Old 05-21-2012, 01:42 PM   #1
TomSTi
Member#: 300431
2012 WRX STi
ISM
Default 2012 STi Oil Analysis
I switched to RedLine 5W-30 at exactly 3000 miles, and drained it 4084 miles later. My copper is through the roof, and I have high aluminum and other metals.
Blackstone says it's still due to break-in, so I guess that's it, but I've seen other reports on this forum from new STi's with 1/10 the copper. Am I losing a bearing?
http://freepdfhosting.com/61ed518dc0.pdf
TomSTi is offline   Reply With Quote
Old 05-21-2012, 02:14 PM   #2
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I think you need to monitor it for a bit longer from what I have read. I have been getting oil analysis for all my changes, 2011 sti now with 365whp and 9000 miles. Certainly all the metals, etc. have come down with each analysis. These engines are not super precisely hand built, etc., so hard to know exactly what is going on in there so new.
Is the car having any other issues? holding boost? discoloration or smell change in exhaust gases? Cold start stuff?
tazswing is offline   Reply With Quote
Old 05-21-2012, 02:51 PM   #3
TomSTi
Member#: 300431
2012 WRX STi
ISM
Hello Taz, thanks for the reply.
I went to Cobb AP stage 1 91 Octane ( I use Shell 93) at about 4000 miles, no driveability issues whatsoever, no noises, purrs at idle, no smoke, stock airbox/filter.
I drove the first 1000 miles carefully, but with enough throttle to seat the rings right. Since then I've run it up through the gears hard now and again, but no real launches or visits to the rev limiter. Lots of highway miles, no low-rpm lugging.
I'll definitely do another change/sample after 3000-4000 miles and see how I'm doing.
Cheers, Tom
Old 05-21-2012, 03:48 PM   #4
b1aze
Member#: 284003
2010 Alpine 135i
Our cars have a copper lined oil cooler which seems to keep copper readings higher than, say, WRXs. I've gone through 3 OCIs with T6 and just finally got my wear metals in the "normal" range, and that's after 20k miles.
b1aze is offline   Reply With Quote
Old 05-21-2012, 03:59 PM   #5
white240hatch
Member#: 95556
2012 WRX 5dr
off topic but...after seeing this post it makes me want to get a test on my 12. Do i just get the standard $25 test or what? thanks!
white240hatch is offline   Reply With Quote
Old 05-21-2012, 05:54 PM   #6
bluesubie
Member#: 767
04 FXT
This. And different oils react with the oil cooler differently so if you're comparing uoa's you'll need to find another STI with similar mileage using Red Line 5W-30. Also, the esters in Red Line have a scavenging affect so the first couple of uoa's on RL will sometimes appear that wear is high.
I would say this is a very good uoa considering that it's still breaking in and is the first run on Red Line. Copper should drop on the next run, but will likely still be higher than normal. Dave at Red Line is very good about responding to emails so drop them a line from their web site if you want.
-Dennis
Old 05-21-2012, 05:59 PM   #7
bluesubie
Member#: 767
04 FXT
Yes, but if you're planning to extend the interval to 7,500 miles I would add the TBN for the first run or two on an oil to make sure that it's up to the task.
-Dennis
Old 05-21-2012, 06:02 PM   #8
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
ya, stick with the same oil for a while if you can. I just get the basic analysis. You can get them cheaper if you buy in bulk from Blackstone, which is what tuning shops often do so look around before you order your own.
Also, you can talk with the folks at Blackstone and see if they will make your own batch number so you can have a unique identifier in their system. But you need to call them and ask for this.
cheers.
Old 05-21-2012, 08:35 PM   #9
TomSTi
Member#: 300431
2012 WRX STi
ISM
Thanks Gents. I'll send a copy to RedLine too, and I'll post back with anything interesting.
Cheers, Tom
Old 05-21-2012, 09:44 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
there is no way in a cold frozen over hell these engines are 'broken in' at less that 7k or 8k miles
and no way in a cold frozen over hell id use any synthetic oil in them until after that
and there is no way in a cold frozen over hell id follow the 'manufacturers recomendations' on break in, either
but that is just me......i dont know nuffin
Old 05-22-2012, 04:04 AM   #11
TomSTi
Member#: 300431
2012 WRX STi
ISM
Thank you, US, you've answered a number of questions that no one asked.
Old 05-22-2012, 01:22 PM   #12
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
High copper readings shouldn't scare you with the first OCI on Redline. My car did it too. You can see my UOA history HERE.
I'll have an oci on Redline 0w30 back from Blackstone soon. I'll update when I get it.
gpshumway is offline   Reply With Quote
Old 05-22-2012, 01:39 PM   #13
TomSTi
Member#: 300431
2012 WRX STi
ISM
Thanks, GP. Are you switching to 0W-30 for MN winter startups, or some other reason?
