Old 05-12-2012, 12:53 PM   #1
CSibbs
Member#: 262532
'12 STi (R.I.P)
Dark Grey Metallic
Default Accessport on 2012 STI and catless dp
Hello nasioc, im in the process of purchasing a 2012 Sti and was going to do a catless downpipe and a stage 2 tune.
Question is will an ots Cobb map be able to clear the cel I will get with my downpipe being catless? Or would I have to get a protune?
CSibbs is offline   Reply With Quote
Old 05-12-2012, 12:59 PM   #2
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
The Cobb OTS map is for a catted downpipe ... so you will want to look at other tuning options.
Also, and this is just my 2 cents, I would go with a catted downpipe on a 2012. The newer WRX/STi are notorious for boost creep issues when running catless.
You only loose a couple HP between a high flow catted and catless downpipe, and help prevent a potential issue from occurring .. up to you though.
GrumpyPitbull is offline   Reply With Quote
Old 05-12-2012, 01:10 PM   #3
CSibbs
Member#: 262532
'12 STi (R.I.P)
Dark Grey Metallic
Well to be honest the only reason I was going to go catless was because of the $300 difference. I figured since I dont have to be inspected for 4 years with a new car I can get away with catless for 4 years. But I guess I will just go with a catted dp. More than likely, invidia though
Old 05-12-2012, 02:10 PM   #4
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
some guys running cattless and cobbs stage 2. i have my cattless DP on the way, i cant justify spending 600 bux for a catted dp. i will see how bad the creep is, if any..
BigRob74 is offline   Reply With Quote
Old 05-12-2012, 04:31 PM   #5
CSibbs
Member#: 262532
'12 STi (R.I.P)
Dark Grey Metallic
Exactly haha
Do you think it will throw a code?
Catalyst insufficiency?
Old 05-12-2012, 04:36 PM   #6
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
Originally Posted by CSibbs View Post
Exactly haha
i hope not, from what i read the AP is supposed to fix that issue..
Old 05-13-2012, 12:25 AM   #7
GrumpyPitbull
Member#: 313311
2012 WRX 5 Door
Plasma Blue
And these are probably the same guys posting in here about blown ringlands, boost creep, and other issues. Can you try the Cobb OTS with a catless DP? Sure you can ... but I would log the crap out of it afterward, and just plan for things to not be set up right. If your going to go catless, get a tune for a catless DP ... not an OTS for a catted DP.
I realize the catted DP's are more expensive, but are you really going to sweat about an extra 200-300 bucks on your 30k-40k car?
Old 05-13-2012, 08:29 AM   #8
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Keep in mind that a catless DP on these cars can potentially result in boost creep that cannot be tuned around. That is, you can potentially overboost even if boost control is disabled (wastegate duty is zero). That means no tune is going to fix it (the ECU has no control over your peak boost at that point) and you would have to go with a mechanical fix (catted DP, port WG, or EWG). The problem gets worse with colder outside temps, so you might find that it works fine now and then you experience the problem in winter.
It isn't an absolute certainty that you will see boost creep with a catless exhaust. But it is a much, much greater possibility that with catted. The colder the temps you see, also increase the chances. The power difference is minimal at stage 2 levels, so it makes sense to consider a catted exhaust and that is why we recommend them for any 2.5L stage 2 car, regardless of what map you are running.
Bill
Old 05-13-2012, 08:37 AM   #9
BadTrainDriver
Member#: 201416
1998 Impreza L
Leave it stock, or goodbye warranty.
If you choose to mod, don't come crying to us when it breaks and SoA won't help you.
BadTrainDriver is offline   Reply With Quote
Old 05-13-2012, 08:51 AM   #10
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
Bill
what about cars running stock intake and exhaust? i keep reading that the intake with a cattless downpipe increases the chance of creep, any truth to that? have you guys tuned cars with cattless DPs?
Old 05-13-2012, 09:13 AM   #11
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
An aftermarket intake can also increase the chance of boost creep, although not to the same degree as a catless DP.
Our shops do custom tunes on a daily basis and deal with this issue all the time. Sometimes you get catless cars where it isn't a problem. Sometimes it is a major problem and there's no way you can tune around it and a mechanical solution is the only possibility. In some rare cases, you can even see it happen with catted cars. It really just depends on the car itself, the conditions its sees, and the mods (especially catless vs. catted).
