Old 06-08-2013, 04:52 AM   #1
Actuality
Member#: 266785
2004 Impreza Wrx
World Rally Blue
Default 04 WRX 2.5 Hybrid 91/E85 FP16G
Hey everyone this is my Girlfriends 04 WRX that I helped her put together. Long story short after 2 td04s going out and the engine giving up the ghost at 176k+miles stage 2 we decided to go for the 2.5L hybrid motor rebuild. A long while later after everything was together here is the mods and results.
SORRY FORGOT TO PUT TURBO IN TITLE IT IS FP 16G
Dyno pull
Elevation: around 4327 feet
Weather: sunny 75-70.
Tires: its on a Dynapack its hub dyno.
2004 Impreza WRX
Tuner: Richard from Racing Edge
Dyno Info: DynaPack Dyno
Transmission: 5spd stock gearset
Gear: 3rd
Peak HP: 342whp
Peak Torque: 370wtq
Baseline hp for a stock: 170-180whp
Target Boost: 21psi
Fuel: 91/E85
2004 WRX Stock 5 speed 176k+ miles on the chassis/tranny
MOTOR:
2.5L STI Block Sti crank
Kink Race Bearings
Sti Rods
Weisco Pistons
Sti Cams (AVCS Plugged)
2.0L heads (newest ver from Subaru)
ARP Head Studs
11mm Sti Oil Pump
stock gasket (higher compression)
Grimmspeed Lightweight Crank Pully
POWER BOLT ONS:
Ebay Silicone Turbo Inlet
Speed Daddy TMIC
Grimmspeed EBCS
Grimmspeed Radiator Shroud
APS 65mm CAI w/ k&n filter
Walbro 255
Injector Dynamics 1000cc
FP 16G (was bought used and not completely sure what it was 100%, it appeared to have a billet wheel in it, but uncertain)
EXHAUST:
Grimmspeed CrossPipe
Grimmspeed UpPipe
Invidia v2 Downpipe (catless) w/ wb02 bung
Everything is wrapped from the head runners and crosspipe to the bottom of the downpipe with Titanum DEI Wrap.
Turbo has Ebay Turbo Blanket on it and VTH Flame sprayed on stock Heat Shield
SRS Catback
We did 2 tunes one with 91oct pump and one with E85.
All were on done on a DynaPack, tuner claims it is within 1HP of Cobbs mustangs dyno
thanks to Ralph for the motor build and thanks to Richard for the tune at Racers Edge
91oct First
299.2 AWHP 316ft/lbs tourqe this was at about 18psi
now for the E85!
342.4 AWHP 370ft/lbs tourqe this was at 20.98psi
I have a video but its from the phone and the audio sucks cuz it was soo loud.
any questions ask away, praise, fight, flame. im curious thanks.
Actuality is offline   Reply With Quote
Old 06-08-2013, 09:02 PM   #2
Actuality
Member#: 266785
2004 Impreza Wrx
World Rally Blue
Maybe a mod could edit my title to include turbo fp16g
I messed up and forgot to put it in the title
Old 06-09-2013, 12:12 PM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Go advanced and do it yourself^^^^ nice numbers.
Old 06-10-2013, 12:33 PM   #4
Layvon
Member#: 195711
STi 04/05/06/07
You indicate that the cams are the newest version from Subaru ... do you know what if any changes were made from the OE back in 04??
Loving the SRR
Old 06-10-2013, 03:36 PM   #5
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Shouldn't a 2.5 be spooling that 16g much faster? Even with AVCS off?
LatentWagen is offline   Reply With Quote
Old 06-12-2013, 08:25 PM   #6
Actuality
Member#: 266785
2004 Impreza Wrx
World Rally Blue
Loving the SRR
Sorry its not the cams its the heads that have had revision due to the common cracking that happens between the valve seats and the spark plug hole. To my knowledge more material was added to help beef up and eliviate the cracking issue. A lot of people still run there cracked heads with good success.
As to the spool...yes I agree. The turbo was used and had new seals but it seamed to be tight and it appeared to have billet wheel. But its defiantly FP but its still kind of a mystery one. Perhaps once the tranny dies and is replaced it will be welcomed with a large turbo upgrade 20g +. Probably not for a while.
Also its internally gated still which doesn't explain it all, but some
Old 01-04-2014, 04:34 PM   #7
xentris02
Member#: 335293
how many miles on engine and how is it holding up so far?
xentris02 is offline   Reply With Quote
Old 03-24-2014, 11:02 PM   #8
Actuality
Member#: 266785
2004 Impreza Wrx
World Rally Blue
Sorry didn't see the response till now.
This was my Girl Friends Car at the time. We are no longer together
however, from what I know she is still using the car as her daily driver, and I'm figuring she has 15,000+ miles on this set up (new motor and turbo stuff)
it was really fun to do pulls on the on ramp, it would just go and go.
any other q's lmk.
