Old 05-17-2012, 06:29 PM   #1
whitefro420
Member#: 61322
2004 Forester XT
Default Slight knock and whine, no CEL (videos)
On decel, the revs drop to almost stalling, then back up to around 4-500. This is accompanied by the constant sound of, well the only way I can describe it is the rattle you hear when your car almost dies when not giving it enough gas in first from a stop. This rattle is almost constant while accelerating and coasting as well. Also, there is a slight knock from the engine bay. Initially I thought timing belt tensioner, but that was just replaced along with the belt and all other pulleys. I will say it does not sound strong enough to be rod knock (hopefully). This is my first Subaru, so I am unfamiliar with whats normal and whats not, which isnt helping.
Sorry about the poor vid quality, but the sound is what is important.
whitefro420 is offline   Reply With Quote
Old 05-18-2012, 12:00 AM   #2
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Is the sound you are referring to after you rev it in the second vid?
The whine I could attribute to maybe some air in you power steering system, but otherwise everything sounds ok as far as I can hear from the vids. You could replace some of the o rings or the pump if it is leaking to resolve that.
As for the near stall, I would look into cleaning you IACV with some gasoline. If that doesn't work it may need to be replaced, but cleaning it is a good cheap starting point.
WRXSD is offline   Reply With Quote
Old 05-18-2012, 12:22 AM   #3
whitefro420
Member#: 61322
2004 Forester XT
No IACV due to it being DBW. Other than the whine, in the first vid at 20 seconds it seems to me like it doesnt sound right, like knocking. Am I being too sensitive? Is this how all boxers sound? This is my first Subaru and boxer engine, so it is possible.
Old 05-18-2012, 12:27 AM   #4
Dyno503
Member#: 314017
2010 WRX
if it was knocking I think it would be more apparent then that. It sounded alright to me tho.
Dyno503 is offline   Reply With Quote
Newly assembled hybrid with cranking and no start and no CEL, suggestions? 240sxguy Built Motor Discussion 7 08-20-2012 10:00 PM
sprayed down engine now it knocks?? no CEL 04beaSTIng Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 75 06-17-2012 10:42 PM
knock count = 17, knock count = 4 no UTEC timing, no load!!! K2Skier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2005 08:32 PM
Gutted stock UP install, no EGT and no CEL??? klie5111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-18-2005 10:04 AM
helix uppipe and downpipe no CEL? VideoGameWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-02-2004 09:31 PM
