Alaskan Impreza Club
Old 05-16-2012, 03:25 AM   #1
574907wrx05
Member#: 312626
2005 wrx
Default Bov questions
Could people with a blow off valve tell this thread which type they have which company and there opinion on blow off valves...
574907wrx05 is offline   Reply With Quote
Old 05-16-2012, 03:44 AM   #2
907scoobyrex07
Member#: 296069
05 Sti
Obp
Turbo xs 50/50 bov 50% recirc 50% atmosphere i like it alot but to be honest doesnt make a diff in my opinion it looks nicer and makes a louder noise... I was told yoi really dont need a aftermarket bov unless you are pushing alot more boost granted info could be wrong but it makes sense
907scoobyrex07 is offline   Reply With Quote
Old 05-16-2012, 03:53 AM   #3
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Stock here, ……it goes whoosh!
Nomadgene is offline   Reply With Quote
Old 05-16-2012, 04:06 AM   #4
granny
Member#: 283145
1997 LEGASTi Wagon
Instagram-@grannywagon
Stay stock unless you like the sound. No performance difference.
granny is offline   Reply With Quote
Old 05-16-2012, 04:37 AM   #5
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
True but it is easier on the motor for daily driving. I'm not using either a bov or recirc.
Rookie J is offline   Reply With Quote
Old 05-16-2012, 08:06 PM   #6
Billboard2001
Member#: 210085
2005 wrx sti
WRBlue
I thought that those were the only two choices? Unless your going to say you're not using a turbocharger either?
Billboard2001 is offline   Reply With Quote
Old 05-16-2012, 08:57 PM   #7
Rookie J
Member#: 281747
Element Sponsored
Lol I do have a turbo.
Old 05-16-2012, 09:14 PM   #8
DaBlueSquirrel
Member#: 311480
You dont have to use either one. There are plenty of factory setups that do not use a bypass or BOV. It is there to protect the turbo over time by reducing the amount of back pressure applied to the compressor wheel when the TB plate closes.
DaBlueSquirrel is offline   Reply With Quote
Old 05-16-2012, 11:17 PM   #9
seascooby
Member#: 133535
06 limited - mine
ww evo 8 - hers
turbo smart 50mm full atmo. love it
seascooby is offline   Reply With Quote
Old 05-16-2012, 11:33 PM   #10
granny
Member#: 283145
1997 LEGASTi Wagon
It's called a cork. Well at least it looks like it.
Old 05-16-2012, 11:51 PM   #11
Rookie J
Member#: 281747
Element Sponsored
Old 05-17-2012, 01:18 AM   #12
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Stock STi BPV for me. Does the job and isn't annoying.
kayetealynn is offline   Reply With Quote
Old 05-17-2012, 01:33 AM   #13
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Stock....
smeerone is offline   Reply With Quote
Old 05-17-2012, 07:59 AM   #14
05GDF
Member#: 281488
2005 STi
GFB for me.. Also adjustable 50/50 or 100%!!
05GDF is offline   Reply With Quote
Old 05-18-2012, 06:21 PM   #15
Billboard2001
Member#: 210085
2005 wrx sti
WRBlue
Learn somethin' new every day
Old 05-19-2012, 02:59 AM   #16
edo2000
Member#: 68709
2012 WRX
red
It's not so much the back pressure that is hard on the turbo, but the compressor blade stall, surging, and vibration that happens when you drastically reduce air flow through the compressor while it is spun up to operating RPM. Definitely shortens the life of the turbo.
edo2000 is offline   Reply With Quote
Old 05-19-2012, 03:08 AM   #17
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
I miss my Greddy Type S....
QwikEVO is offline   Reply With Quote
Old 05-19-2012, 01:52 PM   #18
Billboard2001
Member#: 210085
2005 wrx sti
WRBlue
Is there actually any benefit to running this setup? I'd imagine that it would increase spool up time as that extra air would bog down the compressor. I guess that was why I made the assumption of only being two setups because if it shortens the life of the turbo as well as hurting other aspects of performance why would someone utilize it?
Old 05-19-2012, 03:03 PM   #19
edo2000
Member#: 68709
2012 WRX
red
^^I'm pretty sure the only benefit for not having a BPV or BOV downstream of a turbo would be simpler/less expensive plumbing. I personally have not seen turbo setups without them but I don't doubt one exists somewhere. I assume that BPV's are better than BOV's for engine management, since that is the factory engineering folks choose.
Old 05-19-2012, 03:31 PM   #20
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
I can demo two setups without them, neither the race car or my STI run them. With a proper setup and tune, it's a significant increase in transitional throttle response.
Crawford Racing also sells all their turbo setups and built cars without BOV/BPV and you won't find a single WRC car running one either. But, as was already said, the system has to be set up properly for it.
retrac is offline   Reply With Quote
Old 05-19-2012, 10:53 PM   #21
edo2000
Member#: 68709
2012 WRX
red
Did not know this. Do you plan to operate the engine differently without a BPV? Say, try not to slam the throttle butterfly shut between gears? Do you notice any symptoms of compressor stall, like a repeated thumping sound when you get off the throttle when pulling hard? Sorry, I guess I should stop asking lazy questions and do some research.
Old 05-20-2012, 12:18 AM   #22
AWDBST
Member#: 80085
11.8 117 Trap
Stock EJ205
I too am curious about the tuning aspects of running without a bov or bpv. Could you exPlain a little about it or possibly pm some of the details? Thanks.
AWDBST is offline   Reply With Quote
HKS SSQV BOV Question...Not another BOV thread o2sys General Community 6 09-17-2010 08:04 PM
VTA BOV Question and Catch Can Question...Kinda Urgent FocusdSound Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-16-2008 11:14 AM
Modding a BOV ~ A different type of BOV question Sausage Newbies & FAQs 38 08-07-2006 06:40 AM
BoV Question... DannyGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 10:44 AM
BOV question imprezive General Forum Archive 6 10-15-2000 05:53 PM