Here's what Dave at RedLine had to say:
"The copper level is higher than I might expect, though not likely a bearing as lead and tin would also be elevated. The copper is likely from an oxide inside an oil cooler or an over plate on a cam shaft, either way nothing to be concerned about.
I dont recall seeing oil analysis specifically from this low mileage STi.
The 5W30 should be a good viscosity for the engine, certainly nothing here to indicate otherwise."
Old 05-22-2012, 03:42 PM   #14
TomSTi
Member#: 300431
2012 WRX STi
ISM
More: "In a new cooler the copper would tend to have a fresh non passivated surface, the oil will tend to react with that copper oxide, appearing initially as higher levels in oil analysis tapering off over time."
Old 05-22-2012, 06:52 PM   #15
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
You got it. Frigid MN winters are the reason for using the 0w30. Redline 5w30 is back in the car for the summer.
Old 05-22-2012, 09:17 PM   #16
bluesubie
Member#: 767
04 FXT
MN or the moon?
Viscosity Grade SAE 5W30
Vis @ 100C, cSt 10.6
Vis @ 40C, cSt 62
Viscosity Index 162
CCS Viscosity, Poise, @*C 60@-30
Pour Point, C -45
Pour Point, F -49
Viscosity Grade SAE 0W30
Vis @ 100C, cSt 10.9
Vis @ 40C, cSt 57
Viscosity Index 183
CCS Viscosity, Poise, @*C 56@-35
Pour Point, C -60
Pour Point, F -76
-Dennis
Old 05-22-2012, 09:34 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by bluesubie View Post
MN or the moon?
Vis @ 40C, cSt 62
Viscosity Index 162
Pour Point, C -45
Pour Point, F -49
Vis @ 40C, cSt 57
Viscosity Index 183
Pour Point, C -60
Pour Point, F -76
-Dennis
yeah.....the 0w30 gc is good stuff.....and no need to change it out in the summer, either
Old 05-23-2012, 07:23 AM   #18
bluesubie
Member#: 767
04 FXT
Oh, I presumed gps was talking about RL 0w-30 but it probably is GC.
-Dennis
Old 05-23-2012, 10:22 AM   #19
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
No no, I have used GC extensively in the past (see my UOAs), but this time it is Redline 0w30. Yes, it's oil designed for the vacuum of space.
GC is not as good. VI of only ~165 IIRC. The new SN version of M1 0w40 is slightly thicker at operating temp, but at very cold temps it's just as thin as GC owing to its 185 VI. Redline 0w30 of course beats them both for extreme cold, but is not theoretically as good for high temps, especially compared to M1.
It's funny. After I became confident I wouldn't have a warranty claim on my engine, I looked for oils for longer drains. I was torn between M1 0w40 all year on an easy to remember 5k change schedule and Redline 0w30 & 5w30 on a six month change schedule. At the time that would have equated to 6-7kmi OCIs on Redline. Now my work situation has changed and I get to telecommute more, meaning the 6 month intervals are only 4-5kmi. I may go back to the other plan and use M1 0w40.
One of these days I'll post the UOA history of my dad's 2010 Outback 3.6R, he's used M1 0w40, PP, and now M1 0w30. PP barely stayed in grade. He lives in truly frigid Park Rapids, MN.
I also might just use Redline 5w30 all year. It's MRV spec is not great, but MRV is really a binary metric any way. Either the pump cavitates or it doesn't, and RL 5w30 should be fine down to -30*C. It does get colder than that around here on occasion, but I'm confident I can plug in the block heater in those situations.
Could I use Redline 0w30 in the summer? Probably. We'll see how it comes back in this coming UOA. GC starts out with a higher HTHS, but shears a bit. If the RL is as shear stable as the 5w30, used RL 0w30 might be just as thick as used GC. This spring we had a couple of 80*F days while I still had the 0w30 in the car, it's not nearly as smooth as the 5w30. I know that's subjective, but none of the other oils I've used provided the smoothness throughout the OCI that RL 5w30 has, it's as good at 4kmi as brand new RT6.
Lots of mostly OT there, sorry to the OP.
Old 05-23-2012, 05:33 PM   #20
bluesubie
Member#: 767
04 FXT
Meh. I realize that you may see extreme cold winter temps, but some people have put WAY too much emphasis on VI (and other product data sheet specs) instead of oil data lately or performance. Did you know that the original "Green GC" used no viscosity modifiers? Truly an uber oil.
-Dennis
Old 05-24-2012, 09:35 AM   #21
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
I suspect you're talking about a certain frequent and militant poster on BITOG... I agree to a point, but what are you considering "data". I don't need to tell you that UOAs are primarily for entertainment purposes, especially as it relates to wear data. Most UOAs are decent for telling whether you can keep using the oil, but don't give much info about the quality of the oil other than an idea of shear stability.
