Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 06-01-2012, 06:37 PM   #76
RallyNavvie
Member#: 7113
2008 Spec B
Originally Posted by aggie113 View Post
FYI, kick ass 1911's are up for grap at a kick ass charity raffle:
http://karashope.weebly.com/turnbull-1911-raffle.html
Those remind me of the 1911 my grandfather carried through WW2. He was a paratrooper in the 504th PIR and that gun was with him all through Europe and north Africa (along with his .30 carbine). He gave them to my uncle who eventually pawned them when he was running low on money. Really, really wish I could get those two guns back
RallyNavvie is offline
Old 06-03-2012, 12:23 AM   #77
txjunglist
Member#: 11926
2011 Outback Limited
Dark Grey
Just picked up a Rem 700 SPS tactical 308 today. Got some leupold mk4 rings and TO bases coming. hopefully it's a 1/2 moa gun out of the box like I have read. Glass is a Nightforce 5.5x22x50 illuminated ret mil dot. I have sooo much work to do on this gun. my first bolt gun ..got my fingers crossed
txjunglist is offline
Old 06-03-2012, 12:46 AM   #78
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
You picked a nice one, though. The 700 SPS is a great rifle. Make sure you stick with a good ammunition to both sight your rifle in and then continue to use for the most consistent grouping.
I made the mistake of switching ammos too much to try and find the best, when I should have just stuck with the Hornady Sierra Match Kings I used first and use now. Would've saved me a lot of money and headache if I had just started with those in the beginning.
Spider Pig is offline
Old 06-03-2012, 07:47 AM   #79
Shotskees
Member#: 301185
2006 Cobalt SS
Yellow
I have one of those, I posted a pic of it earlier in this thread. It's an awesome gun, I love mine to death. Good luck!
Shotskees is offline
Old 06-03-2012, 01:58 PM   #80
RallyNavvie
Member#: 7113
2008 Spec B
Or make your own
Old 06-03-2012, 08:26 PM   #81
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
Here are my 3 I use regularly...Top to Bottom
Marlin 30-30
Savage 12gauge
AK-47
I also have, not pictured, another 30-30, 2- 22 rifles, a British Enfield 303, a Taurus .38 special, and a WWII S&S .32 nazi officer side arm.
Twiztidunreal is offline
Old 06-04-2012, 06:41 AM   #82
txjunglist
Member#: 11926
Dark Grey
Originally Posted by RallyNavvie View Post
Or make your own
this
Old 06-04-2012, 08:03 AM   #83
RallyNavvie
Member#: 7113
2008 Spec B
this
I almost have to reload. I'd go poor trying to feed my .300 WM match-grade ammo. I usually burn through 50-100 rounds when I go to the range, and that's at least once a month. That's why I'm leaning toward getting a .308 next and load subsonic. Less powder will eventually show as savings, and I'm probably just going to stick to 100-200 yards on that gun and leave the cannon for longer ranges.
Old 06-04-2012, 04:45 PM   #84
txjunglist
Member#: 11926
Dark Grey
my buddy suggested 190 gr sierra match king and running them subsonic. he says they are really quiet. of course he's suppressed .
Old 06-04-2012, 11:05 PM   #85
Subaru_Freak
Member#: 25667
2011 STI 5-Dr.
PBP
Subaru_Freak is offline
Old 06-05-2012, 07:46 AM   #86
RallyNavvie
Member#: 7113
2008 Spec B
Originally Posted by Subaru_Freak View Post
I considered the AI platform for a bit but didn't want to tie up that much in a single rifle. At that stage you almost have to mount S&B or USO glass on it. And there's always a fear of being called an "awp whore" at the range
I'm thinking the next box of 500 Sierra MKs is going to be of the 190gr variety. Looks like those will work for 200+ with the .300 WM and make for decent .308 subsonic rounds. Does the .308 use Federal 210M primers or can I feed it some of the 215Ms that I'm using for the .300 WM?
Old 06-06-2012, 12:39 AM   #87
Subaru_Freak
Member#: 25667
2011 STI 5-Dr.
PBP
You can use Mags in non-mag calibers, just start a grain down and work up. They will change the groupings.
Old 06-06-2012, 01:31 AM   #88
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
I've always been under the assumption that using mag primers in non-mag calibers could cause dangerous changes in pressure inside the casing due to faster ignition of the powder. Dropping a grain down would help, but wouldn't you still be risking more rapid detonation of the powder in a more enclosed environment, and wouldn't that still be dangerous?
I could be completely off on that, but I would just spend the $40 for 1000 non-mag primers if it were my gun. My reloading isn't up to Garrett's ability, especially since I reload much more handgun ammunition than rifle, but I still would rather be safe than sorry.
