Old 05-10-2012, 09:30 PM   #1
punk
Member#: 169792
2005 STI
Default 2009 Legacy - Wheel Bearing issue?
I know OT don't Subaru in public to often, but maybe you guys are feeling nice tonight
My wifes car started making a "growling" noise from the front right at ~65MPH, which I would immediately say is the wheel bearing, but there is another symptom. Most of the time, along with the noise, the steering wheel shakes. This happens both at speed and while braking once the symptoms have started.
I drove it for a while, and not once under 65 did the noise/shaking start, but sometimes (maybe 50%?) after it started, it would continue down to ~40-45 mph then completely go away until back up to 65.
The shaking and disappearing have me a bit stumped. We tried swapping wheels (summer/winter) and the problem persists. She brought it to one dealership today who suggested resurfacing the rotors and new pads along with a flat spot in the tire. I'm a bit limited in my trouble shooting abilities currently because we just had a new driveway put down yesterday so I can't drive the car on it or drag the jack over it (and would rather not work in the road).
Any ideas before we bring it to another dealership, mighty OT?
punk is offline   Reply With Quote
Old 05-10-2012, 09:32 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
XanRules is offline   Reply With Quote
Old 05-10-2012, 09:34 PM   #3
motorpotor
Member#: 126425
2006 Planet Earth
Growling...so hot
motorpotor is offline   Reply With Quote
Old 05-10-2012, 09:35 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by motorpotor View Post
Growling...so hot
If someone ran over both of your hands, they would be doing a public service.
Old 05-10-2012, 09:38 PM   #5
Mitch
Member#: 1535
2006 OBP LGT LTD Wgn
HRSC 01
Mitch is offline   Reply With Quote
Old 05-10-2012, 09:39 PM   #6
Tweeter
Member#: 162238
Sounds like you need an alignment, bushings, wheel bearing, and hub most likely. A mechanic would know best.
Tweeter is offline   Reply With Quote
Old 05-10-2012, 09:42 PM   #7
godfather2112
Papi Chulo
Member#: 53794
.... Clinton was
behind the Harambe murder
Bitch, are you retarded? What part of OT don't Subaru do you not understand.
godfather2112 is offline   Reply With Quote
Old 05-10-2012, 09:43 PM   #8
Meat Supply
Member#: 137902
---- among the
lost we all shall survive
weird. that almost doesn't seem like a wheel bearing. The noise at speed kind of does, but if it's making noise in a straight line, it probably wouldn't just do it at higher speeds. Usually you can hear it wind down when coming to a stop if it's not load dependent noises from turning.
but the shaking? I've had wheel bearings do some weird stuff, but don't remember much shaking beyond the normal vibration.
well good luck anyway.
Meat Supply is offline   Reply With Quote
Old 05-10-2012, 09:53 PM   #9
FellowTraveller
Member#: 161570
2007 Impreza
Newport Blue Pearl
if its an automatic, it could be the clutchplates and throwout bearings, maybe even corrosion on your purple bellhousing.
or its probably a loose distributor cap and rotor-button. Check your magneto packs and use bias-ply tyres (not tires). Fill the tank with leaded petrol (not 91 grade gas).
Or - check and replace wheel bearing and tie-rod-end (to do so - lift the front of the car, grab each wheel with both hands by horizontal sides, pull and push. Repeat with hands on top and bottom. If movement happens, find the component with jiggle, there you go done. Don't forget that breasts feel nice when you gently squeeze them, nipples have appeal as well.
Taste eggnog during the holiday season. Don't forget that jesus died so you could have no noise at 65mph. I am sober and accept your apology.
FellowTraveller is offline   Reply With Quote
Old 05-10-2012, 11:15 PM   #10
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
I can see a wheel bearing causing those symptoms, especially if it's loose and causing the brakes to drag. Jack up the car, grap the wheel top and bottom and wiggle. If there is any movement, the bearing is shot.
Note that if it's tight, it doesn't necessarily mean that it's still OK. I've had bearings that were loose but silent, and bearings that were noisy but tight.
How many miles? I don't know about the fronts, but the rears are covered under your Powertrain warranty.
t3hWIT is offline   Reply With Quote
Old 05-10-2012, 11:16 PM   #11
Beer:30
Member#: 80192
2004 subaru
JBP
rawr!
Beer:30 is offline   Reply With Quote
Old 05-10-2012, 11:19 PM   #12
FellowTraveller
Member#: 161570
2007 Impreza
Newport Blue Pearl
I just had a front wheel bearing replaced under warranty (4.9 year old car with I think slightly more than 50,000 miles on it)
Read my post above - the answer is within
Old 05-10-2012, 11:34 PM   #13
Beer:30
Member#: 80192
2004 subaru
JBP
2004 Sti Wheel Bearing Issue? BritSti Warranty Issues & SOA Problems 6 10-01-2003 10:00 AM
Wheel Bearing issues? SOA releases new "procedures" Opie Brakes, Steering & Suspension 1 09-18-2003 02:28 PM
Alignment or Wheel bearing issue? BritSti STi Forum Archive 4 08-14-2003 11:11 AM
Rear Wheel Bearing Issue minx Normally Aspirated Powertrain 20 05-01-2002 04:24 PM
