, an error will occur. In this event, perform the procedure again
beginning with part 5. If an error occurs five times, perform the procedure again starting with part 3.
10. If you wish to program another transmitter code into the system (up to 4 transmitter codes can be programmed into the system), perform the procedure beginning with part 4. When you have finished programming all of the necessary transmitter codes into the system, remove the key from the ignition switch.
11. Test every registered transmitter to confirm correct operation.
After you turn the key the 10th time, do you shut it off or do you leave it at ON?
rkjunior is offline
Old 05-16-2012, 02:45 PM   #111
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
EDIT: Leave it ON.
I do know that you have to turn the key back and forth pretty darn fast to make it in the allotted time.
xluben is offline
Old 05-16-2012, 03:12 PM   #112
12sechatch
Member#: 132458
Okie Dokie Fine
leave it at ON.
12sechatch is offline
Old 05-16-2012, 03:18 PM   #113
rkjunior
Member#: 112220
Thanks! I figured as much. You probably need accessory power for the lock button to work.
rkjunior is offline
Old 05-16-2012, 08:35 PM   #114
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Good news! I got the correct Legacy key today, put it back together, and programmed it into the car. Now it all works perfectly! I'll update the first few posts of the thread soon.
xluben is offline
Old 05-16-2012, 09:45 PM   #115
slimfit
Member#: 90597
2011 WRX Premium
Where are you guys finding these legacy keys for a decent price? I can't find anything for under $80 delivered.
slimfit is offline
Old 05-16-2012, 09:47 PM   #116
Zachfeen
Member#: 277479
2011 WRX
That is what you will pay from any site really, you might get lucky and find something cheap on ebay but I have already been burned twice by false advertisements on ebay.
Zachfeen is offline
Old 05-16-2012, 10:12 PM   #117
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep, you can scour eBay and take your chances (I also got the wrong key once). Or you can pay $60-80 for an OEM key.
xluben is offline
Old 05-16-2012, 10:18 PM   #118
fenderpicks
Member#: 287694
2011 WRX
sorry im lazy to read all the pages... but umm does this work on a 2011 WRX lol?
IM SORRY FOR NOT READING GUYS....
fenderpicks is offline
Old 05-16-2012, 10:19 PM   #119
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I hope this is a joke. Read the title. Read the first few words. You will find your answer.
xluben is offline
Old 05-16-2012, 10:20 PM   #120
Zachfeen
Member#: 277479
2011 WRX
hahahah.... laziness to a whole new level
Zachfeen is offline
Old 05-16-2012, 10:25 PM   #121
fenderpicks
Member#: 287694
2011 WRX
Originally Posted by xluben
Currently this post is a work in progress! I am still waiting on my 2011 Legacy donor key for the remote capability. I will update this thread as soon as I get the brains swapped into the flip key. This thread is meant to be a step-by-step guide on creating a 2011 WRX flip key. This thread will cover the steps and parts specific to the 2011 WRX. This can be done on 08-10 WRX's, but the parts and processes required will be different. See this thread on 3GWRX for further information: http://www.3gwrx.com/forum/index.php/topic,22640.0.html
So no o.O? lol idk im confused -_-
Old 05-16-2012, 10:27 PM   #122
Zachfeen
Member#: 277479
2011 WRX
Reading comprehension fail. It can ALSO be done on 08-10 but it's a different process than the for the 11 WRX.
Zachfeen is offline
Old 05-16-2012, 10:30 PM   #123
fenderpicks
Member#: 287694
2011 WRX
Ok i think i get it now... lol
So in order to make it work,
U need the flip shell
and a 2011 legacy key for the remote thingie...?
Old 05-16-2012, 10:33 PM   #124
Zachfeen
Member#: 277479
2011 WRX
Correct.
Zachfeen is offline
Old 05-16-2012, 10:41 PM   #125
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you need to ask that question, I would recommend you absolutely do not attempt this.
xluben is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
