Old 03-22-2013, 07:27 PM   #51
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by Waterlogged View Post
Here is an inexpensive 12v to 6v converter from fleabay. ...
You may not need a 6V converter after all. See my post here.
Care to open up your camera to see if it's similar to the Crosstrek's?
SVXdc is offline   Reply With Quote
Old 03-22-2013, 07:33 PM   #52
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by trek4fun View Post
Are the new Subaru Crosstrek Premiumís with a basic radioís coming prewired for a backup camera? I ask because so many Crosstreks are coming with NAV units and all Limitedís come standard with backup cameras. I have access to a new Crosstrek radio that had backup installed before it was pulled. The owner is keeping their camera.
See this.
Old 03-22-2013, 11:42 PM   #53
Waterlogged
Member#: 294791
2012 Impreza Sport
I'll see if I can get it apart this weekend and post my findings.
Waterlogged is offline   Reply With Quote
Old 03-23-2013, 03:59 PM   #54
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
News
Here is an inexpensive 12v to 6v converter from fleabay. I tested it with an input voltage of 6vdc to 12vdc and it held steady at 6vdc. Rated current capacity appears to be well above the current draw for these Clarion cameras.
Hey what's the fleabay auction number on that DC to Dc converter?
ZURCALED12 is offline   Reply With Quote
Old 03-23-2013, 04:09 PM   #55
Waterlogged
Member#: 294791
2012 Impreza Sport
Type in "12v 6v converter" on fleabay. There are multiple options.
Old 03-23-2013, 04:11 PM   #56
Waterlogged
Member#: 294791
2012 Impreza Sport
The case appears to be sealed in contrast to the camera for the Crosstrek. There are no screws or latches that would indicate that it can be easily split.
Old 03-23-2013, 04:50 PM   #57
ZURCALED12
Member#: 309754
Ice Silver Metallic
Found it, less bulky than my original one. thanks!
Old 03-24-2013, 08:01 AM   #58
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
To anyone wanting the factory camera, please forgive for sounding like an a$$, but if you don't have the factory wiring in place, why waste your money on the factory camera and cut the end off it? The Rydeen MINy, once installed, looks exactly the same as the factory camera sticking out the hole in the garnish. Also, the connector fits SVXdc's harness without cutting anything off. It also does not require any kind of power converter.
Why spend more to chop something up and adapt it when you can get a good quality camera for less and have plug and play?
I purchased the rear garnish with the cut out myself. I had a concern about the plating having an exposed edge if I cut out the old garnish. Unfounded perhaps but that was my decision. Anyway, the MINy fits nicely in the recess where the camera would actually go. (Just peeking out as it would be.) I attached the camera to a piece of flat aluminum which sticks to the opening in the trunk with Velcro from the inside. If needed, I can pull it to make adjustments.
Chances are I may have gone a different route had there been wiring in the car for it already, but since there was not..............
My 2 cents.
John
edit: I should add that this is connected to a factory HU. Of course aftermarket HU's will change things.
Guzzi 1 is offline   Reply With Quote
Old 03-24-2013, 09:13 PM   #59
ZURCALED12
Member#: 309754
Ice Silver Metallic
News OEM vs. Fleabay?
My 2 cents.
John
What does this camera look like? will it fit snugly into the square OEM opening? My concern is that one, it will last longer than my fleabay camera and also that it would work with my Pioneer AVH-8400BT H.U. That is why I was opting out for the OEM camera. Also using a step down DC-DC converter to simulate the OEM H.U. input to the OEM camera. I want the OEM look on my lift gate, that is why I ordered the rear panel with the CUT-OUT already. The camera is kinda pricey, but I do not mind paying for quality, as you know it's made in JAPAN and not CHINA by CLARION. So that being said what does this camera you mentioned look like any pictures, install, website info.
Old 03-24-2013, 09:15 PM   #60
ZURCALED12
Member#: 309754
Ice Silver Metallic
Found this one for like $3 wow sealed waterproof!
Old 03-24-2013, 09:30 PM   #61
ZURCALED12
Member#: 309754
Ice Silver Metallic
Found it, hhmmm!!!!
Old 03-25-2013, 06:38 AM   #62
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
I went with the MINy rather than the DUO, (which you show a pic of), mainly because there was no adjustment for angle with the DUO. Further, that happened to be the one a local dealer kept in stock. The MINy and its mounting base fits through the hole in the trunk lid. On visible inspection, it looks the same as the factory camera in my buddies '13 Outback. You can barely see it peeking out the opening.
As for fitting snugly, it's too small and fits through the hole. As I mentioned, I attached it to a piece of flat metal and used Velcro to stick the edges of the flat aluminum to the edges of the opening from the inside.
The car has been reassembled but I will try to get a couple of pics and post them. Work has been insane lately so I have not taken the time to get any. I will get some reference pics in the next couple days.
Here is the Rydeen site:
http://www.rydeenmobile.com/Backup%2...upCameras.html
The first camera on this page is the one I purchased. I works down to a lower voltage then they have advertised. (CM631UD HU is what I have.) In reality, it is probably smaller than the picture. Also, as I had noted in another post, Rydeen does not have internet sales. If a warranty is important to you, (1 year from date of purchase), then you would want to seek out a local shop to buy it from. I called their toll free number and asked for local dealers.
