Old 05-10-2012, 01:29 AM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default evo3 vs oem small 16g
Just a friendly PSA
eg33GC is offline   Reply With Quote
Old 05-10-2012, 01:49 PM   #2
Aphex28
Member#: 11506
2015 WRX
Any commentary?
I don't know if its lighting/viewing angle, but the wheels look damn similar to me. Is the main difference in the housings?
Aphex28 is offline   Reply With Quote
Old 05-10-2012, 08:54 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
the overall wheel diameter of the intake wheel is almost exactly a quarter in in diameter. The blades also are about an eight inch taller.
The larger wheel also has a more aggressive sweep to the blades.
The exhaust wheel is at least a quarter inch wider, and about again, a quarter inch taller.
This should be good for 350whp I think.
Old 05-11-2012, 03:54 AM   #4
pmugabi
Member#: 280926
It's so unfair how the Evos have a larger turbo and yet have a lower boost threshold than we do running the TD05. The last time I was in an Evo it was like TD04 response with TD05 power.
I
pmugabi is offline   Reply With Quote
Old 05-11-2012, 11:54 AM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
and our cars still kept up pretty good with the evos!
I'm digging for compressor maps for the exact part number s16g we have. I doubt there is one specifically for it though.
Old 05-11-2012, 01:22 PM   #6
Aphex28
Member#: 11506
2015 WRX
Oh wow. I knew the evo3 turbo was better, but not by that much.
Think that cartridge would fit into the Subaru td05 housings?
Old 05-11-2012, 01:30 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
it does
the feed and drain fittings are different though, I have yet to measure them
Old 05-11-2012, 05:32 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
I
That's what happens when the turbo is 6 inches from the exhaust valve.
Old 05-14-2012, 09:56 PM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
this turbo is going to **** rod bolt fragments through my hood
(the new td05hr uses the classic evo3 wheel)
current:
Old 05-14-2012, 10:53 PM   #10
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
Where did you find this turbo? I searched everywhere.
fxt05 is offline   Reply With Quote
Old 05-14-2012, 10:54 PM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
you have to convert it to 90* inlet, is that your issue?
Old 05-14-2012, 10:59 PM   #12
carlck19
Member#: 249890
1995 Impreza L wag
white
^how would you convert it to 90 degree?
carlck19 is offline   Reply With Quote
Old 05-14-2012, 11:04 PM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
like so
Old 05-15-2012, 12:48 AM   #14
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
I wasn't looking for 90 degree. I was trying to find a straight inlet and thinking about intake risers like superdave. The only thing I found was the compressor wheel for something like $170. Is there a complete turbo available? My dream one day in the distant future is a larger turbo. But that will come after a stand alone.
Old 05-15-2012, 12:50 AM   #15
eg33GC
Member#: 206851
56 Belair
Pro Street
There is the option for the Kamak cover and wheel.
I put this together using a hodgepodge of parts.
I much prefer the 90* inlet.
Old 05-15-2012, 10:35 AM   #16
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
I do like the response of our Evo. It's actually my goal for my mr2, to be that smooth n powerful. However, despite what feels like dog-slow spool in my WRX (stock 16g-td05), its probably faster than the Evo with less mods/same boost. (granted a bit less weight)
neko is offline   Reply With Quote
Old 05-16-2012, 02:05 AM   #17
eg33GC
Member#: 206851
56 Belair
Pro Street
got it installed
impressions:
much louder in vacuum conditions
increased rumble
much better manners
hard to get out of vac
not too slow on 10psi. Obviously the small was quicker at post 18psi levels, but the evo3 really shines as it reaches 20psi.
will be doing some road tuning tomorrow. fwiw the targeted afr for 12psi on the small was 11.4, and for the evo3, it was like 12.3. BAD. I only did that for a reference point of course.
Old 05-16-2012, 10:37 AM   #18
scoops04wrx
Member#: 150966
04 WRX
Hmmm i sub'd. I currently have the Evo3 and even though it will do for now, Im kind of looking for something bigger.
scoops04wrx is offline   Reply With Quote
Old 05-16-2012, 12:55 PM   #19
eg33GC
Member#: 206851
56 Belair
Pro Street
what pressure are you running?
an evo3 is superior to the 18g for a street, pump car. Everytime I read on here or in person otherwise, I want to choke puppies.
As soon as you spin those wheels past 20,21psi, the compressor takes off. Maybe that is your issue?
Old 05-16-2012, 02:24 PM   #20
scoops04wrx
Member#: 150966
04 WRX
I'm currently at 21 with my ewg set around 19.5. I only want to switch for power but after reading, I'm starting to have a change of heart. I don't plan on AXin a lot nor dragging. It's mainly for street use.
small 16g vs big16g..A DSM'ers analysis mxpunk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-15-2009 11:56 PM
Ready to Ship Blouch Evo3 16G Turbos and Small 16g Turbos!!! Spun Autosports MAIC Vendor Classifieds 2 08-20-2007 12:10 PM
Small 16G vs stock TD04 mbakercad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 10-23-2006 03:06 PM
small 16g vs. vf34 silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 07-07-2006 06:36 PM
small 16g vs big 16g silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 01-10-2006 02:51 AM
