Old 05-18-2012, 09:42 PM   #1
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Default Alcantara Wrapped ATI Center Dash Pod | GR Impreza
Hey all, today I decided to post the pictures from the new ATI canter dash pod for the 2008-2012 WRX/STI.
There has been a 3 year wait on this pod to come out from ATI and when it finally did, I have to say I was quite disappointed. The first thing that I noticed is that they slapped a thick rubber cover on the pod just to compensate for a poorly molded piece. Even with this rubber cover the pod still fit like crap so I decided to go all out and re-mold the pod and cover it in Alcantara.
Here are the progress pictures of the steps I took to do the job. Overall when I was done, I think I looks a million times better then it did plus it now matches the rest of the Alcantara interior.
If you want to see the rest of the car, stop by my build thread (HERE)
I'll start off with the finished images.
This is the pod how I received it right from Rally Sport Direct.
Then I got it into the car... Thats where it became obvious that there needs to be some work done to make it look right.
I first started by peeling off the rubber cover. It was glued on.
Then I was left with a pod with rubber residue all over it.
Not wasting any time I used the wire wheel on a drill to rip it off.
Then sanded it down smooth again.
Here is the fit before I started to remold the pod with the heat gun.
Overland04 is offline   Reply With Quote
Old 05-18-2012, 09:42 PM   #2
Overland04
Member#: 293311
2013 FXT 6-Speed
The next shot I forgot to take but it is the shot after I molded the pod with the heat gun.
Here are the bolts I used to bolt it tightly to the dash.
Tapping the mounting holes
Drilling the dash!!!
Mixing the bondo
After the sanding of the bondo.. Notice no holes for screwing down?
Re-sprayed the front panel with Plasti-Dip
Glue used to mound Alcantara
Glue applied, ready to stretch
Finished, cut, and mounted gauges
In the car!!
Old 05-18-2012, 09:58 PM   #3
Layvon
Member#: 195711
STi 04/05/06/07
Nicely done. How did you finagle yourself under there to tighten things down?
Again - Looks good, and done right the first time.
Layvon is offline   Reply With Quote
Old 05-18-2012, 10:14 PM   #4
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks!!
I'm trying to see if I have the picture that shows underneath the pod but I don't think I took one.
When I tapped the holes in the pod, what I did was screw the bolts down from the top then glued them into place, then filled the holes with bondo. At that point I had two 3/16" studs coming out the bottom of the pod. When it was time to mount it I just lined up the studs with the drilled holes.
I removed the radio and was able to get an 8mm ratchet underneath to bolt the washer/lock washer/nut all together... It's super solid, no rattles possible!
Old 05-18-2012, 10:15 PM   #5
Overland04
Member#: 293311
2013 FXT 6-Speed
Oh, and a picture of the re-located clock...
Old 05-19-2012, 11:52 AM   #6
HXC573
Member#: 268007
2012 WRX
Ice Silver Metallic
Looks really good man. Could there be a possible driver seat view shot of the pod, and ... Would be possibly wiling to do another one just like it? obviously for the right price i suppose.
HXC573 is offline   Reply With Quote
Old 05-19-2012, 09:30 PM   #7
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
wow that build quality is horrible. final product looks good. also 30mpg!!!!!!
bluemax189 is offline   Reply With Quote
Old 05-20-2012, 12:52 AM   #8
Joey Mick
Member#: 208276
2010 WRX TP Stage 1
Where do you get your alcantara? Thanks
Joey Mick is offline   Reply With Quote
Old 05-20-2012, 09:46 PM   #9
Overland04
Member#: 293311
2013 FXT 6-Speed
I'll get a new picture up of the drivers side view, no problem...
