Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-19-2012, 10:20 AM   #1
tairyhesticles
Member#: 311614
1995 WRX
OMGHi2U How do you like your FMIC?
So I have been using the search for an hour, trying to find some feedback on front mount intercoolers for our cars.
I was pretty confident in putting mine on, until a Subaru enthusiast friend of mine BEGGED me not to due to the response I'd lose. what do you think NASIOC?
Has anyone on here loved their front mount? Has anyone hated it? let me know!
Also, I should mention that this is not a thread asking whether I should buy one, or what brand I should buy. I have the FMIC sitting at my house, with all of the necessary hardware to be installed.
tairyhesticles is offline   Reply With Quote
Old 05-19-2012, 12:00 PM   #2
liltoua
Member#: 206802
1998 2.5rs
What turbo are your running? It creates a minimal amount of lag, but it really depends on what your HP goals are and the type of driving you do, then again that all comes down to what turbo you have.
liltoua is offline   Reply With Quote
Old 05-19-2012, 12:52 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
I have the same kit. No problems. The 16G on a 2 liter is kinda laggy to begin with, it doesn't get much worse.
Old 05-19-2012, 03:59 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
i went to a front mount shortly after i installed the EJ20G into my car. i would never go back... dyno increased by 25AWHP on the same dyno.
i say the lag from a FMIC is better than the heat soak from that tiny little TMIH (Top Mount Inner Heater)
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 05-20-2012, 12:18 AM   #5
tairyhesticles
Member#: 311614
1995 WRX
Running a stock Td05 turbo. Potential plans to go bigger in the future, but I'm still unsure of the upgrade route i want to take.
Old 05-21-2012, 09:36 AM   #6
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Originally Posted by tairyhesticles View Post
Is that the Ebay kit that's like $170?
GGSimpreza is offline   Reply With Quote
Old 05-22-2012, 09:41 PM   #7
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Nice wheels. Thats what I have on my Legacy
Tizzle is offline   Reply With Quote
Old 05-23-2012, 01:23 AM   #8
tairyhesticles
Member#: 311614
1995 WRX
It's the CX racing one I believe, but they're all the same when it comes to eBay kits. Although mine is the old version, the new CX Racing one was revised so the core wasn't so low IIRC.
You have the Speedline Corse wheels? That's awesome! I haven't ever seen another set, these ones are from Japan. Do yours have black "Speedline" decals on them? It looks like mine used to, then were removed.
I put the FMIC yesterday, I can't exclaim how noticeable the gains are. Much more than I found with my Rob's 440 tune.
To anyone reading this thread considering the upgrade, I highly recommend it. Install time is about 3-4 hrs from start to finish, only minor sockets, grinder, and pliers needed.
Buy the GD kit (2002+), it fits perfectly other than one pipe that needs cutting, and cutting behind the right headlight. I didn't have to cut any rebar, since the car is JDM and has no front rebar.
Pictures to follow!
Old 05-23-2012, 02:42 AM   #9
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
I've been running a fmic (cheap ebay) for a while now, td05 16g, yes more lag, but it's worth the wait.
Just a couple days ago I wrapped my dp, blanketed my turbo, and cool taped the first pipe that does that u turn off the compressor side. Solved my heat soak problem for sure!
But yes install the fmic.
azn0boi04 is offline   Reply With Quote
Old 05-23-2012, 08:06 AM   #10
Poppie
Member#: 262422
1998 V4 Type R
Feather White
They are Speedline Preo-R wheels ,I've got a set and had to find a replacement set of stickers which was impossible
Poppie is offline   Reply With Quote
Old 05-23-2012, 12:35 PM   #11
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
+1 for pics of this installed on your gc.
TommyAtomic is offline   Reply With Quote
Old 05-23-2012, 08:54 PM   #12
tairyhesticles
Member#: 311614
1995 WRX
Boom, Pics.
This is where the pipe had to be cut, and an additional silicone coupling was added.
And a pretty significant hole cut behind the headlight to fit the pipe.
Old 05-23-2012, 10:00 PM   #13
Tizzle
Member#: 44472
Ver2 Legacy StiRA
You have the Speedline Corse wheels? That's awesome! I haven't ever seen another set, these ones are from Japan. Do yours have black "Speedline" decals on them? It looks like mine used to, then were removed.!
yes I guess mine are specifically the Preo-r's, with the black lettering. they are from Japan
Old 05-24-2012, 10:13 AM   #14
Aphex28
Member#: 11506
2015 WRX
Sorry if this is a hijack.
rather than making the hole in the fender that large, I opted to use a long silicone coupler to get the pipe to where it needed to be.
pic with view of coupler, and sti engine that blew :
route through fender:
Aphex28 is online now   Reply With Quote
Old 05-24-2012, 02:52 PM   #15
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
I did mine like this. I opened up the hole and put some split hose over the cut edge.
Old 05-25-2012, 12:34 PM   #16
vividwrx13
Member#: 66402
2005 STi Ver8
Went Fmic 4 years ago.......never looked back.
vividwrx13 is offline   Reply With Quote
Old 05-27-2012, 09:24 PM   #17
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Okay, so the FMIC doesn't add that much lag? That's good..
Smoke is offline   Reply With Quote
Old 05-28-2012, 10:47 AM   #18
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I would assume anyone willing to go to the effort of going FMIC would also install headers and up-pipe or at the very least an Up-pipe. The FMIC with all of the extra plumbing will absolutely increase lag but an intake, up-pipe, Headers, and TBE will reduce lag. Drive-ability should meet somewhere in the middle so done all together it probably wouldn't be noticeable.
Old 05-28-2012, 05:14 PM   #19
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
I definitely noticed more lag. But, the turbo achieved full boost only 200 rpm later. I like the extra kick when the boost finally does kick in.
Headers increase lag because there is more piping. PNP stock manifold would decrease lag.
super_usdm is offline   Reply With Quote
how do you know your FMIC is working great? slin02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-29-2003 10:33 AM
How do you like your Tein Wagon Coilovers? 2000vfr800 Brakes, Steering & Suspension 0 11-09-2002 09:48 AM
How do you like your turbo kit for 2.5 rs? Szm426 Normally Aspirated with bolt-on Forced Induction Powertrain 32 07-26-2002 10:44 PM
High altitude owners - How do you like your MBCs? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-01-2001 11:31 AM
'01 Legacy GT owners...how do you like your cars? mvb Legacy Forum 7 06-08-2001 05:08 PM