VI is one of several important metrics in selecting an oil. The most important to me by far though is the performance certifications (ACEA A3, manufacturer specs).
Speaking of entertainment value, I just got my latest UOA back last night. I'll post it in my UOA thread. I asked for a KV40, the results are interesting.
Edit: UOA is up in my thread HERE.
Old 05-24-2012, 06:14 PM   #22
bluesubie
Member#: 767
04 FXT
Yes.. VI is useful to help determine what oil to run in some applications, but it's not the be all and end all. Arguing that Amsoil 0W-20 is a poor choice in TX because it is too thick is really pushing it, IMO. Same goes for pretty much saying that Havoline 0W-20 is a worse choice than Subaru 0W-20 for a new Impreza because Havoline is a heavier oil. This is 0W-20!
No, I don't consider a $30 uoa useful for wear data. UOA's by Dyson are a bit better, especially when the customers share a bit of info. And his old posts on bitog were helpful as well. Or show me some papers or studies. But I'll take anything over making assumptions based on what's in a pds. Sorry to vent here. But we always have to cover multiple topics in every oil thread. My next oci will be on an antiquated 10W-30 with a low VI. I'd pick a high HTHS oil like Red Line over high VI in a turbo any day.
-Dennis
Old 08-31-2012, 08:24 AM   #23
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
My copper also is high and was beginning to taper but this last sample was high again...
-2011 STI Cobb Stg 2 pro tuned with intake and inlet, Moroso catch cans.
-11,153 miles on car
-3,630 miles on Shell Rotella T6 5w/40
-0 make up oil added
-Fumoto valve
Note: This past oil change I put in some ENEOS 5w-30 which my friend has been running and getting good results with (with UOA's to back it up) so I hope to have another sample soon... Some speculate that the Fumoto valve can be leaching copper into the oil, others say it can be an additive in the oil itself, and of course there is the copper oil cooler or something that may be actually wrong.
jay25RS is offline   Reply With Quote
Old 08-31-2012, 03:16 PM   #24
bluesubie
Member#: 767
04 FXT
Copy and paste.
IMO, the copper isn't from the fumoto. I've used the same fumoto valve since 2003 and have never had high copper. I do notice that copper varies whenever I switch oil brands a lot and I agree that this probably copper leaching from the oil cooler. This is even more noticeable on new engines.
Copper and Your Diesel Engine Oils
As distinguished from mechanical wear, cooler core leaching is a chemical process. Although well documented in the literature, it has been only recently that the factors leading to the phenomenon have been understood. It seems to boil down to three things: zinc dialkyl dithiophosphate (ZDDP), heat and new engines. The principle elemental component of ZDDP is sulfur. For new engines with less than 1,500 hours of service life, the cooler core becomes an active reaction site for the ZDDP, resulting in copper sulfides forming on the copper cooler tubes. These sulfides later slough off into the oil, contributing to a rising copper concentration than can reach well over 300 ppm. As alarming as this sounds, it has been reported that copper sulfide, even in these high concentrations, is generally benign and as such may not be associated with (cause or effect) cooler failure, accelerated wear or lubricant oxidation. While I personally have not seen the data that support these claims, I also have no basis to refute them.
If you're trying to pinpoint something that appears to be a problem, you need to stick with the same oil/grade for 2-3 oci's IMO. My uoa "wear" numbers didn't even start to drop until around 18k miles. The last time that I saw true high copper (triple digits) in a turbo Subaru was a few uoa's around the time of the '08/'09 turbo stop sale. If you're really worried, consult a professional tribologist that uses an ISO certified lab.
Dyson Analysis ...
Blackstone for entertainment purposes. Dyson to help you figure out if you have a problem.
Do those magnesium and calcium numbers look right? I know that any HDEO will use a lot of magnesium but I don't recall if that amount looks right.
edit: I think your magnesium and calcium numbers may be backwards. Here's a UOA with calcium at 1204 and magnesium at 933. I would contact Blackstone.
-Dennis
2012 STI oil smell and studder cjd19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 05-23-2012 05:21 PM
2012 STi 91 Octane Data Log Analysis kevosti AccessPort 0 02-04-2012 07:21 PM
Used Oil Analysis - Castrol Syntec 10W40 - Subaru WRX STi, 2nd sample alanlcit Service & Maintenance 8 10-23-2007 09:54 AM
Used Oil Analysis - Castrol Syntec 10W40 - Subaru WRX STi alanlcit Service & Maintenance 19 07-24-2007 03:09 AM
'04 STi (stock) engine oil analysis report at 7,323 miles. lstepnio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 03-14-2004 11:59 PM
