Old 05-10-2012, 04:38 PM   #1
Subbiespeed
Member#: 276493
2005 STI
Default ej20g wrx vs sti wiring
i have a 94 wrx ej20g in my car now and was looking at putting a ver 2 sti ej20g to replace it and just wanted to make sure that the wiring would match up with no issues
Subbiespeed is offline   Reply With Quote
Old 05-10-2012, 06:10 PM   #2
RallyColtTurbo
Member#: 16819
Never done it, but from everything I have read, they should be the same.
IIRC, even the cars with the 5th injector had them disabled from the factory.
RallyColtTurbo is offline   Reply With Quote
Old 05-10-2012, 07:23 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's the same, plug it in and go.
Old 05-10-2012, 08:56 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
All of them, even basic td04 wrx, had the wiring for 5th injector.
All of the wiring is identical from 1992 to 1996, pre K
eg33GC is offline   Reply With Quote
Old 05-19-2012, 08:39 PM   #5
bwmate88
Member#: 320662
Default 02/06 wrx,sti swap
We have a 2002 wrx that we want to put a 2006 sti motor in. Can n e one tell me what id have to do with the wiring ? If possible id like to "NOT" rip out the harness. Will it plug right in to the 06 motor ? Do i have to splice and change some wires or buy n e adapters ? The easiest way would be great. I really dont wana pull all the wiring if i dont have to. [email protected]
Thank u.
bwmate88 is offline   Reply With Quote
Old 05-19-2012, 08:54 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thank u.
You need a whole STI harness, ECU, DBW pedals, all the modules etc
Old 05-21-2012, 11:19 PM   #7
wrxgoonsti
Member#: 320731
What about running the motor with no avcs using wrx ecu and harness?
wrxgoonsti is offline   Reply With Quote
Old 06-03-2012, 08:11 PM   #8
toonz
Member#: 322044
what's the difference between the 2 engines... you might have to get an STI ECU for that engine aswell, no? Someone's tellin me about an issue about my swap I want to make...
I have a 3 pin slot ECU 6S for my 96-98 EJ20G... but they told me the ECU is not the right one for my engine.... its for a EJ20K... but honestly, I don't have a bloody clue... so make sure your ECU will be compatible.... or a one you get IS compatible with the engine....
toonz is offline   Reply With Quote
Old 06-05-2012, 10:04 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
All 4-plug EJ20 turbo ECUs run on the same harness...
Marnix is offline   Reply With Quote
04 WRX vs STi Wiring Harness Differences DinoGuan Electrical & Lighting 14 05-27-2011 07:37 PM
wrx vs. sti vs. aftermarket exhaust/maifold ScarryFatKidGT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 02-05-2009 01:14 PM
All side mirrors equal? 04 vs 05, wrx vs sti? CletusTheDwarf Interior & Exterior Modification 13 01-08-2006 11:59 PM
RX-7 vs. WRX vs. STi Guru Imakuni Off-Topic 19 03-25-2005 04:52 PM
SRT4 vs WRX vs STI vs RS vs RS-T??? OB2 Off-Topic 31 10-03-2004 03:47 PM
