Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Closed Thread
Old 05-25-2013, 04:30 PM   #1251
Ngurdak
Member#: 357459
Wish that worked for me
Ngurdak is offline
Old 05-25-2013, 04:36 PM   #1252
SpicyPeaNut
Member#: 43310
1978 Brat
Originally Posted by xluben View Post
It can hold up to 4 codes. So it is normal for the factory remotes to work.
Perfect. Thank you!
-V
SpicyPeaNut is offline
Old 05-27-2013, 08:59 PM   #1253
sdrenot
Member#: 357667
awesome
sdrenot is offline
Old 05-28-2013, 04:09 PM   #1254
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Not sure how I never saw this 51 page thread before...
phenryiv1 is offline
Old 06-01-2013, 09:43 PM   #1255
turbogc8
Member#: 26540
2001 Turbo GC8 sold
2013 DGM WRX Hatch
Finally got around to cutting up my valet key. Obviously used the transponder, but I also went the route of using the valet key blade. (I never lock the glovebox) I absolutely love this litte mod. I got used to having just a fob when I had to drive my wife's car while she was at home with the new born, and I was waiting for my Wrx to show up. Subaru should have done this from the factory.
turbogc8 is offline
Old 06-01-2013, 10:53 PM   #1256
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
Lets see some pics of those keys that have been used and abused for months. I'd like to see how the case holds up.
ndmx52 is offline
Old 06-01-2013, 11:15 PM   #1257
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
Around 6 months of use, good as new!:
mw1484 is offline
Old 06-03-2013, 04:32 PM   #1258
bao2me_23
Member#: 270201
2011 Impreza 2.5i
Just got mine in the mail the other day and I can't wait to get it cut!
Thanks xluben!
bao2me_23 is offline
Old 06-03-2013, 09:54 PM   #1259
Timecow
Member#: 357791
2013 WRX
Ice Silver
Thanks xluben! Very clear instructions for a cool mod. Getting my new 13 WRX this week but already getting the parts I'll need for this. Been lurking here for quite a while, but had to sign up to say thanks. One of the best "how-to" threads I've come across!
Timecow is offline
Old 06-09-2013, 03:36 PM   #1260
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
Not to hijack a thread, but can anyone help me with a programming issues on my 2013?
I have a separate thread and videos posted now to show whats going on.
http://forums.nasioc.com/forums/show....php?t=2514382
I get to the last part, and when entering the 8 digit number twice, nothing happens.
CPod is offline
Old 06-09-2013, 03:43 PM   #1261
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Where did you get the remotes? The used ones are very often incorrect or non working. Are you entering the code using the buttons on the door or on the remote?
xluben is offline
Old 06-09-2013, 03:46 PM   #1262
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
My friend totaled a 2011 Legacy, and i got the all in one key for free of him (complete)
Took it apart got the 8 digit code.
Yes I was using the driver side door lock/unlock buttons.
this was the video
https://www.youtube.com/watch?v=7vTa6dxOjhQ
(sorry for bad sun visor view)
CPod is offline
Old 06-09-2013, 04:35 PM   #1263
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I can't really tell what you're doing in the video and you're going very fast. But I don't think it should be beeping like that while you are entering the code. Do you have the door open or closed? What position is the key in? Do you get the long tone? I can't tell because you're rushing through it so fast.
xluben is offline
Old 06-09-2013, 05:09 PM   #1264
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
I re-made one showing everything and going slower.
~door is closed as i am putting in code
~key is in the off position this time, (had it in on before too)
~long tone is before starting with first number.
Sorry rushing because this is my 20x attempt at this point.
CPod is offline
Old 06-09-2013, 05:17 PM   #1265
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You're definitely not getting into programming mode. There is no long tone before you start entering the code. And then it just keeps making a beeping noise at the same pace while you are entering the code. This is not correct. Are you going all the way on and off with the key?
xluben is offline
Old 06-09-2013, 05:26 PM   #1266
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
Yup all the way off and on. 10x. I do get the constant tone (while beeping continues). The first number I put it constant tone stops. I also get beep confirming when I hit unlock.
If I pause the constant tone stops. Once 8th digit is entered than constant tone stays on again, and stops when entering first code number again.
CPod is offline
Old 06-09-2013, 05:33 PM   #1267
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I am having a hard time hearing it all on my phone in the car but what you just described sounds correct. Did you confirm the code is right by opening the remote?
xluben is offline
Old 06-09-2013, 05:42 PM   #1268
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
Yup here are some pictures.
523##484
Manufacturer date of 03-11 stamped on right
FCC ID: CWTWB1U811
Model# TWB1u811
CPod is offline
Old 06-09-2013, 08:11 PM   #1269
dmspeed6
Member#: 353994
2013 Imprezza WRX
Ice Silver
Since I can't email you because of posts, can you PM me so I can get everything I need to do this? Thanks
dmspeed6 is offline
Old 06-11-2013, 10:07 PM   #1270
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
CPod, you have to end the 10 on/off with the key in the on position, I know you said you tried that, but you didn't show that in the videos you are programming with the key in the off positon, it needs to be on "run" position. Don't worry about the key working or not until you have properly programmed the number. If you don't get the lock/unlock confirmation from the car at the end of programming, you didn't program the code.
Check this video, shows the right way, pretty much the same as you, notice he does it in the key on position, and he gets the lock/unlock confirmation at the end:
Power6 is offline
Old 06-13-2013, 03:28 PM   #1271
CPod
Member#: 319681
2013 WrX Limited
Plasma Blue
Video Link: http://www.youtube.com/watch?v=HPRSSj2C5BE
I will try this again when I get home. I am in Vegas till Wed night, but thank you for still replying on my issue.
CPod is offline
Old 06-14-2013, 04:12 PM   #1272
Ikkitousen
Member#: 354304
2012 WRX
Took about 2+weeks to get my parts in from Ben, he shipped them out as soon as he was able to pick them up:
Received it this morning and took me about 3 solid hours to put it together. I used a dremel with a few different attachments, my cut ain't pretty like Ben's but I got it in flush and it holds tight. Programming took me 2 tries, it was easy after I re-read the steps a few times and got it down.
You also need to rewind the springs a few rotations so the key ejects once you press the button down, took me a min on that. The fob feels heavier but it's fine for me as you can see I already have a Blox nut as my house key...
All in all, very happy with this DIY
Thanks again Ben.
Ikkitousen is offline
Old 06-14-2013, 05:10 PM   #1273
Trustkevin13
Member#: 259184
2008 Subaru WRX
^^^^ I have a 1-up!!!!
Trustkevin13 is offline
Old 06-14-2013, 05:24 PM   #1274
emazz104
Member#: 281811
04 WRX
World Rally Blue
After about four months, I finally got around to assembling everything! I love it! Anybody know of a way to make the trunk popper work on an 04? I would like to have it work simply to have it, plus I have a fully shaved trunk so it's kind of a PITA if the valet tab gets bumped.
Thanks again Ben.
It took me that long just to put it back together! Haha just kidding, the spring is kind of tricky, but it goes right together.
emazz104 is offline
Old 06-14-2013, 05:35 PM   #1275
Ikkitousen
Member#: 354304
2012 WRX
I need to get me that one :/
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
