Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-18-2012, 12:08 AM   #1
SilverSubiGC8
Member#: 313024
1995 GC8 JDM
Default Stock BCS clicking
Stock boost control solenoid is clicking at low rpms on my 95 wrx, isn't noticeably affecting boost. Anybody have this problem?
SilverSubiGC8 is offline   Reply With Quote
Old 05-18-2012, 04:26 AM   #2
pmugabi
Member#: 280926
We all have it :-)
It's normal, it's just that usually you don't notice it.
pmugabi is offline   Reply With Quote
Old 05-18-2012, 04:59 AM   #3
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Aftermarket ebcs is even louder. I made a custom bracket for my prodrive ebcs and mounted it roughly where the stock one is located and then i drove the car. Not expecting it to make a difference, i freaked out cus it sounds like knock at low rpms. I thought i ****ed myself... Couple days later, i read that the ebcs can make noises, so i took off the bracket and let it "sit" looses in the engine bay and the knock sound went away... Go figure
Jubert39 is offline   Reply With Quote
Old 05-18-2012, 09:49 AM   #4
luka
Member#: 194742
1993 Impreza WRX JDM
if you put the car in diagnostics mode (green and black connectors under the dash) and turn the key to on you can go under the hood to hear what it sounds like without the car running.
sounds like a starter relay under low battery.
luka is offline   Reply With Quote
Old 05-18-2012, 11:44 AM   #5
SilverSubiGC8
Member#: 313024
1995 GC8 JDM
Thing is I never had the clicking before, I thought it was knock too haha! I'll try the diagnostic mode and see if it clicks. Won't make a difference if I put a new BCS in? Thanks guys
Old 05-18-2012, 12:39 PM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
You can clean and re-lubricate the factory ebc. It reduces the noise and makes for smoother operation.
TommyAtomic is offline   Reply With Quote
Old 05-18-2012, 01:49 PM   #7
SilverSubiGC8
Member#: 313024
1995 GC8 JDM
I'll try that. Anyone have a DIY on how to clean it?
Old 05-18-2012, 02:11 PM   #8
luka
Member#: 194742
pull one of the vacuum lines and spray it some brake cleaner quick and easy way to do it without dismantling the thing.
Old 05-18-2012, 05:19 PM   #9
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
1) Note where all boost controller vacuum lines go.
2) Remove all vacuum lines from boost controller.
3) Plug in under dash diag connectors (this will start the fans and the OEM boost controller will start clicking like crazy)
4) Spray brake cleaner through each of the ports until what comes out the other two ports is clean. (The solenoid will get louder)
5) Spray WD40 through each of the ports (the solenoid will get quieter)
6) turn off car, plug vacuum lines back in and unplug diag connectors
Old 05-18-2012, 06:03 PM   #10
SilverSubiGC8
Member#: 313024
1995 GC8 JDM
3) Plug in under dash diag connectors (this will start the fans and the boost connector will start clicking like crazy)
Awesome! Thanks a lot
Stock STI Springs, Stock BCS , Stock Intercooler Elbow FunSTI619 Engine/Power/Exhaust 3 12-01-2009 07:51 PM
Hallman Pro MBC, Stock bcs, Stock BPV ryansport22 Engine/Power/Exhaust 3 05-30-2009 08:02 AM
IL: stock sti injectors (sidefeed), stock BCS, short ram intake, and more STiGMATA Engine/Power/Exhaust 14 10-19-2008 11:22 PM
STI Intercooler, 05 WRX Coil Packs all 4, Stock BOV, TXS Racing BPV, Stock BCS mrtrex Engine/Power/Exhaust 11 03-30-2008 07:34 AM
Perrin BCS clicking spit_heron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2006 11:51 AM
