Old 05-15-2012, 02:24 AM   #1
SubaruDemon
Member Sales Rating: (8)
Member#: 97460
02 WRX 16G EVOIII
PSM Blegh
Default TurnInConcepts Lateral Link Bushing Enthusiast
Okay, here is my install review on the Lateral Link Bushings from TiC in the Enthusiast package. I was lucky enough to be chosen to test out these Lateral Links that are meant for the driver that is interested in handling but not full race stiffness. My overall impressions on the install is good. They were not too hard to install alone, but I can see how being on jackstands would make this job a real pain. After you get the old bushings out these pop right in easily with a vice. The real trouble on the install is if your drivers side long bolt is seized or rusted through. My overall feelings in driving the car is stiffness in the rear over bumps but not too outrageous. I have coilovers on the car so the stiffness is not really an issue for me. Well onto some pictures. They definitely look very good and shiny. Overall a great product from these guys!
SubaruDemon is offline   Reply With Quote
Old 05-15-2012, 02:40 AM   #2
SoCal_Scooby
Member Sales Rating: (2)
Member#: 210777
Don't worry bout' it Brah
Don't you need an alignment afterward?
SoCal_Scooby is offline   Reply With Quote
Old 05-15-2012, 04:10 AM   #3
SubaruDemon
Member#: 97460
02 WRX 16G EVOIII
PSM Blegh
Yes you will need an alignment afterward. Planning on doing mine after I finish installing the Trailing arm bushings and front lower control arm bushings!
Old 06-04-2012, 12:39 AM   #4
txl146
Member Sales Rating: (142)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Keep us posted on how your car handles now. Did it really make noticeable difference in how your car handles? lateral link bushing is probably the only bushing I haven't replaced on my car yet...
txl146 is online now   Reply With Quote
Old 06-04-2012, 10:30 PM   #5
ragejed
Member Sales Rating: (12)
Member#: 76817
2005 WRX
Which do you plan on replacing the front LCA bushing with? Superpro, whiteline, oem?
ragejed is online now   Reply With Quote
Old 06-05-2012, 09:50 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Any update?
Old 06-07-2012, 08:07 PM   #7
SubaruDemon
Member#: 97460
02 WRX 16G EVOIII
PSM Blegh
Apologies man! Have been VERY this week. I now have the trailing arms done, which were easier to do than the rusted lateral links in my opinion. I feel that a noticeable difference has been made and even the NVH has improved as I can feel the bumps on DD basis but it seems to absorb some of the larger potholes well. You can instantly tell over turns that the rear is The rear seems to have firmed up a lot! I cant say much about the increase in traction since I dont really do hard starts and the car already has so much grip that wheel slip doesnt really happen. I think it takes more of the play out of the suspension and you can "feel" what the back end of the car is doing and how its acting. Handling is a definite plus on this. Install is the only difficult part if you dont have a press.
ragejed I replaced the front LCA bushing with a Whiteline Caster Adjustment kit which was amazing as the steering response grew heavier instantly and it feels like the the front doesnt wash out as much.
Old 06-07-2012, 08:23 PM   #8
AFBeefcake
Member Sales Rating: (63)
Member#: 27874
2002 WRX 6MT 312whp
05 LGT
This looks like the best place to move my review of the bushing too.
So, I have been driving around to and from work with the bushings installed for a couple weeks and the car does feel firmer and less loose in the rear.
I feel like the bushings reduced my cars body roll slightly and that makes some sense. The lateral link to wheel hub bushing now has less play in it therefor making the rear sway bar work better.
Also before the install I had a squeak noise in the rear of my car when first driving. Like the bump at the end of my drive way or the bump out of the work parking lot to the street. Which I have not heard at all.
I don't race my car or push it to the limit so I am sure others may notice more of a difference then I did.
I would say in my case it was like upgrading to better rear sway bar end links.
So thumbs up on these bushings. If you already upgraded everything else or your looking to replace your stock bushings its time to get these bushings.
They are way easier to install then the stock ones by a long shot. Removing the stock bushings can be a real pain as well as dealing with stuck bolts if your in the salt belt.
I did not notice an increase in NVH, but I do already have a lot done to my suspension.
A pic of my car a 2002 WRX.
My current mod list is show on my cardomain page here.
AFBeefcake is offline   Reply With Quote
Old 06-08-2012, 12:34 AM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I would love to get these bushings.... but unfortunately I couldn't get the bolt to break loose. I took my car into Subaru dealer and they couldn't do it either.
I will just have to find time to destroy the long bolt.
Old 06-08-2012, 02:13 AM   #10
SubaruDemon
Member#: 97460
02 WRX 16G EVOIII
PSM Blegh
Does NY use a lot of salt on their roads too
Old 06-08-2012, 08:43 AM   #11
ragejed
Member#: 76817
2005 WRX
Yup, as does CT.
Old 12-24-2012, 01:42 AM   #12
SubaruDemon
Member#: 97460
02 WRX 16G EVOIII
PSM Blegh
These bushings plus anti lift is amazing
FS : Turninconcepts Lateral Link Bushings (New) adamkob32 Suspension/Brakes/Handling 10 04-19-2011 04:33 PM
FS: Group-N Lateral Link Bushings, Poly Trailing Link Bushings aboothman Suspension/Brakes/Handling 5 12-02-2009 03:44 PM
Noltec Lateral Links and Noltec Rear Lateral Link Bushing Kit RufusAZ SWIC Private Classifieds 0 07-18-2008 04:50 PM
WTB: Lateral Links or Lateral Link Bushings pitcrew Private 'Wanted' Classifieds 2 08-23-2004 02:15 AM
Trailing links / Lateral links/bushings? 9balljoe Brakes, Steering & Suspension 1 10-13-2002 01:45 PM
Message Board Statistics All times are GMT -4. The time now is 04:48 PM.
