Old 08-26-2002, 11:18 AM   #1
Ryan23
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Default My VF34 Dyno Results are in!
Well, after a weekend in MD, the guys @ TurboXS got my car straightened out. First off, many thanks to Phil and Nathan. They are great guys and kept me in the loop on everything. Their approach was very methodical and I was asked for input on everything. The shop was top notch and I am very pleased to say the least. The Utec worked flawlessly and gave me what I was looking for......Consistency.
Ok, on to the run. I had a conservative tune put on her for now, just looking to see what 93 octane Exxon gas would do. The dyno sheet below indicates that. Timing was conservative and she is running a healthy 10:5~11:1 A/F. There is no knock as evidenced through a headset attached to a stand alone knock monitor. Very precise and it left me with a good feeling. There is plenty of room to grow here with my map. Keep in mind, this run was also done through a catalytic converter. Mods are:
TurboXS UTEC
VF34
MRT FMIC w/unifilter
STI Injectors
Walbro Fuel pump
Blitz SBC-ID EBC (For the moment) @ 20.5 PSI
TurboXS Turboback
Vishnu Uppipe
Vishnu Pulley
EGT/AF/Oil Pressure/Boost gauges
The car is running great and the power is very linear. None of the peakiness I was experiencing before tuning with the S-AFC. Stock Driveability is very much preserved. I won't comment too much on the Utec other than to say you will be very impressed once it is formally announced. It is a DIY tweaker's dream. Very easy to use and the data logging function is fast. Incidentally, my Blitz was reading 1 PSI off and the Autometer Electric Boost gauge was consistently within 1/2 pound of true boost. Not bad for an Autometer. My Greddy A/F was reading 2 A/F points richer than it should have been . Not good if you're tuning on the street/strip. It can be adjusted, I'm going to work with it or invest in a decent wideband if all else fails. I also did some beta running of my propane injection kit. Initial results weren't spectacular (+15HP/+12LBS/FT), but it's work in progress. I will have some more dyno pulls with that once I get a few more details worked out. I plan on releasing a WRX specific kit when everything gets sorted and I have some solid #'s to back it. Once again, thanks to TurboXS for the great tune!
Ryan
Utec'N It
Ryan23 is offline   Reply With Quote
Old 08-26-2002, 12:01 PM   #2
Tronner
Member#: 12845
2008 BMW 335xi
Sparkling Graphite
Ryan,
Great numbers!
I'm just curious since I have the SBC-id as well, when you say it was off by 1 psi was it reading 1 psi low or high? I would assume low, since mine reads lower than my VDO gauge. Also, it says you have the SBC-id "for the moment". Do you plan on getting rid of it? If so, why?
Thanks
Tronner is offline   Reply With Quote
Old 08-26-2002, 12:07 PM   #3
Tronner
Member#: 12845
2008 BMW 335xi
Sparkling Graphite
Ryan,
Great numbers!
Thanks
Old 08-26-2002, 12:23 PM   #4
Ryan23
Member#: 15116
EJ257/GT35R
Originally posted by Tronner
Ryan,
Great numbers!
Thanks
It's reading 1 PSI too low. I'm getting rid of the SBC-ID so i can utilize the Utec's closed loop boost control
Ryan
Old 08-26-2002, 12:41 PM   #5
nmyeti
Member#: 4980
Ryan,
I am Glad that you liked the tune; I know I was happy with the results. I think we've given you a great place to start with, and I suspect there is a whole lot more power in your setup for when you ditch the cat and add in the race gas.
I wish you would have been listening to the headphones on the first dyno run, as the detonation would have taken your head off. I suspect that you being 2 points leaner than you thought you were accounted for a good deal of the detonation.
All in all though, I am very happy with the results as your car was just so nice to drive when we were finished with it.
-Nathan
PS, as far as I know thatís the most HP that has ever been made on our dyno though a cat.
nmyeti is offline   Reply With Quote
Old 08-26-2002, 12:46 PM   #6
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
WOOT!!!!!!!!!! Grats man!!!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-26-2002, 12:51 PM   #7
[email protected]
Guest
Member#:
Well done. Looks like a nice linear curve. How does that VF 34 feel? When does it spool and does it pull through redline? How much boost is this on? Thanks.