I'd love to make more but Id have to but a new piece of Alcantara which is $100/yard and the minimum amount you can buy is a yard. I don't think it would be fair to ask $100 + the labor just to wrap a pod
Haha, thanks!! The MPG is from bigger injectors, this car will never see anything close to that, lol It's just there to tease you everyday
Originally Posted by Joey Mick View Post
Where do you get your Alcantara? Thanks
Hey Joey, I get all my Alcantara from JPM Coachworks the link to the material is (HERE)
Old 05-20-2012, 10:23 PM   #10
HXC573
Member#: 268007
2012 WRX
Ice Silver Metallic
Well if I were to buy the pod and alcantra how much would it be for labor
Old 05-20-2012, 10:43 PM   #11
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
Beautiful
danny_d19 is offline   Reply With Quote
Old 05-20-2012, 10:48 PM   #12
Darth Wagon
Member#: 269713
2015 Forester XT
Nicely done! I can't believe the crappy fit of the original.
Darth Wagon is offline   Reply With Quote
Old 05-21-2012, 10:15 AM   #13
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks great! I'd hate to drill into my dash, but I have to admit, your bolt method is ingenious for a clean look!
xluben is offline   Reply With Quote
Old 05-21-2012, 10:34 AM   #14
Drowner
Member#: 49297
17 WRX Limited
Man, its too bad that the original product was garbage, especially after a 3 year dev cycle. You really turned it around to something much better, love the fitment and the hidden bolts. Even if the original was a perfect fit, the exposed bolt holes would be a deal breaker for me.
Drowner is offline   Reply With Quote
Old 05-21-2012, 11:10 AM   #15
LTD77
Member#: 257416
2011 STI Sedan
Dark Gray
Nice job! I was thinking of purchasing this, but after looking at the fitment I am not so sure.
LTD77 is offline   Reply With Quote
Old 05-21-2012, 12:00 PM   #16
Tsujen
Member#: 269643
15 WRX Limited
Wow I can't believe how horrible that fitment was at the beginning and a company would even sell those.. But you did an amazing job at getting it to fit right good job!
Tsujen is offline   Reply With Quote
Old 05-21-2012, 10:00 PM   #17
jon102034050
Member#: 223895
2010 WRX
amazing work - hard to believe the product sucked so much before you did some work to it...
jon102034050 is offline   Reply With Quote
Old 05-21-2012, 10:13 PM   #18
OneBadSS
Member#: 104475
2014 Audi S5
1986 Pro Street Monte SS
+1 on the fit. I have yet to open mine from the group buy, but I am not very optimistic of it at this point.
OneBadSS is offline   Reply With Quote
Old 05-21-2012, 10:24 PM   #19
JFern
Member#: 311934
Nice work! That looks like a huge improvement over the original!
JFern is offline   Reply With Quote
Old 05-22-2012, 09:26 PM   #20
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Overland04 does it again!
I've watched you progress your car from day 1 and this isnt the first time I've said it and it wont be the last.. fantastic job!
and like others have said, I'm happy I saw how poor the original fitment was. Saved me some money in the long run!
daigledangle8 is offline   Reply With Quote
Old 05-22-2012, 09:31 PM   #21
Zachfeen
Member#: 277479
2011 WRX
Me too Did a great job with it but I won't be wasting my time with this project. Going SMY instead
Zachfeen is offline   Reply With Quote
Old 05-22-2012, 09:33 PM   #22
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Unless overland is available to do the template.
smeerone is offline   Reply With Quote
Old 05-22-2012, 09:36 PM   #23
Zachfeen
Member#: 277479
2011 WRX
Doesn't seem like it would be very hard, just too much work required for the price you pay for the product.
Old 05-22-2012, 09:39 PM   #24
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
How much is the pod? I know alcantera is 100$ yard.
Old 05-22-2012, 09:43 PM   #25
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
^ I believe rsd sells it for $135?
WTB : ATI Triple Meter Center Dash Pod 801wrx RMIC Private Classifieds 0 04-25-2012 04:28 PM
Got Boost- ATI Triple dash pod SebassScoobie Interior & Exterior Modification 6 10-05-2011 03:36 PM
FS : ATI Triple Meter Center Dash Pod with Carbon insert (60mm \Rogue Interior/Dressup/Audio & Security 2 05-06-2011 08:08 PM
WTB: ATI clock / dash pod FACEPLATE only captureandrelease Private 'Wanted' Classifieds 2 12-23-2009 12:55 AM
Painted My ATI Triple Dash Pod WRXSIG Interior & Exterior Modification 20 06-09-2006 05:28 PM