I can assure you that this camera, sticking out the factory opening in the garnish looks OEM. Further, my mounting solution insured that I needed to make no holes that were not there. IF there is a drawback, it may be that it does not stick out enough. I have thought about a small piece of aluminum angle bolted to the flat piece I already used and stick the camera mounting bracket to a vertical surface. That should let it peek out just a bit more. Then, OTOH, it is working just fine as it is. Just that I can be anal about getting things like this just right.
John
Old 03-26-2013, 05:27 AM   #63
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Here are a couple of quick pics with the fone. Forgive the dirt.
Almost straight on:
A closer view:
John
Old 03-28-2013, 09:12 PM   #64
ZURCALED12
Member#: 309754
Ice Silver Metallic
News That looks Great on there.
Wow! that does looks OEM. It's snug up in there too.
Old 03-28-2013, 11:11 PM   #65
ZURCALED12
Member#: 309754
Ice Silver Metallic
News FINALLY PROGRESS! LoL !
This is the OEM Crosstek/Impreza Camera. Courtesy of :Lv4toys
Last edited by ZURCALED12; 04-03-2013 at 09:06 PM. Reason: Thanks! SVXdc for all your help & input.
Old 04-12-2013, 09:55 PM   #66
ZURCALED12
Member#: 309754
Ice Silver Metallic
SVXdc was correct there is no need to use a 5V supply to power the OEM camera it has been verified and tested in this forum: http://xv-source.com/showthread.php?...ew-Camera-ASSY
Old 04-13-2013, 09:54 AM   #67
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Very interesting. I like how it appears to snap into the opening and create a seal. A very simple and effective mounting solution.
Does it have any provision for angle? It looks like it sticks out straight, which would not work out too well on a sedan. (Can't speak for the 5 door.)
John
Old 04-13-2013, 11:47 AM   #68
ZURCALED12
Member#: 309754
Ice Silver Metallic
News OEM camera wiring.
I am waiting for the lift gate garnish with the cutout for the camera. Once it comes in I will post pictures on the entire retrofit. My OEM Ice Silver Metallic garnish I am going to sell. I also found out that there is no need for a DC to DC converter, the camera will operate on the 13.8V that the car supplies. I need to find out which is the camera video ground? I think that it's the brown wire on the harness. The black wire should be regular ground for the circuitry of the camera.
RED +12V
BROWN video - Ground feed to H.U.
YELLOW video + Positive feed to H.U.
BLACK - Ground
Old 05-01-2013, 10:39 PM   #69
ZURCALED12
Member#: 309754
Ice Silver Metallic
News Correct Back Door Cord
Well, finally the correct back door cord assembly is this one: 81812FJ090 okay, it's not cheap! @ Heuberger Subaru it will cost you $74.44 ouch! it has the connector for the camera on it.
The camera as you already know is: 86267FJ000 and it's a whopping $234.47 double ouch!
The garnish is: 91111FJ180NN and it cost $78.05
The cost for going OEM is very expensive, but if that is what you like and don't mind paying for it, here you go.
Old 05-27-2013, 04:16 PM   #70
ZURCALED12
Member#: 309754
Ice Silver Metallic
This is the connector inside the RIGHT REAR pillar that houses the OEM camera connector. It does NOT have the wires present for the OEM camera. They will have to be added on the GRAY connector. The XV OEM harness attaches to this connector here.
Old 05-27-2013, 04:20 PM   #71
ZURCALED12
Member#: 309754
Ice Silver Metallic
This is the CAMERA connector for the OEM camera, it must be purchased seperately to ADD the OEM camera. It's on the "CORD BACK DOOR 1" harness from www.huebergersubaru.com
To some this is a little extreme to get the OEM camera installed, but I see it this way if the OEM camera fails I can always get it through the dealer and use the part number. If use an aftermarket camera there is a chance that it can be discontinued.
Old 05-27-2013, 04:40 PM   #72
ZURCALED12
Member#: 309754
Ice Silver Metallic
The "BS" part No. 81812FJ030 harness is what my car came with, the "BU" part No. 81812FJ090 is what I replaced it with. It's the XV and the 2013 Impreza 2.0i with OEM back-UP Camera harness.
Old 07-14-2013, 03:57 AM   #73
cnunez13
Member#: 195460
2013 Impreza Sport
man anyone in the bay area want to help me install this? dont know electronics at all -_-
cnunez13 is offline   Reply With Quote
Old 07-19-2013, 05:08 PM   #74
Lv4toys
Member#: 338495
2013 XV Crosstrek
Tangerine Orange Pearl
Zurcaled12:
Nice clean install. I am in the process of doing the same install on my 2013 Crosstrek. One question: What size pins did you use to populate the gray connector inside the right rear pilar?
Thanks
Pat
Lv4toys
Lv4toys is offline   Reply With Quote
Old 07-19-2013, 05:09 PM   #75
Lv4toys
Member#: 338495
2013 XV Crosstrek
Zurcaled12:
Thanks
Pat
Lv4toys
Retrofit rear camera into 2012 Impreza? BrysImpreza Car Audio, Video & Security 231 01-01-2016 08:00 PM
OEM Camera in 2012 Impreza Waterlogged Car Audio, Video & Security 16 07-15-2012 08:23 PM
OEM Sirius in 2012 Impreza Waterlogged Car Audio, Video & Security 0 03-24-2012 11:49 PM
FS : OEM 2012 impreza hatch splash guard 2012WSP Exterior/Styling 1 03-24-2012 10:16 AM
PCSing back to USA; cross country ride in 2012 Impreza or 2012 Odyssey? tlminh Newbies & FAQs 11 03-14-2012 03:03 PM
