Old 05-17-2012, 01:28 PM   #1
BoostedNightmare
Member#: 188832
1996 legacy lsi/gt
gold
Default timing belt install question
So I have a built motor that has everything done to it. YES everything. Installed the engine and it won't start. Keeps backfiring. So first thought is timing. My question is can the crank be 180 out. Typical engines u set #1 to top dead and then set cams from there. Well #1 doesn't ever seem to be at top dead. #1 I assume is passenger front being its the furthest cylinder forward. Have read every timing belt install and nothing points to if u have turned the crank and have them out of phase with cams and how to set it up properly. Any help would be great.
BoostedNightmare is offline   Reply With Quote
Old 05-17-2012, 02:24 PM   #2
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
I remember someone on here doing that and they ended up being fine. Lined up everything but put the N at 12 oclock on the crank, and not the mark.
WRXSD is offline   Reply With Quote
Old 05-17-2012, 03:03 PM   #3
BoostedNightmare
Member#: 188832
1996 legacy lsi/gt
gold
180 out won't damage anything correct just not sure what happened and how to correct or keep from happening again
Old 05-17-2012, 03:38 PM   #4
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Having the crank 180 out will just have the intake valves open during the exhaust cycle and vice versa. I don't recall how he corrected it. I want to say he had everything lined up and then just rotated the crank, but don't quote me on that.
Edit: Doesn't read like he lined it all up when rotating the crank:
Found it:
http://forums.nasioc.com/forums/show....php?t=2199427
Old 05-17-2012, 08:11 PM   #5
BoostedNightmare
Member#: 188832
1996 legacy lsi/gt
gold
Well obviously I have just rotated the crank but not sure how from start to make sure this doesn't happen again. I understand that when u are just doing a timing belt everything is already lined up and u just install a new belt, but if u are building the engine ground up how do u know where to put the crank so all is well and then yes I know u then phase the cams
Old 05-17-2012, 08:16 PM   #6
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
The half-moon pill on the crank...
You did install the rods the right direction for each cylinder, right? 1-3-2-4 in order of getting to TDC, remember...
J_Baker is offline   Reply With Quote
Old 05-18-2012, 06:24 PM   #7
BoostedNightmare
Member#: 188832
1996 legacy lsi/gt
gold
Unsure: the machine shop assembled the engine I just put the timing belt on and they are pretty knowledgable about suby engines so I would assume they did it right
Old 05-18-2012, 06:43 PM   #8
LivingLEEgend
Member#: 320581
Gold
if your timing belt was installed in the wrong position then its already too late. assuming the timing is set right then i would check to make sure you have the coil pack connectors on right. white in the front and black in the back. Ive seen them installed backwards and it causes backfiring and wont start. hope this helps
LivingLEEgend is offline   Reply With Quote
Help! Timing Belt Install, stuck on the... you know, install RS-Flyboy Normally Aspirated Powertrain 11 07-09-2009 01:03 PM
Timing Belt Install Questions Bad Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-28-2006 04:52 PM
Timing Belt install questions tonyakavw Normally Aspirated Powertrain 11 09-22-2005 12:24 PM
Timing belt installation for a PE belt? IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-27-2003 03:45 PM
02 WRX timing belt install after crash cky211 Service & Maintenance 1 12-28-2002 11:25 PM