Mike
VR
Old 08-26-2002, 12:59 PM   #8
Twelvz
Member#: 11302
11 GT-R
10.x @130+
Default AWESOME !
Thats sweet Ryan !
...I'm a week and 3 days away from working with TXS (actually maybe more depending on what they tell me on the phone this afternoon) can't wait to work with the guys to see what the VF22 can do with some Citgo gas !
Twelvz is offline   Reply With Quote
Old 08-26-2002, 01:33 PM   #9
Ryan23
Member#: 15116
EJ257/GT35R
Mike
VR
Mike,
It takes a little longer to spool due to the FMIC, but hardly objectionable. I've attached the chart for the Boost curve on the dyno in 4th gear. It's capable of holding 20 all the way to redline (or pretty damn close). This dyno run was done with 20 PSI dialed in with the Blitz SBD-ID. Next time I head up there I'll be using the Utec to take charge of boost control.
Ryan
Old 08-26-2002, 01:34 PM   #10
Ryan23
Member#: 15116
EJ257/GT35R
Boost Curve:
Old 08-26-2002, 03:46 PM   #11
Imprezd
Member#: 3357
Congrats on the big power man...
I miss power
Imprezd~
Imprezd is offline   Reply With Quote
Old 08-26-2002, 07:58 PM   #12
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
sweeet....can't wait to get my utec!
ScoobieSnaX is offline   Reply With Quote
Old 08-26-2002, 08:53 PM   #13
mlambert
Member#: 13831
GOOD STUFF!!
that curve looks really nice! Id love to take a spin in your car!
Im sure that youre aware of this, but youre getting close to piston meltdown power levels. Ive seen 2 go in my local area in the past 2 months at power levels very close to this. There is an upside to this though...soon there will be TWO STi type RA powertrain conversions in my area
Once again good stuff!!
mlambert is offline   Reply With Quote
Old 08-26-2002, 08:59 PM   #14
Chris-BoT
Member#: 11829
2002 WRX Wagon
Jorge (RiftsWRX)
www.ProjectWRX.com
Jorge - buddy, hate to break it to ya...but it's w00t !..not WOOT...
Nathan - Can you give me some more info on that knock monitor/headphone setup? What does it consist of? I'm very interested in it, especially since I have a lot of tuning to do in the near future, and I'm a rather anti-detonation type of guy...
Chris-BoT
Chris-BoT is offline   Reply With Quote
Old 08-27-2002, 01:04 AM   #15
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default Re: My VF34 Dyno Results are in!
This is disturbing, as I was planning on upgrading my virtually useless Autometer A/F gauge for the Greddy...not so sure I should even bother...maybe Knocklink, EGT, boost, is enough, along with Autometer A/F light show gauge.
annointed is offline   Reply With Quote
Old 08-27-2002, 01:11 AM   #16
TurboWRXImpreza
Member#: 9911
2008 STi
Lightning Red
WOW!! Very nice #'s. I've been looking at that turbo for quite some time now...and the patience has finally paid off...I think I'm pretty settled on this turbo, I know I will be happy with this rather than the 1820 or 1818.
Just a few quick questions though:
1. What fuel management did you use? Can you explain it a little bit more on how you tuned it?
2. You were running 20PSI of boost? was that safe?
Thanks
Ray
TurboWRXImpreza is offline   Reply With Quote
Old 08-27-2002, 11:00 AM   #17
Ryan23
Member#: 15116
EJ257/GT35R
Thanks for the compliments guys, the car is coming along quite well. There is a lot more power to be had here, I'm interested in seeing how hard one of these "tiny IHI turbos" can be pushed. Once I reach that limit, I'll start investigating alternate turbos. It's nice now because I don't have to invest in a custom DP,Uppipe, ETC to make it all work. Not to mention how streetable the car currently is. I'm not too concerned with the block itself yet as they have been proven good to 400HP. Without nitrous, I don't expect to even approach that number with a VFXX.
