Old 05-15-2012, 10:31 PM   #1
idmtngrl
Member#: 320287
Default 2006 subaru outback won't start
I ran that battery dead and was able to jump start it this morning had error on odometer and engine light on. Now after unhooking the battery cables and charging the battery, when letting off of the accelerator, it nearly died ( RPM went down to 400). Now it will not start, there is not clicking even, and there is power in the battery.... It can be pull started, but nearly dies when letting off the accelerator... upon shutting it off, it will not start. any ideas? it will not jump start now.
idmtngrl is offline   Reply With Quote
Old 05-15-2012, 10:55 PM   #2
cinnaman
Member#: 298063
2005 legacy 2.5i
DIP
Nvm im clueless
cinnaman is offline   Reply With Quote
Old 05-15-2012, 11:01 PM   #3
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
I assume this is completely stock?
GhostSenshi is offline   Reply With Quote
Old 05-15-2012, 11:35 PM   #4
boostdsuby8
Member#: 139739
You sure the battery/alternator/etc isn't bad?
It could be a vacuum leak as it will start and then refuse to stay running.
boostdsuby8 is offline   Reply With Quote
Old 05-24-2012, 09:54 AM   #5
idmtngrl
Member#: 320287
Thanks to all the suggestions... we did replace the battery, which was necessary, but it still would not start. It ended up being a fuse.
Old 05-24-2012, 10:44 AM   #6
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
The bad idle is the IAC metering and other idle settings relearning. They take about 20 minutes of idling or 45 minutes of driving to readjust after an ECU reset (IE battery removed or drained.)
J_Baker is offline   Reply With Quote
Old 05-24-2012, 11:12 AM   #7
sklindz2
Member#: 321182
wow a fuse!! i was stumped lol
sklindz2 is offline   Reply With Quote
2006 subaru outback won't start idmtngrl Newbies & FAQs 0 05-15-2012 10:22 PM
FS : UT: Lightly modded 2006 Subaru Outback XT Limited wagon uaoSTI Private Vehicle 'For Sale' Classifieds 0 05-15-2012 04:32 PM
99 impreza outback won't start mypwrtools Newbies & FAQs 0 08-11-2010 07:10 AM
1996 outback, won't start, overheated, timing raymond338 Normally Aspirated Powertrain 5 03-31-2010 02:32 AM
Outback won't start. greaper_ca Transmission (AT/MT) & Driveline 0 01-07-2007 05:31 PM
