Old 05-15-2012, 07:18 PM   #1
B.R.E.D
Member#: 289606
06 WRX
white
Default B.R.E.D: Review of TICs new TGV Deletes
First, Thanks to the guys at TIC for picking us to test the new TGV deletes. We enjoy testing new parts whether they are from another company or our own. About once every two months we pull one of our personal engines apart to test something new or to check and see how the parts we are currently testing are holding up. Luckily for us these parts don't require a full tear down just a hour or two of wrenching to install.
I haven't installed these on the car yet, just wanted to give my initial impressions of the product. Ill be installing them towards the end of the week and Ill update this thread accordingly.
If any of the other testers would like to post there feelings in here they are more than welcome to.
Matt
Ball Racing
Ball Racing Engine Development(B.R.E.D)
So, Whats in the box....well I got a card with Clints cell phone number, it will be for sale shortly on ebay, opening bid is 4 million but I'm open to offers...
Really nice looking kit, everything you need is included. LGT style TGV to cylinder head gaskets are very nice and we use them on everything at the shop. The tops of the TGV seal to the intake with a rubber O-ring, this is a nice touch(ours came with 6 incase someone tears one installing them. All of the Brass inserts look to be very secure. The overall finish is very nice and I don't see anything that I would change. I haven't installed them on the car yet but I did test fit a set of stock rails as well as a set of Aeromotive rails and both fit perfectly.
This is everything that comes in the box.
A single TGV by itself, not the smooth finish on the outside, no rough edges at all.
Different angle of the TGV
Close-Up of the O-Ring Groove
Bottom of TGVs
Inside of TGVs from the bottom, this ridge actually looks bigger in the picture than it actually is. It could very easily be removed with some fine grit sand paper by hand. No need for power tools on this.
Same view but from the top.
More Views
View from the back
O-Ring
B.R.E.D is offline   Reply With Quote
Old 05-15-2012, 07:18 PM   #2
B.R.E.D
Member#: 289606
06 WRX
white
Old 05-15-2012, 07:18 PM   #3
B.R.E.D
Member#: 289606
06 WRX
white
Sorry for all the delays, its been crazy busy at the shop the last couple of weeks but they are installed and tested. Here are my initial thoughts.
Install
Install on these is no more difficult than a normal set of TGVs. If you know your way around a Subaru it will take you somewhere between a 1 and 2 hours. If you don't know your way around a Subaru I suspect you can double that.
The Legacy TGV to cylinder head gaskets seal up very nice and provide a positive stop when you are torquing them down. The O-rings on the top that seal to the intake manifold also seal very nicely. Keep in mind you are sealing a o-ring so you don't need a tremendous amount of torque for these to seal. I torqued mine down tighter than I thought necessary to see how sturdy the inserts are in the plastic. I had no issue with it at all.
Its a very well constructed part, I didn't expect it to be any more difficult to install than a standard tgv and of course it wasn't.
Testing.
We kept testing rather basic. Its plastic so it should transfer less heat to the intake manifold and the interior is smooth so it should flow well.
Ill arrange my temp data in the same format that Crystal posted his in for easy comparison.
Stock No Spacers:
At TGV's inner side is where the temps were measured:
#3 - 155* #4 - 145*
#1 - 146* #2 - 144*
Intake Manifold @ the runners above flange
#3 - 134* #4 - 120*
#1 - 140* #2 - 129*
TIC's Composite TGV's:
@ TGV's
#3 - 138* #4 - 125*
#1 - 134* #2 - 128*
Intake Manifold:
#3 - 108* #4 - 101*
#1 - 108* #2 - 107*
More important than all the numbers above are the track results. I took the car to Atlanta Motorsports Park last weekend and put it through the paces. I forgot the IR Temp gun but one thing was very obvious...The intake manifold is way cooler after a 30 minute track session than it ever has been before. I could put my hand on it. Previously I could have put my hand on it...it just would have been followed by screaming and cursing. The car is on the ragged edge of how much timing it can run and I honestly expected it to want less timing at the track with as hot as it is, what actually happened was the opposite, I ended up putting a little more timing in it during the day. While it may not be the most scientific results its enough for me.
Clearly having plastic there isolating the intake manifold from the head is providing a thermal benefit.
If anyone has questions please feel free to ask. I've got more pictures but I of course left the camera at the shop.
I like these so much that I told Clint I would take 5 sets on the first order and we will be keeping them in stock at the shop. These will be going on every track car we build.
Matt
Old 05-15-2012, 07:19 PM   #4
B.R.E.D
Member#: 289606
06 WRX
white
Reserved 2
Old 05-15-2012, 07:20 PM   #5
vicious_fishes
Member#: 158864
to hell with what they look like, how do they work?
vicious_fishes is offline   Reply With Quote
Old 05-15-2012, 07:25 PM   #6
B.R.E.D
Member#: 289606
06 WRX
white
I'm working on it, I want to finalize the tune on the car this week and Ill install them this weekend.
Old 05-15-2012, 08:25 PM   #7
vicious_fishes
Member#: 158864
ahh i see. keep us posted
Old 05-15-2012, 08:35 PM   #8
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
They look great, should be a nice alternative to some of the other "ridiculously priced" competition
binjoau is offline   Reply With Quote
Old 05-15-2012, 08:51 PM   #9
25rsti
Member#: 166324
02 V8 Spec C 03
V9 Limited 2013 Legacy
Meh, One peice manifold FTW.
JK, looks like a fabolous peice of work. Though, I wonder why they went with the design of the oring. Do Legacys use orings already?
