Old 05-19-2012, 05:33 PM   #1
dickiescoob
Member#: 259508
2015 WRX Limited
Default paint chipping
looking for suggestions on how to properly treat these chips. its on a 2011 swp hatchback, these are the pillars on the edge of the passenger side windshield.
thanks
dickiescoob is offline   Reply With Quote
Old 05-22-2012, 05:39 PM   #2
dickiescoob
Member#: 259508
2015 WRX Limited
anyone?
Old 05-22-2012, 05:46 PM   #3
tmcgraw
Member#: 287023
2016 BMW M4
touch up paint. might not make it completely unnoticeable but it will cover it.
tmcgraw is offline   Reply With Quote
Old 05-22-2012, 06:10 PM   #4
dickiescoob
Member#: 259508
2015 WRX Limited
From the dealer or just any paint shop. And that should prevent it from further peeling back right
Old 05-22-2012, 06:20 PM   #5
itsover9000
Member#: 309498
2012 STI Limited
yeah got a fat one on my passenger rear door. I had mudflaps so i was hoping it wouldnt
itsover9000 is offline   Reply With Quote
Old 05-22-2012, 06:33 PM   #6
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Dr. Colorchip
findurpath is offline   Reply With Quote
Old 05-22-2012, 10:58 PM   #7
tmcgraw
Member#: 287023
2016 BMW M4
touch up paint should stop it from spreading.
Old 05-23-2012, 07:37 AM   #8
dickiescoob
Member#: 259508
2015 WRX Limited
Awesome. Thanks guys
Old 05-25-2012, 05:27 PM   #9
dickiescoob
Member#: 259508
2015 WRX Limited
Looked into Dr colorchip, any reason for that over touch up paint direct from my dealer?
Dealers comes in a 2 step as well, looks almost the same, and is half the price.
Old 07-16-2012, 03:32 PM   #10
IamCaDeMiC
Member#: 262093
2011 Impreza WRZ STi
Satin Pearl White
Interested to see if you went the Dr Colorchip route? If you did, how'd it turn out? I've read differenting opinions on Nasioc.
Some little punks with an airsoft gun hit my SWP STi on my way home from work on Friday. It didn't dent my baby but it made a little paint chip on my rear fender. Not as large as yours though.
IamCaDeMiC is offline   Reply With Quote
Old 07-16-2012, 06:15 PM   #11
dickiescoob
Member#: 259508
2015 WRX Limited
Turned out ok. You cant tell unless you get up close
Old 07-16-2012, 06:36 PM   #12
IamCaDeMiC
Member#: 262093
Satin Pearl White
Would you be able to posts some updated pictures? I would really appreciate it. I've read on some posts that the SWP from Dr Colorchip is iffy.
I went to some local body shops and they all want around the same - $1,000. :-( When I get home, I'll post a picture of my chip. It's small, but noticeable. Hurts my heart.
Old 07-16-2012, 07:14 PM   #13
dagreek
Member#: 326331
Paint chips aren't to be fooled with since no matter what you do they're always going to show. Touch up paint? No thank you, it'll glob on and make it look worse than before.
Just follow the steps...
1) carefully chip off any loose paint around it that is raised and not adhered to the body. You may want to hold the area around the raised chip so that you don't take off an entire chunk and are just treating the localized area.
2) use masking tape to cover the surrounding area leaving only the space of the chip and surrounding paint exposed.
3) If there's rust, sand use compressed air and a damp cloth to remove particles
4) Apply an automotive spray on primer (go alittle bit onto the paint around it to prevent water ingress under the surrounding paint and you'll handle it in step 7)
5) **For the next step do not apply factory touch up paint with a brush... They apply it with a spray gun at the factory, logically a brush and spray gun won't have the same look as the brush will provide more of a texture. I have a desert rock colored acura mdx and I just went to wal-mart and matched up some krylon spray paint as best I could and applied it. It's not a 100% match, but it looks 1000x better than the botch job I did on my accord with the factory touch up paint with a paint brush. If you want to paint a picture of a landscape, use a brush... if you're paining a car, use an aerosol (sorry Al Gore), the brush lacks the consistency and "even" look the "spray paint" gives the rest of your car's paint.
6) Hit it with some good automotive clear coat
7) If you need to remove extra primer, paint or clear coat, do so with 90% alcohol and a paper towel, but be easy since you are working your way into the original clear coat.
Another way would be to go to the dealer and get robbed, either way its gonna be nasty
dagreek is offline   Reply With Quote
Old 07-17-2012, 12:08 AM   #14
dickiescoob
Member#: 259508
2015 WRX Limited
That sounds fantastic, and I wish I could have done that, but living in an apartment makes it very difficult. Especially since I have a new chip on my hood that I touched up, and it looks crappy. But that was more my fault than the touch up paint. Some drops accidentally fell off the brush, and trapped some black dirt under it , before I could wipe them away.
Ill grab some pics tomorrow after work.
Old 07-17-2012, 12:43 AM   #15
IamCaDeMiC
Member#: 262093
Satin Pearl White
Thanks man, really appreciate it.
Old 07-17-2012, 06:26 PM   #16
dickiescoob
Member#: 259508
2015 WRX Limited
here is a spot on the hood. notice the black smudge to the left, thats where the drop fell before i could clean it
here are pics of the passenger door pillar now touched up:
not the greatest by far, but ok enough for now.
Old 07-17-2012, 11:08 PM   #17
cineris
Member#: 263329
2011 Impreza WRX
Lol yeah you definitely cant tell its there unless you're told to look. Curious, any nicks on your hood?
cineris is offline   Reply With Quote
Old 07-18-2012, 07:42 AM   #18
dickiescoob
Member#: 259508
2015 WRX Limited
Yea.the first pic is of the hood
Paint Chip Repair: Post Paint/Clear dvrmstrng Car Care & Detailing 0 10-25-2011 11:15 AM
FS: Paint chip repair kit + CGM touch-up paint Alex1 Exterior/Styling 2 02-21-2008 01:34 AM
FS: Paint chip repair kit + CGM touch-up paint Alex1 Tri-State Area Private Classifieds 0 02-20-2008 09:06 PM
('93-'01) Warranty and Paint Chips Julian Impreza Forum 33 05-06-2001 10:52 PM
('93-'01) ack, first paint chip Dussander Impreza Forum 8 04-19-2001 09:59 AM
