Old 05-10-2012, 09:45 AM   #1
nismopowerdqg
Member#: 312580
2010 WRX [email protected]/334
Cobb/Torqued Performance
Default Will this be a good replacement spark plug?
I have NGK platinums and they are a bit worn and the previous owner gapped them which i read is bad for the plug, i heard copper plugs were better for my set up (18g, 22psi w/ supporting mods) and didnt know if this plug would be sufficient or not. Its one of the only step colder plugs i can find in my town. Feedback is appreciated.
http://www.napaonline.com/Catalog/Ca...922_0137962118
nismopowerdqg is offline   Reply With Quote
Old 05-10-2012, 11:52 AM   #2
GeneralTJI
Member#: 152680
NGK bkr7e
part number 4644 at the auto parts
I've run all kinds of things, I run these gapped at .0.24 (built motor, cams, big holset turbo etc.)
Copper doesn't last as long as Iridium, but provides a bit better spark. Stay away from platinums...
GeneralTJI is offline   Reply With Quote
Old 05-10-2012, 12:16 PM   #3
nismopowerdqg
Member#: 312580
Got the ngks. Thanks
Old 05-10-2012, 01:02 PM   #4
nismopowerdqg
Member#: 312580
UPDATE!!! one of the coils little connector "tits" is broken. will zip ties work to keep it secure??
Old 05-10-2012, 01:36 PM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yes, you just need to lock it on there.
tip: in nearly 10 years of replacing copper plugs every year, i have never disconnected my coils from their wiring harness.
Old 05-10-2012, 02:28 PM   #6
nismopowerdqg
Member#: 312580
i dont disconnect them. it just fell off like it was already broken maybe from the previous owner. but thanks for the help!
Old 05-13-2012, 11:44 AM   #7
AZP Installs
Member#: 40160
Often time the heat can make them brittle and they snap off just by touching them. Zip ties sometimes work, but if you get a misfire on that cylinder then you may need to epoxy it.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 05-18-2012, 05:26 AM   #8
westsideguy
Member#: 319112
Just to clarify, if done properly gapping a plug is not "bad" for a plug. Technically all plugs are supposed to be "pre-gapped" for proper spark with the plug, but if you are going to do routine maintenance on your vehicle I would recommend getting your own spark plug gapping tool. There is a spec for your vehicle's plug gap, and you never know what the gap could be with the new ones "fresh out the box". For example I had 4 plugs I bought for my beater ford escort and there was an up to .020" difference between some of them. I used a gapping tool and got them right around .002" of each other. Of course getting the hang of gapping might take a bit, so I would practice on the ones you are replacing before putting the new ones in. FYI gapping tools are only like 5 bucks and that's a little pricey for one
westsideguy is offline   Reply With Quote
Old 05-18-2012, 06:56 AM   #9
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the problem is that it is nearly impossible to gap a needle-point electrode (platinum, iridium) without damaging the surface.
this is a non-issue with traditional copper plugs.
Changing spark plugs before retune, will this be an issue? Byzantium Engine Management & Tuning 5 10-19-2010 12:09 PM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 04:45 PM
Shoul I use colder replacement spark plugs with this setup? MMastro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-24-2003 09:30 AM
Is this the correct size for replacement spark plugs Scoobie Newbie Newbies & FAQs 5 03-06-2003 06:27 PM
What is a good replacement Spark Plug besides its stock NGK, for WRX 2002? javier2971 General Community 10 12-29-2001 12:41 AM
