Old 05-11-2012, 12:42 AM   #1
ironhydroxide
Member#: 90862
1989 xt6
red
Default question on EJ20G/EJ205 Throttle Body
SO the car:
EJ20G engine running APEXi PowerFC Controller (a bit less finicky i would say)
the goal:
Install EJ205 Throttle body (and modified intake manifold) sensors and IAC.
The question:
Does the APEXi read just TPS Voltage, and doesn't care about idle switch (currently a 4 wire sensor)
what's the difference in IAC's
and, theres a MAP sensor there (i think) should I run it instead of the Stock EJ20G MAP? is it possible?
thanks for any input.
ironhydroxide is offline   Reply With Quote
Old 05-11-2012, 12:48 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
wont work
sell the pfc, g merge, heads/intake/etc and get a full 205 swap
eg33GC is offline   Reply With Quote
Old 05-11-2012, 12:59 AM   #3
ironhydroxide
Member#: 90862
1989 xt6
red
thanks for citing proof....
(one more chalked up to the "this is the answer because i say so")
Old 05-11-2012, 01:11 AM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
good luck buddy
Old 05-11-2012, 03:20 AM   #5
ironhydroxide
Member#: 90862
1989 xt6
red
Yet again i'm reminded why I don't frequent NastiCock
Old 05-12-2012, 03:00 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
This is the answer because I say so. He's right, it doesn't work.
Old 05-13-2012, 04:30 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
SO the car:
the goal:
The question:
This question belongs in engine management/tuning. Pretty sure this is not the forum for Apexi tuning.
TommyAtomic is offline   Reply With Quote
Old 05-13-2012, 09:11 PM   #8
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Then why don't you **** off if you don't like the answer to your question.
i_c_the_light is offline   Reply With Quote
Old 05-14-2012, 07:20 AM   #9
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
How about yes... Is that a better answer?
wrxlaunch is offline   Reply With Quote
Old 05-14-2012, 09:01 AM   #10
ironhydroxide
Member#: 90862
1989 xt6
red
Honestly, I could care less if its YES or NO..... What i'm here to know is WHY it will or wont work.
and when you are looking for information, and all you get is.
NO.
or
YES.
Well, it doesnt' really help you much.
Old 05-14-2012, 10:41 AM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
Nasioc is huge. Every question you could ask has been asked 100 times already. You didn't use the search function so be grateful we even took the time to answer no.
Old 05-14-2012, 10:58 AM   #12
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
NO.
or
YES.
You should prob refer your questions to apexi... Just a thought. Help us help you by using all the resources available to you; by relevance. Then come on here if you wld like after, to see if someone else has had a similar issue and how they solved the prob.
Old 05-14-2012, 03:06 PM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
this subforum is by far collectively the one that is populated by people that have done above and beyond 99% of the bros on nasioc.
we don't spoon fed, nor do we expect it.
We answered your question. We don't care if you don't understand why.
Old 05-15-2012, 01:00 AM   #14
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
I am assuming we are talking about USDM WRX EJ205 here, and say we you were going to swap intake manifolds
the intake, wiring, sensors, etc, are all totally different. allow me to count the ways.
IACV is TOTALLY different, mounted in a different place, with different mechanisms. also it will get in the way of the TMIC probably.
EJ20G does not have a MAP in the same sense as a EJ205.
EJ205 throttle is mounted/oriented the opposite way as the EJ20G.
EJ205 has TGVS, EJ20G does not.
EJ205 has straight entry turbo inlet, EJ20G is angled (top entry)
wiring routes differently for both.
also, the EJ205 intake manifold will NOT physically bolt to EJ20G heads. (phase 1 DOHC vs phase 2)
so, do you need more reasons?
having said all that, in the case of just wanting to switch to an EJ205 throttle body, which I cant imagine why you would want to... the answer is no, you cant practically.
if you simply need an EJ20G throttle body and are having trouble finding one, i have one for sale
this.
i hate every other section of NASIOC except this one, because this is the only one that has actually knowledgeable down to earth people.
elislider is offline   Reply With Quote
Old 05-15-2012, 01:07 AM   #15
eg33GC
Member#: 206851
56 Belair
Pro Street
I've thought about figuring out a way to modulate the idle switch in the tps, instead of using the integrated one.
I always have a pita adjusting the tps.
DBW 2.5 liter throttle body question No Limit Motorsport Built Motor Discussion 5 05-10-2012 05:40 PM
FS : Various stuff on eBay. DBW throttle body, OEM bypass valve, TGV servos sensors, more JSiwek Engine/Power/Exhaust 0 04-15-2011 06:41 PM
Here's the final wiring question on EJ20G smacksube Subaru Conversions 22 01-21-2004 10:01 PM
injector question on EJ20G 99WRXEJ20 Subaru Conversions 1 12-11-2003 04:24 AM
Question on the subaru stock body kit Wrx0R Interior & Exterior Modification 2 10-16-2001 03:13 PM
