Old 08-26-2002, 04:49 PM   #1
flames
Member#: 23471
Lightbulb hp opinions wanted
hey guys,
looking for educated guess as to what i am running to the wheels with the following ( i have no access to dyno ). my car is very, very quick, but i have not had it to a strip yet either. i've been told 420hp at the crank with Yoshio ecu. it feels like it....staying right with ZO6's, and i'm not a great driver (yet).
blitz: fmic, dd bov, sbc-id 20psi, 8 range plugs,
nurspec r, godspeed up/down pipe, catless all the way
unichip - soon to be a custom Yoshio ecu.
sti injectors, power enterprise fuel pump
power enterprise 1818 turbo
zerosports headers
ats cc cluth/flywheel combo
what do you think???
flames is offline   Reply With Quote
Old 08-26-2002, 04:56 PM   #2
NotoriousWRX
Member#: 9026
Any aftermarket uppipe or downpipe? Any cats?
I think that 420 might be way off.
NotoriousWRX is offline   Reply With Quote
Old 08-26-2002, 04:58 PM   #3
flames
Member#: 23471
oops,
no cats, godspeed uppipe and downpipe, 420 at crank, not wheel....i'll edit my post
thanks
Old 08-26-2002, 09:41 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Default go to the drags
With out access to a dyno the most reliable and by far the cheapest way to determine your wheel horsepower is to make a 1/4 mile run and see what trap speed you get. The trap speed is very reliable indicator of engine power, and highly independent of things like launch technique. Once you get the trap speed you can easily figure your hourse power by using one of the many on-line calculators. The only other piece of info you will need is an accurate as raced weight.
Larry
hotrod is offline   Reply With Quote
Old 08-27-2002, 01:03 PM   #5
flames
Member#: 23471
thanks - great information....what exactly is "trap speed" & how is it measured?
flames
Old 08-27-2002, 05:16 PM   #6
jmott
Member#: 6713
2007 Prius
brown
flames
the drag strip measures it by seeing how long it takes you to pass two little sensors at the end of the strip.
you will get back a slip with your elapsed time and speed at the end of the 1/4mile (trap speed)
jmott is offline   Reply With Quote
Old 08-27-2002, 06:41 PM   #7
silverscooby
Member#: 15060
Sounds like an awesome car. Who tuned your unichip?
silverscooby is offline   Reply With Quote
Old 08-29-2002, 11:54 AM   #8
flames
Member#: 23471
most of the work done on my wrx by Godspeed Inc. Dan Ponze is the owner. dan had his own wrx which he R&D'd all mods on prior to making recommendations. nothing left to chance, no mix/max ghetto mods - just proven power.
i have had two unichips....first one was not good. hesitation, unpredictable. second unichip was actually tuned & dynoed on dan's project wrx which had similar mods to mine....much better performance. dan could tell you more specifics....
fmic, plus properly tuned unichip made a huge, i mean huge difference in my car's performance.
Old 08-30-2002, 02:49 PM   #9
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I was at Godspeed the other day and Al was telling about your car. I would love to see it sometime, but I know the mod bug would be even worse after just seeing it.
Seth
mbiker97 is offline   Reply With Quote
Old 08-30-2002, 09:10 PM   #10
Carlo
Member#: 18376
367 WHP!
460 HP at the crank!
Default Re: hp opinions wanted
hey guys,
zerosports headers
OK, lets try doing a comparison for *****s and Giggles.
We'll start by assuming you're running pretty much the same as a TurboXS Stage 4 setup which puts out 270whp at about 18 psi. You are running the PE1818 which dynod a little less then the VF-30 so we'll subtract 10 hp. You mentioned your completely cat-less so we're going to add about 8 hp to the number for this. You didn't mention after market muffler so we're going to subtract 5 hp for this. We'll assume the Unichip is a wash. You've got the STI injectors and fuel pump to power the injectors so again we're at a wash. The clutch/flywheel isn't going to do much for hp so we're not worried about these. I don't know what the zerosport headers will do but lets "assume" you gain 20hp from them. You're running slightly more boost then a "standard" stage 4 setup so assuming it's still in the effeciency range of the turbo we'll add 15 hp for this. You're also running a blitz front mount IC which should do about the same as the new TXS top mount so we'll give you another 20 hp for this.
270 hp base Stage 4
+ 8 hp - cat-less
- 5 hp - didn't mention aftermarket muffler
- 10 hp - Turbo
+20 hp - zero sport headers
+15 hp - 2psi more boost
+20 hp - Blitz front mount IC
318 hp at the wheels
Now if you take this 318 wheel hp and use the "fancy" Godspeed or TurboXS math and multiply this by roughly 1.35 you get.
429 Crank Horse
I did this very quickly from memory so if I messed something up sue me But to answer you question, yes you are in the 420-430 crank range using "conventional" crank math
Carlo
Carlo is offline   Reply With Quote
Old 09-01-2002, 05:47 AM   #11
spool_fool
Member#: 23646
I guess I'll post this here. I have seen lots of AWD dyno results for the WRX. My last car which was a Honda was figured at 15% DriveTrain loss. I have seen 2 dyno results from stock WRXs which were 167whp and 147whp. I figure the DriveTrain loss to be around 25%-30%. Is this right? What does a stock WRX dyno at?
So if 420x27% = 113hp - 420 = 307whp that should be about right. Of course all engines will have some variation.
spool_fool is offline   Reply With Quote
Old 09-01-2002, 11:21 AM   #12
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Default Re: Re: hp opinions wanted
Originally posted by Carlo
270 hp base Stage 4
+ 8 hp - cat-less
- 10 hp - Turbo
We have about 25% drivetrain loss so....
318/0.75 = 424 hp at the crank (approx).
Now if I were you, I would stick to whp numbers since a stock Z06 (405 crank hp) runs about 345 whp, he should be faster.
Great ride.
Sordid Philosopher is offline   Reply With Quote
Old 09-01-2002, 12:08 PM   #13
Carlo
Member#: 18376
367 WHP!
Default Re: Re: Re: hp opinions wanted
Great ride.
Just for info on this. This I was using numbers from TurboXS as the "baseline", I also used their dyno numbers to come up with the 1.35 multiplier.
The stock car dynoed at 168.5 hp at the wheels and has crank hp of 227. 227/168.5=1.347 which I rounded to 1.35. 318(whp)x1.347=428.3 at the crank
Old 09-01-2002, 12:48 PM   #14
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Default Re: Re: Re: Re: hp opinions wanted
I understand - the reason I use 170 whp is that is about the highest I have seen. The stock ECU can cut your HP and that shouldn't be included in your drivetrain loss since it has nothing to do with the drivetrain. The other reason I use 25% loss is that it is easy to add/subtract 25% in my head
Old 09-02-2002, 06:53 PM   #15
krave
Member#: 13908
2002 WRX Sedan
296 whp
i think you should be able to get around 325WHP
krave is offline   Reply With Quote
How Good is B-specs Aluminum Flywheel...opinions wanted Rubasu Normally Aspirated Powertrain 7 05-30-2001 08:21 AM
Performance Winter Tire Opinions Wanted Bob O Brakes, Steering & Suspension 15 03-02-2001 07:33 PM
Quick Survey! Everyone's opinion wanted! TheSubaruDon New England Impreza Club Forum -- NESIC 2 03-02-2001 09:48 AM
Opinions Wanted Lexicon Legacy Forum 2 09-11-2000 09:01 AM
Canadian opinions wanted kgb Canada Region Forum 8 08-03-2000 12:07 AM
