Old 05-20-2012, 09:18 PM   #1
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Default "BLOOD" in my coolant
Recently my oem radiator took a dive and i replaced it with a Mishimoto full alum one. I read that we should be using Subaru coolant due to our blocks being alum. so I dropped of the car at a shop for a week to have suspension work done and replace the rad. Told the guy to flush the system and replace it with Subaru coolant. Today i come out to check the coolent for no reason at all and this is what i see. "BLOOD". Oil is clean and not leaks. Any help? Did the shop miss match coolant and not flush the system? Is it ok to drive?
The red stuff is less dense then the green coolant and floats to the top.
BlackFighter is offline   Reply With Quote
Old 05-20-2012, 10:19 PM   #2
LBell05STI
Member#: 305890
2005 STI
What does it smell like? Ifs its sweet its most likely just mixed coolant. If it has a sour egg smell and a sweetness about it, it may be oil mixed in.
Also why not just do a coolant flush to be safe? That way you know it will be 100% coolant and if its mixed again that would raise an eyebrow.
LBell05STI is offline   Reply With Quote
Old 05-20-2012, 10:22 PM   #3
VERSION7
Member#: 306038
Why dont u ask them....
VERSION7 is offline   Reply With Quote
Old 05-20-2012, 10:45 PM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
What has zero bearing for coolants? Color. They can make coolant ANY color, so you need to contact who did this for the info you seek and if not, then dump it all down the toilet and refill what what you know to be the correct fluid.
Old 05-20-2012, 10:49 PM   #5
UK-Wagon
Member#: 232430
555 I haz 5 Subarus
GC8/GF/SG/GD sedan & wag
Red coolant is Toyota Coolant, Orange typically is Dex Cool for GM cars. Flush it all out and I would recommend Subaru Long Life (green) or Subaru Super Coolant (blue).
Either they messed up or someone there doesnt like you and put ATF in your coolant!
UK-Wagon is offline   Reply With Quote
Old 05-20-2012, 10:55 PM   #6
BlackFighter
Member#: 193940
2004 WRX STI Black
No i trust this guy and he is the owner. (And likes me). When i dropped of the parts with the car he already had 2 Subaru coolant jugs so i know he bought the right stuff. I used Peak 50/50 coolant before. If he didn't flush it and just drained it with a little left over, could the two have mixed and caused some kind of a chemical reaction? It smells like coolant.
And it was the Subaru Long Life (green) coolant as you can see.
Old 05-21-2012, 02:14 AM   #7
UK-Wagon
Member#: 232430
555 I haz 5 Subarus
Was the peak 50/50 the yellow universal kind? even if it was I dont see how it could be red if you never used red. Unless you are using the internal oil cooler inside the radiator as a power steering cooler. It could be leaking inside..... Some guys use that cooler for the P/S which comes standard on koyos for cars with Automatic Transmissions. The lines are down on the bottom, but you should know this if you installed it.
Old 05-21-2012, 06:12 AM   #8
AZP Installs
Member#: 40160
2001 Race Tested,
Enthusiast Approved!
My guess, and it's only a guess is that there was some residual from the Peak fluid. It should be ok, but I would do a drain/fill just for safety sake.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 05-21-2012, 06:29 AM   #9
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Don't some places have a special machine to flush the coolant system? Maybe that is just some residual flush solution.
KOJAK-02-WRX is offline   Reply With Quote
Old 05-21-2012, 01:17 PM   #10
BlackFighter
Member#: 193940
2004 WRX STI Black
yes, but not all. need to find out if the shop flushed or just framed.
Old 05-21-2012, 02:44 PM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
so do you guys think this is two coolant missed together or residue and not oil or exhaust gasses? i know that it is a 2.5l section question but the mods moved it here.
Old 05-21-2012, 08:08 PM   #12
Elbert Bass
Member#: 283429
The fact that it separates indicates it is not coolant. Oil will float on water - red is usually tranny fluid - tranny fluid is an oil.
Not saying it is tranny fluid, but it is obviously some type of oil product...
Elbert Bass is offline   Reply With Quote
Old 05-21-2012, 08:20 PM   #13
BlackFighter
Member#: 193940
2004 WRX STI Black
Well it was cold. Could it separate at cold temp but when worms up mixes together? Does coolant come in different densitys?
Old 05-21-2012, 08:22 PM   #14
BlackFighter
Member#: 193940
2004 WRX STI Black
Could it be production oil from the Mishimoto production line, a little was left in some how?
Old 05-21-2012, 08:22 PM   #15
BlackFighter
Member#: 193940
2004 WRX STI Black
Old 05-22-2012, 08:57 PM   #16
scarney1988
Member#: 317760
If your not sure, and he wont give any answer. Drain, and refill with proper coolant and be done with it.
g-luck
scarney1988 is offline   Reply With Quote
Old 05-22-2012, 09:46 PM   #17
Rob.Prairie
Member#: 290881
Best bet is to flush it.
Rob.Prairie is offline   Reply With Quote
Old 05-23-2012, 01:52 PM   #18
d0ugch0i
Member#: 198861
2004 WRX
what everyone else said. drain it and refill it. better safe than sorry
d0ugch0i is offline   Reply With Quote
Old 05-24-2012, 08:27 AM   #19
erik11876
Member#: 275888
2011 WRX Limited
Same flush machine they use for ATF? Could be the culprit
erik11876 is offline   Reply With Quote
Old 05-30-2012, 05:28 PM   #20
CaliImpreza
Member#: 317639
2012 Impreza Premium
Dark Red
ATF is red. The radiators in Subies cool ATF fluid. When I messed with my OBW I had a bunch of ATF mixed with coolant in my drain pan. Either your new radiator has an internal bust and ATF is getting in the coolant or your shop got it mixed somehow. Drain and refill, see what happens.
CaliImpreza is offline   Reply With Quote
Old 05-30-2012, 08:07 PM   #21
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
OP has an STi, i highly doubt it came as an automatic, like an OBW.
fastnoypi is online now   Reply With Quote
Old 06-05-2012, 06:58 AM   #22
deathbomb843
Member#: 285970
its the subaru coolant additive that all dealerships add when flushing the radiator, its goopy just like that
deathbomb843 is offline   Reply With Quote
Old 06-05-2012, 07:36 AM   #23
Supraru
Member#: 23313
99' 2.5Rs
black
I don't think it is. Can't say I've studied what it looks like after I dump it in but it's not red like what he is showing.
Supraru is offline   Reply With Quote
Old 06-05-2012, 06:49 PM   #24
Elbert Bass
Member#: 283429
Unfortunately that is incorrect. I use Subaru Coolant conditioner daily. The Subaru conditioner is a light brown opaque color - not clear red as shown by the OP photo. Subaru conditioner also dissolves and mixes readily with coolant - it's not going to separate like that.
Flecks and specs in my coolant elgineddie Newbies & FAQs 7 11-05-2007 10:40 PM
What is this gunk in my coolant? billmidd08 Service & Maintenance 3 07-03-2006 11:53 PM
What is this goo in my coolant overflow tank? yobtah Factory 2.0L Turbo Powertrain 1 05-28-2005 03:27 PM
WTB: Belt covers for block. Last friday, my belts cut a hole in my coolant line.... psyber_0ptix Mid Atlantic Impreza Club -- MAIC 5 12-20-2004 05:46 PM
Sand in my coolant?? DanMan Factory 2.0L Turbo Powertrain 0 06-11-2002 07:59 PM
Message Board Statistics All times are GMT -4. The time now is 07:27 AM.
