Old 06-16-2012, 04:56 PM   #51
85z28
Member#: 313657
It's cool.....
LOL jk, congrats man. I love that part of the country. How is that going to work out with your band?
85z28 is offline   Reply With Quote
Old 06-16-2012, 05:09 PM   #52
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
Mostly moving there because of the band, actually. We keep flying back & forth from Dallas to Nashville, and every time we go there it just seems obvious that we should make the move. As soon as someone buys/rents the band house here, we're out.
8thWonder is offline   Reply With Quote
Old 06-19-2012, 04:29 AM   #53
8thWonder
Member#: 230366
2005 STi
Got confirmation tonight that the 19mm spacers finally shipped! Now I can finally start putting everything together when I get back in town this weekend. Since I had more time to dwell on this whole project, I decided to order the necessary sensors to get a speed density tune. Hoping that it helps with the smoothness/driveability/accuracy of the tune, especially when I upgrade the turbo in a few months.
Old 06-19-2012, 06:49 PM   #54
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Big shoutout to me... for everything....
wrxadam05 is offline   Reply With Quote
Old 06-19-2012, 06:52 PM   #55
wrxadam05
Member#: 84070
500whp GRB STI
IS that a push fitting to -6an with a clamp on the drivers side shock tower?
Good luck with that.
Old 06-19-2012, 07:11 PM   #56
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Clean build, I think my favorite thing is the fuel filter lol
Smurftastic is offline   Reply With Quote
Old 06-19-2012, 07:46 PM   #57
8thWonder
Member#: 230366
2005 STi
HUGE shoutout to you!! Added something to the first post. Absolutely could not have done any of this without you, except for the audio stuff
Yes it is, because we were like 8ft short on the amount of fuel hose we ordered. Had a perfect amount for the feed line and the fuel rails, but absolutely none left over for the return line. Got a push to -6an adapter and clamped the correct size hose from the hardline to the adapter. Not worried. If I'd known the spacers were going to take 2 weeks to get to me, I would have just ordered more fuel hose.
Old 06-20-2012, 06:17 PM   #58
wrxadam05
Member#: 84070
500whp GRB STI
Sounds like you routed the feed from the tank possibly through the airport before making it to your engine bay. I ordered the same about of hose, did my feed, return, surge tank, and rails, and still had enough to give you a small show of my zip-tie trick at my kitchen table.
Old 06-20-2012, 07:28 PM   #59
8thWonder
Member#: 230366
2005 STi
noooope
Either I got shorted, you got more than you ordered, or we didn't order the same amount.
Old 06-21-2012, 12:57 PM   #60
wrxadam05
Member#: 84070
500whp GRB STI
Chuck testa. Just sayin'.
Old 06-23-2012, 02:09 PM   #61
8thWonder
Member#: 230366
2005 STi
OEM gasket vs beefcake spacers
Back in town & time to get to work!
Old 06-25-2012, 01:05 AM   #62
8thWonder
Member#: 230366
2005 STi
Have been in the garage all weekend. Re-installed power steering pump, alternator, AC compressor, radiator hoses, and belts. Got the engine wiring harness back in the car and hooked it all up. With the help of some colorful vocabulary and repeated test-fitting of the intake manifold, finally got it in place. Figured out a new mounting place for the FPR, after realizing that it was preventing the hood from closing all the way. Installed the turbo inlet. Started cleaning up the vacuum lines. Torqued down most of the fuel rail stuff. Cussed at the injectors/rails for making it impossible for the injector harnesses to clip into place. Lengthened/spliced wires for the speed density sensors (MAP and IAT). Heading back for more...
Old 06-25-2012, 07:36 AM   #63
8thWonder
Member#: 230366
2005 STi
Ran the rest of the vacuum lines and got the vacuum distribution block mounted, got all the hoses & wires underneath the intake manifold settled into place, and completely finished everything fuel-related under the hood.