Old 06-06-2012, 07:39 AM   #89
RallyNavvie
Member#: 7113
2008 Spec B
The reason I ask is because I bought a case of 5000 Federal 215Ms last year when primers were scarce. I've heard mixed reviews of the use of mags in non-mag reloads. It probably wouldn't hurt to use a slower-burning powder like I do in the .300. It isn't a big deal to get a case of 210M though, they aren't that expensive and they seem to be more common than the magnum versions.
Old 06-06-2012, 08:05 PM   #90
Subaru_Freak
Member#: 25667
2011 STI 5-Dr.
PBP
You can interchange them, but it's wise to drop a grain or two before working back up. In a rifle, the primers will chrono slightly faster, but it's not majorly significant. In a handgun, you can easily interchange between the two with no change.
Most of the difference is the ability of the primer to withstand higher pressures in the flash hole and resist deformation / blow-out.
It's common to even use rifle primers in handgun calibers like 9mm Major.
Old 06-06-2012, 08:06 PM   #91
Subaru_Freak
Member#: 25667
2011 STI 5-Dr.
PBP
Match primers give a much slower burn rate from my experience than a standard primer.
Old 06-06-2012, 09:02 PM   #92
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Recently got a Big Chubby and tried it out on the AR-10. Helps alot with recoil but is tons louder and a nice slap to anyone standing off to the side .
Also got a Magpul ACS-L installed, going to try to shoot it this weekend, it's much more sturdy than the stock butt stock and hopefully better in other ways.
aggie113 is offline
Old 06-07-2012, 02:52 AM   #93
Spider Pig
Member#: 82323
I'm a lead farmer,
mother****er!
Got a question for the fellow reloaders here. I'm using nickel plated brass casings for my .40 S&W +P loads since the metal is harder than standard brass. Do I still get the same amount of reloads out of them as the regular eight times for brass? Or can I reload them more since they're a stronger case and are subject to less metal warping?
Old 06-07-2012, 03:58 AM   #94
mightymints
Member#: 252858
2015 STi WRB/Gold LE
2013 WRB STi 5dr Stage1AP
Anyone have a spare Aimpoint T1 2moa that they would like to trade for a LMT 14.5 inch upper with a KAC RAS?
mightymints is offline
Old 06-07-2012, 07:45 AM   #95
RallyNavvie
Member#: 7113
2008 Spec B
I use the nickel-plated casings I got from a couple boxes of Federal Premium (I think you shot some of them) for hunting loads because the nickel is less likely to tarnish in those conditions. I've heard from some people not to bother with them at all, or if you do to limit the number of times you reload them. I'd worry the nickel plating covers up weak spots in the brass so that you don't notice them.
I don't see why you couldn't continue to use good brass for +P. You may not get the same number of reloads from them (not sure how pistol brass flows/trims) but seems like you won't from the nickel-plated either. If you're going to keep them in a leather bandolier then yeah, go nickel
Old 06-09-2012, 01:33 PM   #96
RallyNavvie
Member#: 7113
2008 Spec B
I might be headed out to Gibson's when they open tomorrow if there are any others interested. I think they open at 10am.
Old 06-20-2012, 02:23 AM   #97
BlueLGT
Member#: 247590
2010 Legacy GT
I bought this on Monday. Smith and Wesson M&P 15-22.
BlueLGT is offline
Old 06-20-2012, 02:51 AM   #98
rickross
Member#: 312764
2008 wrx
we need to make a gun range day/meet. it'd be cool to have alot of subis and alot of guns lol I have a s&w mp15 with tons of mods on it.
rickross is offline
Old 06-20-2012, 08:47 AM   #99
BlueLGT
Member#: 247590
2010 Legacy GT
What mods have you done?
BlueLGT is offline
Old 06-20-2012, 11:11 AM   #100
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
I thought I wanted an M&P Shield for a pocket gun
but now I want this (Springfield XDs):
TyrannoSullyRex is offline
Closed Thread
Fortune Auto Coilovers ROUND 2!! Round 1 Pics are UP! 7L Autosport Vendor 'Group Buy' Classifieds 114 12-17-2011 05:39 PM
BLOW OUT SALE ROUND 2! Gaskets, 2.5 Short Block, JDM TGV's, 08 SPT Catbacks!!! RenickMotorsports Engine/Power/Exhaust 10 05-17-2008 01:44 PM
fp green/2.0...round 2 rallyrab Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-15-2007 01:04 PM
Round 2 Headlight covers for queen/rallispec meet. munkis Tri-State Area Forum 8 02-07-2002 05:48 PM
Me vs. Weapon*R intake round 2 AccidenT Normally Aspirated Powertrain 3 12-18-2000 12:27 AM
