Old 05-10-2012, 11:49 AM   #1
aboes81
Member#: 202226
2002 WRX Sedan
World Rally Blue!
Default 2002 WRX AirCon Troubleshooting
Last winter (Feb '11) I took the whole AC belt assembly off my car because it was only working intermittently (sometimes warm air would come out then throw ice chunks at me) and I had hopes that removing it would improve my gas mileage.
Well last summer it really sucked not having AC. Hoping for at least some cooling, I put the belt back on and now it doesn't work at all.
What's the best way to troubleshoot this?
aboes81 is offline   Reply With Quote
Old 05-10-2012, 07:44 PM   #2
silverstreak02
Member#: 316307
2002 Impreza WRX
I would start by checking if the AC compressor even cycles on and off when you turn on the AC. If not, you're probably out of refrigerant which means you have a leak somewhere in the system. The next step is charging your system and filling it with leak detection dye. Periodically look over your system with a UV light to pinpoint the leak.
Most likely looking at the o-ring that is where the discharge line meets the compressor or possibly the condensor. That's really the only way to go, hopefully this helps and you know someone with access to an AC machine/manifold gauges or you will have to pay a shop a half hour diagnosis fee and let them check for you.
silverstreak02 is offline   Reply With Quote
Old 05-17-2012, 12:02 PM   #3
aboes81
Member#: 202226
2002 WRX Sedan
World Rally Blue!
Thanks for the info, I'll try to take care of it this weekend.
Old 06-29-2012, 11:04 PM   #4
aboes81
Member#: 202226
2002 WRX Sedan
World Rally Blue!
I ended up going to a shop and he filled it for me. He checked for a leak and ther e was an o ring that was leaking. The whole thing only cost me $108
Old 06-30-2012, 02:35 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
there was a tsb on the 02's about the one switch location being not good and it freezes up....research this....some have just insulated it with some foam and had it cure the freeze up issue
FS : VA: 2002 WRX Sedan 93k miles, Original owner, 9000$ DaveyPetey Private Vehicle 'For Sale' Classifieds 16 06-06-2012 10:23 PM
FS : VA: 2002 WRX Sedan 93k miles, Original owner, 9000$ DaveyPetey MAIC Private Classifieds 6 05-31-2012 10:34 PM
FS/FT : VA: 2002 WRX, Stock 3.8k CLEAN SDelong Private Vehicle 'For Sale' Classifieds 32 05-14-2012 02:09 PM
How long to swap a 2002 wrx motor with another 2002 wrx motor subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-29-2006 02:16 PM