I think all that's left is securing the last couple of FMIC pipes, torquing down the intake mani, finishing the air/oil separator hoses, re-installing the coolant reservoir and intake, and triple-checking everything.
5am camera phone skillz:
Old 06-25-2012, 12:40 PM   #64
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
looks much better!!! running all the vacuum lines underneath the intake manifold
blakkboxer is offline   Reply With Quote
Old 06-25-2012, 01:42 PM   #65
8thWonder
Member#: 230366
2005 STi
Thanks! It's still busier than I was hoping. The engine wiring harness is such a beast!
Old 06-26-2012, 03:39 PM   #66
8thWonder
Member#: 230366
2005 STi
Another late night. Clamped down all my FMIC piping/couplers. Installed the BPV. Ran the last few vacuum and coolant lines. Now to finish up the AOS, hook up the battery, pop in the intake filter, and double-check everything. As soon as COBB sends the base map, I'll fire her up and tow her to get tuned!
Old 06-27-2012, 06:58 AM   #67
8thWonder
Member#: 230366
2005 STi
Hooked up everything to the point of being "tune-ready" (i.e. the AOS is connected but not permanently mounted, the front bumper is off, no strut bar, etc). Reconnected the battery for the first time in a while and primed the fuel pump repeatedly to check for leaks. All fuel bits seem good to go. Loaded the base map that the tuner emailed me, and the car won't start. Seems like it just doesn't want to spark, but the spark plugs never left their place, and the coil packs are definitely connected correctly. Barring some huge issue that I'm completely blind to, my guess is that the base map didn't cover some of the changes I made. Hopefully that's the case. Just reserved a trailer from U-Haul and will be towing her to the dyno in a few hours.
horrible lighting, but here's an idea of how she looks right now:
Old 06-27-2012, 11:43 PM   #68
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Can't wait to see what that intake does under boost
I'm rite behind you buddy all I have left is installing the giant spacers and intake and I'm ready to fire it up!! Good luck!
shilohb is offline   Reply With Quote
Old 06-28-2012, 09:12 PM   #69
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Update??
Old 06-28-2012, 11:17 PM   #70
8thWonder
Member#: 230366
2005 STi
The car will be on the dyno tomorrow morning! Cobb wanted to change a few things about the setup (not using the manual boost controller, etc.), so they made those changes today and will tune tomorrow. Can't wait to get it back.
Old 06-29-2012, 02:22 AM   #71
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
This is a great thread!
JohnnyWas is offline   Reply With Quote
Old 06-29-2012, 03:17 AM   #72
Inversed
Member#: 164306
Something about your RPF1s and fitment is just perfect, more so than others with similar setups. Car looks great, that 2nd photo in the op is perfect, anyway you could put up a high res of it?
Inversed is offline   Reply With Quote
Old 06-29-2012, 04:33 AM   #73
8thWonder
Member#: 230366
2005 STi
Thank you! I hope to keep updating and to eventually do a write-up on the sound system/electrical stuff as well.
Thanks for all the kind words! The largest version of the pic that I have is 1500x760. Here's a direct link:
http://i.imgur.com/jvsbc.jpg
Old 06-30-2012, 02:02 PM   #74
8thWonder
Member#: 230366
2005 STi
Finally got the car back yesterday! Made 301hp/355tq on Cobb's Mustang dyno with 93oct. Not bad for stock turbo and 102*F ambient temperature. I only got to drive it for about an hour, then had to leave town. Can't wait to get back, put the bumper back on, and really go for a drive! Will post the dyno sheet when I'm back as well.
Old 07-10-2012, 12:49 PM   #75
8thWonder
Member#: 230366
2005 STi
Back in town! Took some time yesterday to reinstall the front bumper, back seat, alt shroud, strut bar, and underpanel. Will have some good pics of it after getting it washed.
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 05:41 PM
Silver Ra's Build Thread Silver Ra Member's Car Gallery 23 06-25-2007 09:46 PM
Jutboy's EJ22(T) Build Thread Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-07-2007 08:52 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 05:26 PM