Old 05-15-2012, 08:57 PM   #10
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
I know the 08+ WRX does with the legacy plastic mani
Old 05-15-2012, 09:53 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Real quick as I'm working on a motor and would like to get home by midnight.
I didn't even notice the ridge inside until Crystal also pointed it out. It's an artifact from the mold. I'll have to hit them quick with a 1500 grit flap sander on the production to take it out. Especially since both you and he have pointed it out.
The finish will look better as the mold still needs to be media blasted. We didn't have that done for testing in case changes needed to be made.
The lower TGV gaskets. I wanted a rubber gasket there and pulled a "damn the torpedoes" and now I see how much the torpedoes are. I am working with the manufacturer to find a more cost effective solution.
I have NOT tested it with a normal lower gasket. It may actually be just fine doing that. I need to set one up with a stock lower and put 40 psi into it to see what happens.
Crystal has his, Team Scream should have his, and you have yours. Juan - there's a small delay on your set, but I should get those out soon. In the mean time the other goodie should be there for testing (yes guys I have two parts in test currently someone buy something as two R&D projects along with getting the race car is killing me).
Old 05-15-2012, 10:16 PM   #12
25rsti
Member#: 166324
02 V8 Spec C 03
I wanna be a test dummy :-)
Old 05-15-2012, 10:42 PM   #13
monkiboy
Member#: 202958
2008 wrx
caption for second photo ...
" *note the smooth finish..."
thanks for posting - look forward to your review.
monkiboy is offline   Reply With Quote
Old 05-16-2012, 12:20 AM   #14
B.R.E.D
Member#: 289606
06 WRX
white
Honestly the ridge is a non issue for me. I don't think its actually high enough to even cause a flow issue. Ill knock it down with 1500 grit before i test it. So far it really looks like a nice part. I bolted it onto a set of our test heads today to see how they line up with the ports and it looks perfect. Looking forward to doing more testing this week.
On a side note, we did some testing as well this weekend on a new set of pistons and oil control rings and the results look great. Could be good news for everyone this week.
Old 05-16-2012, 01:12 AM   #15
mlitz
Member#: 293571
1997 Legacy GT
Murdered
Very excited! cant wait to see more.
mlitz is offline   Reply With Quote
Old 05-16-2012, 01:21 AM   #16
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Very nice guys!
Bishop is offline   Reply With Quote
Old 05-16-2012, 03:48 AM   #17
Bru1212
Member#: 178770
2006 sti
Suscribed
Bru1212 is offline   Reply With Quote
Old 05-16-2012, 04:10 AM   #18
Tuned200
Member#: 127740
2006 FXT-Mine
2007 FXTi-Her's
X2!!!
Tuned200 is offline   Reply With Quote
Old 05-16-2012, 04:16 AM   #19
my name is joe
Member#: 171412
Hurry up so I can give you my money. ETA to public? What's the melting point to the plastic? And what kind of plastic?
my name is joe is offline   Reply With Quote
Old 05-16-2012, 06:22 AM   #20
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Great! I cant wait, i am going to start talking to my cooworker about the infrared camera
juanmedina is online now   Reply With Quote
Old 05-16-2012, 07:59 AM   #21
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I got a yes on the camera . I will take a base line reading as soon as I figure whats wrong with my car lol
Old 05-16-2012, 11:20 AM   #22
Nuul
Member#: 313456
2003 WRX Wagon
Originally Posted by my name is joe View Post
ETA to public?
I'm curious about this as well.
Nuul is offline   Reply With Quote
Old 05-16-2012, 12:26 PM   #23
ScoobyJD
Member#: 185910
07 WRX TR
are these made out of hard plastic?
ScoobyJD is offline   Reply With Quote
Old 05-16-2012, 12:31 PM   #24
Turn in Concepts
Member#: 93646
Many Track Records
they are composite so there is a thread fill in there as well. basically, you're looking at the same stuff OEMs are using for plastic manifolds now.
Old 05-16-2012, 12:38 PM   #25
Turn in Concepts
Member#: 93646
Many Track Records
hey guys - super busy so a quick update for you.
To make this project fly I had to commit to 1000 sets. Given the out of pocket costs on this one I will be hosting a pre-production group buy. That of course is dependent upon the testing of the prototypes.
Now, here's the thing. It is a long-ish lead item. 60 days from my order until they are delivered.
For this I was thinking of hosting the group buy for 45 days so I can get a rough idea of on if I need to then initiate a second immediate order.
As for timing - right now it depends upon the test feedback. Once we have that we move forward with the next step.
Next step could be a green light OR it could be that changes need to be made. This is why we do testers.
As for the group buy it will NOT be a tiered setup. It will be a one price point, but since I have the same manufacturer working on another little goodie at the same time I am going to see if I can do an add in bonus deal on this one when we hit a decent number of people on the list.
TIC's new TGV Deletes STI08awd Built Motor Discussion 0 05-15-2012 06:55 PM
NEW GReddy T518Z Turbo and NEW TGV Deletes!! hanzo918 Engine/Power/Exhaust 74 09-14-2009 06:24 AM
FS APS big TMIC in Spokane WA lots of pics $250 TGV delete FS w/ right offer cky211 NWIC Private Classifieds 12 10-26-2007 03:57 PM
FS: new TGV deletes for top mount injectors Marnix Engine/Power/Exhaust 15 07-22-2007 05:39 PM
Little to no boost - new tgv deletes just done Mactizen Factory 2.5L Turbo Powertrain 5 06-12-2007 10:04 PM
Message Board Statistics All times are GMT -4. The time now is 11:57 AM.