Annointed - Yes, it was very disturbing for me too! I trusted in it based on other members observations and it could have proven disastrous. On my baseline run I was running 13.8:1@ 4K RPM and dropping down to 12.8:1 @ 4500 to redline. My Greddy was indicating 11.5:1~11:1. This of course varied with whatever timing the stock ECU was in the mood for but it was an average. FWIW, my Greddy is now showing the needle buried @ 8:1 sometimes 9:1 when 2 other W/B's@ TXS showed it running at 10.5:1~11:1. Electromotive is getting ready to release (from what I hear) a new wide band with a display here soon. I think it's priced in the $500 or so range. I would like to bounce it's readings off a known good W/B to see how accurate it is. It might be the ticket for us home tuner types.
TurboWRXimpreza -
1.) I am running TurboXs's Utec system. It offers fixed timing and fuel. There is a ton of "leaked" info regarding it in the thread under FF called "TurboXS new ECU product". It's tuned via a terminal session, IE: Laptop, Palmpilot, whatever app you want that will do terminal emulation.
2.) 20 PSI safe? Well, that's tough to say. All we can base this on is other people's experiences as I have yet to see a compressor map for this turbo. There are a number of cars with VF 30/34's running up to 22 PSI of boost. My EGT's are low (1400~1500), detonation is not present as noted earlier with a specialized headset to listen for this and my Air Fuel ratio/timing is in check. If anything, I have conservative settings. So is it safe? It's as safe as it's going to be in my eyes. Only time will tell. Now with some consistency in fueling/timing I think we will have a better understanding as to what a stock block EJ20 can take before it grenades. If I become a victim, so be it, somebody has to try
Ryan
Old 08-27-2002, 11:16 AM   #18
jesse370
Member#: 12147
2005 g-35
ivory pearl
I would worry about a piston far before the block....I've heard of a few high boost engines popping when they start making bigger power, but I think most of them were still running the stock tmic??
great numbers the more I see and read about this thing the more I can't wait to start pushing my car like that congrats man. You guys that test this stuff have bigger stones that I do.
jesse370 is offline   Reply With Quote
Old 09-07-2007, 04:14 PM   #19
WetDragon
Member#: 152929
2003 JDM STI
sweet results man.. just what im planning to do.
WetDragon is offline   Reply With Quote
Old 09-07-2007, 04:48 PM   #20
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Oldest bump ever?
RexFTW is offline   Reply With Quote
Old 09-07-2007, 09:05 PM   #21
Clark_Kent
Member#: 114299
Originally Posted by RexFTW View Post
Oldest bump ever?
Clark_Kent is offline   Reply With Quote
Old 09-08-2007, 06:06 PM   #22
akturbogti
Member#: 119474
05 Hummer H2
black
Holy..effing...crap......from when the utec was first coming out? LMAO!!!
akturbogti is offline   Reply With Quote
Old 09-08-2007, 06:08 PM   #23
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Sweet dude, did you just buy tickets to the :failboat: too?
cucamelsmd15 is offline   Reply With Quote
Old 09-08-2007, 06:24 PM   #24
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
Hahahah, I started reading the post and started thinking "Did the UTEC get a new firmware update??"
5 years, thats gotta be some kind of record.
On a good note, he must have been using the search button.
scraggy is offline   Reply With Quote
EJ257 vs EJ255 dyno results are in !!!! IA Performance Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 69 03-10-2010 12:37 AM
Dyno results are in.... ChaseHeadrick North West Impreza Club Forum -- NWIC 13 04-21-2009 12:15 PM
'05 2.0L WRX VF34 dyno results Acingteam Proven Power Bragging 17 01-07-2009 01:58 PM
STi dyno results are in... V8VENOM Proven Power Bragging 29 11-24-2003 10:05 AM
SCCA results are in ... and I got first place in my 4EAT Impreza! Jessie James Bay Area Impreza Club Forum -- BAIC 18 06-24-2001 07:09 PM
