Old 05-13-2012, 07:46 PM   #1
jdmjack
Member#: 248430
2003 PSM Bugeye
Default Dealer service
So my 03 wrx just passed 75k and I'm wondering I should get the 75k service. I know alot of guys are big diy people when it comes to any and all maintenance but my knowledge and skills don't go far beyond oil changing and some engine mod installs.
The 15K service (75K) includes:
oil conditioner/cleaner
fuel system cleaning
air filter replace
top off all fluids
rotate tires and set air pressure
cabin air filter replace
service front and rear brake pads and rotors
check axle boots front and rear
check operation of clutch
inspect steering and suspension systems
I have the following mods on my wrx all of which are roughly 10-12k miles old.
-turbo xs catless bellmouth downpipe
-Invidia N1 race catback
-Sti topmount
-Turbo xs short ram
-cobb accessport 93 tune
along with upgraded clutch, coilovers, wheels and tires. I have yet to take it to a dealer since I've owned it (just over a year and about 10k miles) and I'm not sure if the previous owner did. So ultimately what I'm asking is, should I take it in to get these things checked out or should I wait until the 105k service? Is all of it necessary or are there a few main things I should get checked out versus having it all done?
jdmjack is offline   Reply With Quote
Old 05-13-2012, 08:58 PM   #2
Supraru
Member#: 23313
99' 2.5Rs
black
air filter replace
top off all fluids
Depends on your skill level
-Oil conditioner is just an additive they add in your oil change
-Fuel system cleaner cleans carbon off your upper pistons and they put a bottle in your tank to help clean the injectors. Basically seafoam.
-Air filter is obvious and easy
-Top off fluids is washer solvent, sucking out brake fluid from the resovoir and adding fresh fluid to it. At our dealer we drain the coolant and put in fresh coolant
-Service front and rear pads to me sounds like lubing the slides which isn't a bad thing
-chicking axle boots and clutch operation is self explanatory.
There really isn't much on there that is difficult to do or worth the money you'll pay unless you are unable to do it yourself.
Supraru is offline   Reply With Quote
Old 05-13-2012, 09:57 PM   #3
scarney1988
Member#: 317760
As a dealer tech for 5 years (for toyota) here is what I would recommend.
  1. Buy the fuel treatment and add it into the tank. Follow instructions on bottle, to the T. Nothing major, but chem. engineers develop instructions for a reason.
  2. Purchase oil system cleaner. Add after getting oil change.
  3. Get an oil change and tire rotation at dealer, or independent service shop, and tell them to look it over. Believe me, if you need brakes or axles or suspension they will say something. That is how techs get paid. Brakes dont need service unless there is a problem (noise, uneven wear, low pad life).
  4. Request engine air filter and cabin air filter replacement. If you feel capable of performing these services definitely get both filters and put them in yourself.
  5. If you had a problem with steering components... you would probably notice. there would be play in the wheel or noise or something. The tech, if he is good, will notice anything that is wrong with your steering components. If your clutch had an issue, it would be slipping by now. If its not slipping, it must be good and any tech would be nuts to tell a customer there clutch is in need of replacement when it works fine after 75k.
I guess just trust that the machine is set up to sell you parts you may, or may not, need. Even a trustworthy mechanic only makes money selling you parts you need. The above is my advice to you. Otherwise, just pay for 75k and hope you get what you pay for. I know I always used maintenance list a check sheet, but I cannot say the same for all my coworkers.
G-luck, hope this helps.
scarney1988 is offline   Reply With Quote
Old 05-14-2012, 11:06 PM   #4
jdmjack
Member#: 248430
2003 PSM Bugeye
Thanks for the advice guys
Old 05-15-2012, 08:30 AM   #5
AZP Installs
Member#: 40160
At 75k there are no major services. Essentially if you completed the 60k, it would be a tire rotation and oil change at 75k. Next major after 60k is 90k. Check our maintenance page on our website for what we include.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
anyone here a service advisor/technician for a dealer service department. tacomaprime Off-Topic 13 07-25-2006 01:32 AM
Dealer service depts? FUBAR North West Impreza Club Forum -- NWIC 2 06-14-2001 08:44 AM
Good Subaru Dealer Service Departments? briank New England Impreza Club Forum -- NESIC 2 03-23-2001 12:09 AM
Anyone have Subaru dealer service coupons? kevinsUBARU New England Impreza Club Forum -- NESIC 7 02-04-2001 01:21 PM
Dealer Service mhj New England Impreza Club Forum -- NESIC 6 11-30-2000 04:58 PM