Bill
Old 05-13-2012, 09:59 AM   #12
bacalhau16
Member#: 297565
2011 WRX hatch
I have an aem cold air intake and a stock exhaust. I just went stage 2 and installed a catless dp. I haven't had any issues yet. I have no intentions on getting a full exhaust and am content with the improved sound now.
I went with a cheap dp because if it did overboost, it would been installed and returned to stage 1.
It sucks that there is no consistent and going stage 2 is a bit of a gamble. Some cars have issues, others don't.
bacalhau16 is offline   Reply With Quote
Old 05-13-2012, 11:27 AM   #13
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Increasing exhaust back pressure is a means of reducing the chance of boost creep. So, just as a catted DP reduces the chance, the stock catback (vs. aftermarket) will reduce the chance (maybe to a lesser degree than the catted DP). So, a catless DP with aftermarket catback has a greater chance of the problem than a catless DP with stock catback. But, generally, a full turbo-back catted aftermarket exhaust has a very minimal chance of boost creep which is why we recommend that combo for stage 2 (vs. any catless configuration).
Bill
Old 01-29-2013, 08:55 AM   #14
gilroy408
Member#: 345275
2012 STi
Silver on Gold 18" BBS
I'm running catless dp full 3" tbe straight pipe cobb stage2 intake on my 2012 STi with no problems
gilroy408 is offline   Reply With Quote
Old 01-29-2013, 10:21 AM   #15
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Some won't have any boost creep issues with a catless DP + intake - it depends a lot on your climate. In fact, you could have no issues at a higher temperature (or a less noticeable overboost) and then significantly overboost if the temperatures were to drop quite a bit. So, as a fake example, you could run fine at 60 degrees, but severe overboost at 20 degrees.
Boost creep usually occurs at higher RPM, so you might not be exceeding your peak boost target, but your boost may not taper at higher RPM like it should. That would be a case where things might appear to be fine, but you are actually overboosting at higher RPM. Data logging is the best way to see how things look.
Bill
Old 01-29-2013, 12:36 PM   #16
Delphi
Member#: 239335
2011 WRX
My vf52 which is essentially the same turbo with a different cold side hasn't boost creeped with a catless downpipe, aem intake and in -30C weather. And yes I do data log. But I do have a torqued performance tune. Not cobb. According to Eric @ Torqued Performance he says he hasn't seen anyone boost creep with a stock intake and catless downpipe. And the ones that do creep are Invidia and Tsudo downpipes with a Cold air intake.
Delphi is offline   Reply With Quote
Old 01-29-2013, 12:53 PM   #17
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
With actual severe boost creep, tune is irrelevant as you will overboost even at 0% wgdc. We have definitely seen cases of boost creep with stock intake stage 2 GR WRX, but certainly not anywhere near as common as aftermarket intake with stage 2. It is a combination of factors (not one thing) that increase the chances of boost creep on a stage 2 car: 1. aftermarket intake 2. DP design (some designs appear to be worse than others 3. catless DP 4. cold outside temps 5. higher atmospheric pressure (i.e. those near sea level). That doesn't mean if you have some of these factors, that you will see boost creep. It is more the combination of these factors (and severity of each where applicable). For example, at our Portland OR Cobb location we see many more cases of boost creep than at our Plano, TX location and that is due just to environmental factors.
At 0% wgdc, about the only thing you can do as far as the tune is concerned when boost creep is still an issue is to modify the throttle mapping to close the throttle at WOT to try to mitigate it.
Bill
Last edited by Cobb Tuning; 01-30-2013 at 09:33 AM. Reason: clarified statement about boost creep and tuning
FS : 2012 WRX Invidia CATLESS DP + COBB SRI 2012 Rex Engine/Power/Exhaust 20 05-05-2012 01:02 AM
WTB : Accessport V1 and catless DP 2005 wrx :D 6h05twrx SCIC Private Classifieds 1 08-09-2010 03:58 AM
NOVA: FS: sti injectors, catless dp, sti strut top mounts wytewrx06 MAIC Private Classifieds 9 04-10-2009 09:27 PM
WTB: catless UP and Catless DP Weempster101 Private 'Wanted' Classifieds 2 10-17-2008 04:30 AM
WTB: 05 STi Accessport and Catless DP w/ bung FluxXxSTi Private 'Wanted' Classifieds 2 05-17-2007 10:22 PM
Message Board Statistics All times are GMT -4. The time now is 09:23 AM.
