Closed Thread
Old 05-28-2013, 08:38 PM   #3651
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Originally Posted by sgoldste01 View Post
Time to start doing your own oil changes.
I would but the terms of the extended Warranty is only Authorised Subaru dealers can perform the Servicing.
Interestingly I called the Service Manager and requested he advise if this is considered overfull, he disappeared for a bit then informed it is Normal for them to overfill these cars because it is Normal for them to use oil between services, my concern is so far ours doesn't use much and I'd like it to stay that way.
John451 is offline
Old 05-28-2013, 08:55 PM   #3652
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
What an effing scam this is. They rape you for the price of the extended warranty, and then they rape you again every time you need an oil change.
Do they charge you for the KY Jelly before they ask you to drop your trousers and bend over?
Sorry for the rant, but this kind of crap pisses me off. Just strikes me as a conflict of interest, forcing you to use their service in order to satisfy the terms of the warranty.
sgoldste01 is offline
Old 05-28-2013, 09:18 PM   #3653
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
And completely false...
Xafen is offline
Old 05-28-2013, 09:34 PM   #3654
MattD87
Member#: 126930
2015 Legacy
CGM
Couldn't have said it better myself!
MattD87 is offline
Old 05-28-2013, 09:50 PM   #3655
John451
Member#: 321966
The extended warranty was " Free ", obviously the locked in servicing requirement is a way to get their money back, still the extended contract is from Subaru the company not the Dealer otherwise I wouldn't worry about it also it's my wifes car and she wants it done by the dealer.
John451 is offline
Old 05-29-2013, 06:40 AM   #3656
79letour
Member#: 302570
2013 XV
DGM!
Was there a tsb for ky jelly??? I never got any.
79letour is offline
Old 05-29-2013, 08:04 AM   #3657
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Maybe that's why you think the seats are so uncomfortable.
Old 05-29-2013, 10:34 AM   #3658
79letour
Member#: 302570
2013 XV
DGM!
Finally some comic relief!
79letour is offline
Old 05-29-2013, 11:01 AM   #3659
srpuywa
Member#: 355974
2013 2.0i 5 door
dark grey
I have 228K on my 2003 Jetta TDI - it's been pretty reliable
I hope the 2013 Impreza is as well
srpuywa is offline
Old 05-29-2013, 01:35 PM   #3660
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
If you have an extended warranty (not maintenance contract) with Subaru, you can still have your services performed anywhere....just keep ALL receipts. Having a SAS (Subaru Added Security) contract does NOT bind you to have your service (maintenance) done at at dealer. The mechanical issues have to be done at a dealer, but not the maintenance.
However....if you have a maintenance contract thru Subaru, they have to be performed at the dealer in order to get them for free. Do you have to do them at the dealer? No, but you will pay for them if you go elsewhere.
RexyGirl is offline
Old 05-29-2013, 03:52 PM   #3661
John451
Member#: 321966
Thanks RexyGirl, will re-read the fine print as have a long time competent mechanic I'd rather use.
Do you know if it's Subarus recommendation to now normally fill past the Imprezas full mark by 3/5 to 4/5 " as measured after 3 minutes ?
John451 is offline
Old 05-29-2013, 04:09 PM   #3662
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I've always heard that overfilling is bad for an engine because it can cause oil foaming. I don't know how much overfilling would be required to cause foaming in a Subaru boxer engine. Regardless, I can't recommend overfilling.
Old 05-29-2013, 04:14 PM   #3663
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Down Under, Canada, Europe, and Hawaii; the Subaru SAS "aspects" may be different than those stipulated for the US domestic market. Notice that Hawaii is not considered to be within the US domestic market.
Anyway, welcome back to the forum.
G-
G-Omaha is offline
Old 05-30-2013, 05:30 PM   #3664
John451
Member#: 321966
Thanks, its what I think also although their mechanic when I asked said 20mm wasn't enough to cause foaming.
The first oil change they overfilled it by the same amount and the motor would smell like burnt oil whenever I went up a steep mountain range, think the excess oil must have been burnt through the air box. Had them empty it back to " F " then and the smell went away.
Last change I firmly stipulated they don't overfill and their wasn't a problem, so will have them remove some.
John451 is offline
Old 05-30-2013, 07:27 PM   #3665
SylvainBeauvais
Member#: 314448
My 2012 was burning about two and a half litres for each 7,000 km (4,000 miles) or so. I was somewhat worried as this was my first car ever to burn oil. Upon my first oil change I mentioned it to the dealer but he said that during the break-in, it is not uncommon to see this.
