Old 05-14-2012, 07:56 PM   #1
carlck19
Member#: 249890
1995 Impreza L wag
white
Default ej20g lag
Hi guys,
So ive had my ej20g swapped for a year and it has mostly been running fine, sorting out issues, etc. So I recently ordered a robs 550 tune and I currently have the 440 tune with mbc @15psi, turboback, walbro. I put an apexi intake on the car recently and lag seems to be worse than ever. The car is lifeless at low rpm and wont hit peak boost till between 4 and 5k. What could be happening? maxing out maf?
Thanks,
Alex
carlck19 is offline   Reply With Quote
Old 05-14-2012, 09:26 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
Likely a few bad exhaust gaskets pre turbo
also, you've got to be extremely close to maxing out the stock injectors at that pressure level with a 16g
eg33GC is offline   Reply With Quote
Old 05-14-2012, 09:44 PM   #3
carlck19
Member#: 249890
1995 Impreza L wag
white
^yah im retuning and im going to replace all the pre-turbo gaskets. when should a setup like mine spool/hit full boost?
Old 05-14-2012, 09:44 PM   #4
carlck19
Member#: 249890
1995 Impreza L wag
white
Old 05-14-2012, 09:47 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
I don't know. I've never had a stock tune/rob tune on the 16g. I hit at about 2700, 15psi and 3000 is 21psi
Old 05-14-2012, 09:52 PM   #6
carlck19
Member#: 249890
1995 Impreza L wag
white
^what turbo?
Old 05-14-2012, 09:55 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
oem small 16g.
for now
Old 05-14-2012, 09:58 PM   #8
carlck19
Member#: 249890
1995 Impreza L wag
white
^haha word. but you're on e85 which i would think affects spool. otherwise our setups are pretty similar. Im going to just replace every damn gasket pre and post turbo with grimmspeed for peace of mind and then with the tune im hoping i get good response. if not, what would be the next thing to check?
ps the motor runs perfectly no real hiccups or anything and no cel's.
Also what plugs would your recommend? ngk bkr7e? what gap? Im currently using pfr6g's with .29 gap and yes i have the gd coil conversion
Old 05-14-2012, 10:03 PM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
No those numbers are with pump
I use V-power at like .30, no issue
Old 05-14-2012, 10:42 PM   #10
carlck19
Member#: 249890
1995 Impreza L wag
white
v-power what part number?
Old 05-14-2012, 10:43 PM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
bkr range 7
Old 05-14-2012, 10:47 PM   #12
carlck19
Member#: 249890
1995 Impreza L wag
white
Originally Posted by eg33GC View Post
bkr range 7
thanks! ill update this in a few weeks when i do the gaskets and get my tune on and stuff.
Lag? What Lag? TJ Texas Impreza Club Forum -- TXIC 35 08-09-2007 07:18 PM
how much lag is too much lag? msm Off-Topic 8 07-19-2007 07:42 PM
TV lag or Xbox lag? Paraskass Off-Topic 11 09-15-2006 12:19 PM
Local FS: sedan spoiler, MRT TMIC for EJ20G, and EJ20G GC8 headlights annointed Tri-State Area Forum 3 05-10-2003 01:12 AM
MY00 has turbo lag.. er... rather.. NA lag..... Fitz New England Impreza Club Forum -- NESIC 7 04-03-2001 09:12 AM
