Closed Thread
Old 02-03-2013, 01:10 PM   #2726
Last Subie
Member#: 345669
2012 Imprez prem 5sp
Exclamation 2012 Impreza Burning Oil
I say burning but I don't know where it goes.
I am new to the thread, but my 2012 impreza needs oil added frequently. I need to start watching exactly how much. I would say a quart every 7,500 miles.
I would love to see an impreza owner log on and say that they don't burn a drop.
Thanks to all who have pointed out that the dealer over fills. I thought they did that but was reluctant to question their expertise.
I will now.
Last Subie is offline
Old 02-03-2013, 01:18 PM   #2727
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I would argue that adding 1 qt every 7500 miles is not "frequent". In fact, since that's Subaru's recommended oil change interval, it sounds to me like you don't need to add oil at all.
sgoldste01 is online now
Old 02-03-2013, 02:48 PM   #2728
79letour
Member#: 302570
2013 XV
DGM!
No one likes the thought of their new car burning a quart of oil between changes.
But it sounfs like youre on the far end of the oil consumption scale. I burn a lot more oil than you and am not close to burning enough to get anything replaced.
79letour is offline
Old 02-03-2013, 03:16 PM   #2729
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I will now.
Did any of your other cars go 7500 miles with out adding oil?
auskip07 is offline
Old 02-03-2013, 03:57 PM   #2730
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
I will now.
Needs oil frequently? 1 quart every 7,500 miles is not frequent - that is the optimal oil change interval. If you look at the description of severe conditions, a lot of locations/situations actually fit that criteria. That interval is much less than 7,500. I personally think Subaru made a bad decision on making the interval that long on such a light weight oil.
ST Eye is offline
Old 02-04-2013, 12:03 AM   #2731
stevehnm
Member#: 329526
2013 Impreza Spt cvt
Actually to my knowledge mine has not used a drop. Hard to tell, though, as the dealer overfills it. Next service I will pursue the question of why they overfilled it.
Speaking of dealer service, how does one get out of the maintenance agreement?
stevehnm is offline
Old 02-04-2013, 07:59 AM   #2732
M45
Member#: 333446
2013 Impreza SL CVT
My first oil change looked like I had not burned a measurable amount. this was only 1800 miles though :P
M45 is offline
Old 02-04-2013, 08:41 AM   #2733
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Agreed i think every 5k is a good number to stick with
auskip07 is offline
Old 02-04-2013, 09:00 AM   #2734
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
There's no harm in that choice. But if you've looked at the Used Oil Analysis thread, then you've seen the results of my analysis, which showed that my oil had a lot of life left in it at 4500 miles, and that Blackstone recommends I could safely go to a 6500 mile oil change interval.
DISCLAIMER: I use Amsoil OE 0W-20 oil, and don't drive very aggressively. If your oil and driving conditions differ from mine, then you might get different results. I provided my used oil analysis report as an interesting data point, and make no guarantees about the OCI you should use.
Old 02-04-2013, 09:18 AM   #2735
Angelus911
Member#: 89967
2012 Impreza Sport
What do you guys think about the new Mazda 0w-20 Synthetic? I've heard some good things about it:
http://www.cleanmpg.com/forums/showthread.php?t=45295
http://www.bobistheoilguy.com/forums...Number=2520584
It's a little expensive at $7.95 per quart, but thought it may be worth a try for my next oil change coming up.
Angelus911 is offline
Old 02-04-2013, 10:20 AM   #2736
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I think it will be no different than any other 0w 20 oil. That includes amsoil and mobile 1.
auskip07 is offline
Old 02-04-2013, 12:08 PM   #2737
ST Eye
Member#: 73068
I am also going with a 5k mile interval. My good friend (head Suby tech) suggested between 5k-6k. Since I get free oil changes at my local dealership, I'm going with 5k.
ST Eye is offline
Old 02-04-2013, 12:48 PM   #2738
Zeeper
Member#: 299286
2015 WRX CVT
I will now.
I change my own oil, last change was October 30th, with 7000 miles, and now have 9,400 miles with no visible change in oil level. If I overfilled it, it wasn't more than a couple of ounces (I think I poured about 5.4 liters in).