Upon my second oil change, I pointed out to the dealer that the problem was still there. They noticed that an oil vapor recirculation valve was stuck open (not the exact scientific term but this is how they explained it) and it was probably the culprit.
They replaced the valve about 7,000 km ago and it does burn oil any longer.
I now have 15,000 km on the car and couldn't be happier with my Subaru.
SylvainBeauvais is offline
Old 05-30-2013, 08:21 PM   #3666
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I assume you meant, "They replaced the valve about 7,000 km ago and it does not burn oil any longer."
Old 05-30-2013, 11:21 PM   #3667
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Hmm... that's interesting. Glad to hear that replacing that valve fixed your problem. Sounds like a relatively easy fix.
None of the techs at my dealership mentioned anything about that valve possibly being the culpit for my oil consumption problem, but I assume that they checked it.
jr0bb5 is offline
Old 05-31-2013, 07:34 AM   #3668
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Never...assume...anything.
Old 06-02-2013, 12:22 PM   #3669
LloydP
Member#: 329308
My car has 10,000 miles on it. Low oil level lit up on the 4,000mile mark and 3,000miles after my first oil change. It doesnt bother me that the engine eats up oil actually.
There was finally a possible solution stated in this thread how we can prevent the engine from eating up oil
Just now, my oil level pressure warning light illuminated. But faintly illuminated mot like when you switch your keys to ugnition when starting the engine.
The warning light illuminates when im cruising around 60mph. It doesnt illuminate on stop and go traffic.
Has anybody found a solution for the oil pressure warning light? Im going to bring my car to the dealer tomorrow. This thread is so long and i dont have the time to backreaf all the 100+ pages.
Thanks!
LloydP is offline
Old 06-02-2013, 12:48 PM   #3670
LloydP
Member#: 329308
Just to clarify, the yellow indicator warns you that the oil level is low. That happened to me twice which i dont really mind.
What happened to me awhile ago is the red oil pressure warning light.
Has anybody solved this?
Knowing that this is a world wide problem makes me at ease. At least i know im not the only one and no one i think had their engine broke down because of this issue.
Should we just not mind the low oil pressure warning light? Take out the bulb maybe? Hahahahaha
LloydP is offline
Old 06-02-2013, 03:20 PM   #3671
79letour
Member#: 302570
2013 XV
DGM!
Only a few ON HERE habe had the red oil pressure light, and iirc they were all electrical problems. No widespread oil pressure losses have been reported.
79letour is offline
Old 06-03-2013, 01:05 AM   #3672
BretAZ
Member#: 320866
Just checking back in here to see if Subaru has addressed any oil consumption issues. Not surprised they haven't.
As for the red oil light, yes mine was dimly illuminated. The dealer had to solder a wire on because they said it was too short from the factory. I can't remember which dealer now. Some dealerships know how to fix it and some don't. Another problem Subaru is aware of and has failed to address. SOA is worthless.
Don't miss that POS Subaru one bit.
BretAZ is offline
Old 06-03-2013, 02:52 AM   #3673
LloydP
Member#: 329308
Just brought mine to the dealer here in the Philippines. They also suspected that it might be a grounding issue. I hope its hust the same as BretAZ's case. Its weird how a new car has grounding issues or a wire is too short. Ill be bringing my car next week for further inspection and repair.
I also relayed my concern of my impreza burning oil. This shouldn't happen based on the reply of the service manager. Next time my oil level light illuminates, ill be bringing the unit to the dealer and they will do a full check up on my oil consumption. I didnt get to bring my car and show them the oil level light since i was out of town and decided to put oil in just to get home.
Our imprezas here in the Philippines are made in Japan and has european specs. My impreza has a 6speed MT. So far there are no other reported oil eating imprezas since most of the people here bought the CVT version. I think only the MT variant has this issue.
Here it is not recommended to use the 0w-20 grade oil due to the hot weather. Here we use 10w-30 i think.
The dealer here are easy to work with. Ill give you updates on my oil eating impreza as soon as i have time to leave it in the dealer for inspection and repair.
LloydP is offline
Old 06-03-2013, 08:31 PM   #3674
jr0bb5
Member#: 315353
5MT OBP/DGM
I forget, what did you get rid of your Impreza for? Was it the Mazda 6?
jr0bb5 is offline
Old 06-03-2013, 10:23 PM   #3675
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I think he got a new VW Beetle Turbo.
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