That does not mean it hasn't used a drop, just that it is not burning enough to be noticeable.
There are cars that are burning oil, and cars that are not. There is a problem if you are consuming a liter between changes, no doubt. However you cannot take your experience to mean that all of the new imprezas are burning oil, because the evidence actually points the opposite direction, a small percent are burning, and most are not. At least all the evidence I have seen, based upon the number of cars sold.
Zeeper is offline
Old 02-04-2013, 12:54 PM   #2739
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Same here with the 5k oil and filter change interval. My driving situation would probably fall under Subaru's definition of "severe", but I feel a 3k interval is a waste of money. I will probably send a sample to Blackstone Labs the next time I change my oil.
Also using AMSOIL OE 0W20.
jr0bb5 is offline
Old 02-04-2013, 02:16 PM   #2740
79letour
Member#: 302570
2013 XV
DGM!
I'd like to see the results of a uoa from an oil burner running 0w20 subaru oil, and going the reccomended 7500. I've never had oil in my car long enough to worry about uoa's but when that consumption test is over, I'll send off a sample.
Being that Amsoil is such expensive stuff,I'd be curious to see what a 79 year old guy whos getting dealer changes gets for uoa results. So far it looks like even with amsoil and a good non oil burning engine, 7500 miles is pushing it.
79letour is offline
Old 02-04-2013, 02:17 PM   #2741
79letour
Member#: 302570
2013 XV
DGM!
Not ALL the imprezas are burning oil. But it says a lot when Consumer Reports has to top theirs off...
And dealers have scripted answers about allowances...
79letour is offline
Old 02-04-2013, 02:48 PM   #2742
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Not all Amsoil is expensive stuff. My Amsoil OE 0W-20 costs $6.10/quart, and no shipping charge because I buy it from a local distributor.
My car is not an oil consumer, so I'm not adding any fresh oil between changes. My Blackstone UOA with almost 5k miles on the oil (and 11k miles on the odometer) resulted in Blackstone telling me I could probably get 7500 miles from the oil, but they recommended using a 6500 OCI just to be safe (and sending them another sample at 6500 so that they could confirm that the oil was still good, which I don't plan to do; instead, I think I'll just use a 6500 mile OCI and leave it at that).
Old 02-04-2013, 03:21 PM   #2743
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I just paid 5.54/qt after shipping and tax for my amsoil OE. So definitely not expensive stuff
flyboy1100 is offline
Old 02-04-2013, 04:42 PM   #2744
jr0bb5
Member#: 315353
5MT OBP/DGM
That's about what I pay. Think it's only $4.70/quart before shipping and tax.
Better and cheaper than M1 and shipped to my door within 2 days!
jr0bb5 is offline
Old 02-04-2013, 04:53 PM   #2745
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I want to believe that the Amsoil OE is better than Mobil1. But without a Used Oil Analysis from someone running Mobil1, we're all just speculating.
Old 02-04-2013, 05:01 PM   #2746
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Our Imp hasn't burned a drop yet. It has about 12,000 miles total now i think.
saabarupp is offline
Old 02-04-2013, 09:10 PM   #2747
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Same goes for me, except I'm at almost 13k miles.
jsteg is offline
Old 02-04-2013, 11:50 PM   #2748
stevehnm
Member#: 329526
I agree that all new Imprezas do not burn oil. My opinion is that a small percent do burn oil. That is based on my experience.
It is also your *opinion* Zeeper. It is not *evidence*.
You need to learn the difference.
stevehnm is offline
Old 02-05-2013, 06:54 AM   #2749
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It looks like stevehnm and Zeeper are in agreement then--a small percentage of Imprezas burn oil. I think everyone on this forum agrees that this is true. Nobody is saying that they all burn oil, and nobody is saying that none of them burn oil.
Old 02-05-2013, 07:01 AM   #2750
stevehnm
Member#: 329526
"Small" is a relative term, and only Subaru knows what that number is. It could be 1%, it could be 25%. I believe it is within that range.
We don't know, as we don't have the *evidence*. It does point, however, to a potential variability in their manufacturing process - another feature of which might be excessive fuel consumption, as opposed to excessive oil consumption.
stevehnm is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
